Question about Mitsubishi VS-45607 45" Rear Projection Television
No picture vertical line across tv has sound - Mitsubishi VS-45607 45" Rear Projection Television
  • Mitsubishi Master
  • 1,869 Answers
Vertical output transistor failure
Posted on May 29, 2009
THe tv is showing just a line straight across the tv
Vertical Ic collapsed need to be replaced
May 27, 2010 | Sansui DTV2760 27" TV
Line across the tv no sound no picture
If you look carefully at teh line it should be red, green, and blue close together to appear like a white line. If this is the case, then the vertical circuit has failed. This is often poor solder connections at the vertical IC or a defective IC. Expect a parts cost in the $20 range for this repair.
Dan
May 04, 2010 | Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
TV TURNS ON,LINES ACROSS SCREEN THEN TURNS OFF BY ITSELF
sounds like a vertical problem, usually you'll see one white line across the screen, but one I worked on would come on and the bottom half of the picture was gone and there were lines across the top of the screen.
If you know how to solder & can find the vertical output chip then you could try resoldering the pins. If this doesn't fix it then it needs new parts.
Mar 08, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Vertical Green Lines across TV Screen with no picture
The capacitorson the FMT board have failed, which will cause that symptom. Is the menu screen clear when you hit menu?
Apr 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
SanyoTV-blk screen w/thin line of light across screen great sound
Your Vertical Amp is probably Blown (bad) , but before you change that check all capacitors around the vertical amp IC and / or resolder resistors and diodes around vertical amplifier.
And NO it is NOT the Picture Tube
Good Luck
JG
Apr 18, 2009 | Sanyo DS27820 27" TV
Line across picture tube
It's a bad solder connection on the vertical IC.It will be mounted on the main board.It is vertical in length and will have thirteen pins..should be marked "LA7838" or similar.
Apr 04, 2009 | Emerson TS2587D 25" TV
Problem with my insignia tube tv!!!!
if that look like horizontal line shuld be vertical problem. check vertical ic around it of resistor& capacitor. good luck!
May 26, 2008 | Insignia NS- 27" TV27 TV
Sound but no picture
A white like across the screen means that the vertical circuit has stopped working. Look for a small fuse that looks like a resistor near the vertical output IC, replace that fuse if open and resolder the pins on the vertical output IC.
Jul 08, 2007 | Toshiba CZ32V51 32" TV
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
Mitsubishi VS-45607 45" Rear Projection Television Logo
63 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
