Question about Uniden 5.8GHz Cordless Phone
Handset 2 line on hold cant get it off hold, until then it will hang up when using.
Handset 2 line on hold during calls it hangs up
  • 77 Answers
Make sure that on the base of the main set that you are plugged into the port that says LINE1/2 and not just line 1
Posted on May 29, 2009
How do you turn the speaker phone back on for Mitel 4025?
While on a call and using the handset, place the call on hold, then hang up the handset, then press the line button of the active line. The call will now appear in handsfree mode on the speaker. To take the call off the speaker and go back on handset mode, simply lift the handset. Hope this helps.
Apr 24, 2014 | Mitel Superset 4025 Corded Phone...
Unable to Call, Try Again
The phone line is supplying a certain amount of power. If you open many parallel channels the power is distributed among active phones. The more sets there are the less power each one gets.These are the physical principles behind the limitations on the number of ringers a single line can activate (Ringer Equivalence Number)
As to the need to be using 3 or more sets on the same line and at the same time, I have a hard time understanding that.
For a landline, your phone company can activate 2 numbers, as it can enable A/DSL on your phone line.
Dec 18, 2013 | VTech Communications CS6409 - cordless...
How do i enable call forwarding from my vtech phone to my cell phone
Hello! You can turn on call forwarding by pressing 72# then wait until you hear the two tones and dial your number that you wish to send the calls to and then hang up the phone. The two tones signal that it has understood your command and is putting the line into forward mode.
To turn off cal fowarding, press 73# and wait again for the two tones and hang up.
Apr 21, 2011 | Vtech CS5121 Cordless Phone
My nokia n72 has a problem when ever i on it during the booting period it hangs and sometimes it will work and during the period i am making use of it, it will hang please i need help
Dear customer miraclebenso
I will very happy to help you please follow those steps
1)You just switch off your handset first
2)Press *star button- 3 button-calling button and on/off key at a once times but don't put out your fingers until the phone star for formating. Two persons may do better this so take help from any other person.
3) Your handset will restart automatically.
It will erase your all data of phone memory ( CONTACT , IMAGE, RING tone ) It will work 100/ or you should to flash your mobile phone by FLASHING software. There are many softwares in the market for example JAF, UFS and HWK . If you are not a trained mobile technician then you should to contact your nearest NOKIA care center. Thank you RON Rank : GURU
Jan 10, 2011 | Nokia N72 Cellular Phone
Uniden 1725 no dial tone
I had the same problem as long as they are plugged in correctly and you put the #2 handset into the #1 cradle to register it to your base then try hanging the phone up several times. These are expandable phones so that I believe you can keep adding other handsets. So sometimes they think you have a few more handsets than you really have so when you hang up it may not know what handset you are hanging up #1 #2 or #3 #4 etc. So I had to keep hanging them up until it finally hung up. Then I had to re install them so it knew I only had 2 hand sets. So then you start from the beginning, like when you took it from the packaging. I hate these phones. I ended up replacing them with different ones. Plus I always keep a rotery phone laying around put away because during a power outage you still can plug in an old dial phone and it will work! Nothing like old technology.
Feb 15, 2009 | Uniden 5.8GHz Dual Cordless Phone
Transfer
Do you mean send the call to another phone?
Make sure the line is not on hold (push the caller's line) then push Cnf/Trn, dial the extension you want the call to go to, then hang up.
The person you're sending to will receive that call on their speakerphone button and it will ring in a different tone.
Jan 13, 2009 | Toshiba DKT-2010H Corded Phone
I can use the calculator on my iphone but I cant use the keypad..
try to reset your device once to factory setting. switch off your phone first than hold power and home button for 10 seconds.
Jan 02, 2009 | Apple iPhone Smartphone
Turn off ringer?
On the base, to turn the ringer off, press and hold Volume Down [V] until the unit beeps 2 times. On the handset you can use the menu to turn off ring. This way, you can choose to receive and take the urgent calls.
Apr 04, 2008 | Panasonic KX-TG2313 Cordless Phone
Storing Speed Dial Phone Nmbers
Emergency/quick dial numbers: Pick up handset, push store, enter the phone number (it will not call the number), push store again, Push A,B or C. hand up handset. Frequently called numbers, pick up the handset, push store, enter the phone number, push store again, push key pad 1, or 2, etc. for memory location. Hang up handset. How to change a stored number. just repeat the sequence. How to clear a stored number, repeat the storage skip step 3 (do not enter the phone number). How to correct an error while storing, just hang up and repeat.
Feb 26, 2007 | GE Telephone pr521w
Uniden 5.8GHz Cordless Phone Logo
502 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
