Question about Bissell 1400 Little Green Pro Canister Steam Vacuum
I think the pump needs to be replaced in my Bissell little green machine. Some water/solution is being pushed through but not enough to spray only drip, if I hold the machine up high while using it (ie on a table) it will spray a little. Is the pump easy to replace? is there anywhere to get a parts diagram?
  • 3 Answers
I got my Little Green ProHeat when the product was first unveiled several years ago. Shortly thereafter, the nozzle itself developed a clog in the spray jet. Remove the nozzle from the end of the hose, and with the machine running pull the trigger. If a great amount of solution comes out of the supply hole, then your nozzle is clogged. You can try clearing it with a very thin pin and then rinsing it out.
In about 6 months, my pump would no longer spray solution at all but I could hear the tiny pump still running inside the machine when I would pull the trigger. Remove the tanks, unplug the unit, and look carefully and you will see the few screws holding the unit together. Pull it apart carefully and don't use much force as some of it snaps together and you don't want to break those tabs. Once open, you can find the solution pump, a little fella. The drive shaft on the motor that spins the pump had rusted away completely! Design flaw. In lieu of getting it repaired, I simply started using a spray bottle for my solution application. Several years later and I'm ready to take the time to replace the pump - a very simple process. From the research I've done, the part number for the solution pump is:
Manufacturer's Part Number: 6035029
If you google search "Bissell 6035029 VacPartsWarehouse" without the quotes, you should find your part there for around $9.
Try this direct link to VacPartsWarehouse's website:
VacPartsWarehouse Bissell 1425-2 Little Green ProHeat
Click item #9. It's very simple to install. If you can wield a philips screwdriver, and pay attention to how you've disassembled the unit and then just reverse the steps, you can fix this yourself on the cheap.
Good luck! :)
Dan
Posted on Sep 12, 2009
  • 11 Answers
The motor for the pump rusts because the design of the pump does not seal well against water leakage. Water gets out (the only thing that seals it is silicone grease) and rusts the motor. It can get so that the front of the motor shaft wobbles and that makes the leak worse.
As noted, a new pump/motor assembly is cheap. If you get one and replace it, don't forget to tie-wrap the hoses, as the factory does, or you will get leakage at the hoses.
Posted on Sep 19, 2009
  • 4 Answers
Instead of just purchasing a new motor, try what I did: disassemble the case, remove the pump motor from the plastic housing, make sure the drive shaft is turning by using a pair of pliers to turn it, lubricate the drive shaft where it enters the motor with a drop of 3 in 1 electric motor oil (NOT WD-40, can cause more seizure). Reassemble the motor and case. Worked for me, and I saved $10 at least for now!
Posted on Aug 04, 2010
    Problem Solver:
  • 5 Answers
Check out bissell.com for troubleshooting questions. I have had luck there.. It might be a pluged hose in it. liquid mixtures can harden if you do not clean out the mechine after use.. run water through the system.. if it is a clogg or if you have calcium deposit issues in your area, try running vingar and water in the system..
Posted on May 30, 2009
How can I download Bissell Little Green Clean Machine manual?
direct
https://canada.bissell.com/support
or the first link has it, also videos
  • BISSELL LITTLE GREEN 1400 SERIES USER MANUAL Pdf ...
    www.manualslib.com > ... > Vacuum Cleaner > Little Green 1400 SERIES
    Bissell LITTLE GREEN 1400 SERIES User Manual. ... Vacuum Cleaner Bissell Little Green 1400 SERIES User ... Rcvd a used bissell little green machine w stagnant ...
  • Bissell Little Green Machine ' Walmart.ca
    www.walmart.ca > Walmart.ca > Appliances > Vacuums > Steamers
    • 4.1/5
    • 185 REVIEWS
    • $99.96
    Bissell Little Green Machine for sale at Walmart Canada. ... Powerful suction lifts stains and spots with water or any of the Bissell cleaning solutions.
  • Little Green® Portable Carpet Cleaner ' BISSELL®
    www.bissell.com > ... > Browse By Type > Carpet Cleaners > Portable
    The Little Green® portable carpet cleaner is produced with a minimum of 50 ... Coupon code for purchases on bissell.com: ... (including all accessories and manuals) ...
  • BISSELL LITTLE GREEN CLEAN MACHINE PDF - fenbook.me
    fenbook.me/get-it-free/b/bissell-little-green-clean-machine-manual.pdf · PDF file
    Get Free Read Online Ebook PDF Bissell Little Green Clean Machine at our Ebook Library. Get Bissell Little Green Clean Machine PDF file for free from our online library
  • Bissell Little Green Owners Manual ; Bissell Little Green ...
    www.youtube.com/watch?v=PpQji8obNz4
    • BY BOTHSHOOP
    • 4 MIN
    • 11K VIEWS
    2012-11-07 · Video embedded · Bissell Little Green Owners Manual ; ... Bissell Little Green Owners Manual ; Bissell Little Green Machine ... How to fix a Bissell Carpet
  • Bissell LITTLE GREEN 1400 SERIES User Manual
    May 24, 2016 | Bissell Vacuums
    Little green machine will not spray. Can I fix it?
    yes according to the model you have look up a schematic on line and take it apart you will see the pump assy the pump # is 6035029 this can be purchased on line i got mine at VacParts Warehouse.com think it was about 14 or 15$
    Sep 11, 2010 | Bissell THE BISSELL LITTLE GREEN MACHINE...
    Biseell little green machine wont squirt water out
    The Pumps on these go bad after a couple of months. They rust and will sometimes spray and other times not then eventually not work at all. If your a handy man pull the top off it and remove the pump motor and replace it yourself. The part number is 603-5029 you can put this number in google shipping and get it to your door for about $15 and replace it yourself or have a friend do it. Ebay has tons of them once again just put in the part number and a list of them will come up.
    Thanks and have a good one
    Sincerely, CRTN
    May 22, 2010 | Bissell THE BISSELL LITTLE GREEN MACHINE...
    Spray path is too wide. Is there a deflector available
    I had the same problem with my proheat. The water would spray a wide path out the sides. I think it must be a defect as I have replaced my unit due to another problem. I purchased the Bissell machine without the heater and the nozzle is fine.
    May 14, 2010 | Bissell 1425 Little Green ProHeat Handheld...
    Cleaning the bissell little green
    Bissell 1425 works great, but today will not ****! Spray is fine....just no suction, even without any attatchments.
    Oct 11, 2008 | Bissell 1425 Little Green ProHeat Handheld...
    I need directions for using the Bissell Little Green.
    http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=723971
    Generic problem for all Vacuums
    Posted by jkcanger on Jun 30, 2008
    I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. If the instruction did not come with the Bissell Little Green Machine then I would contact the Bissell Factory that I will provide for you listed 2 the bottom of the answer,
    So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
    http://www.bissell.com/ Customer Service 1-800-237-7691
    Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
    Saturday 9:00 am to 8:00 pm EST Mail To: Headquarters, Bissell Homecare Inc
    P.O. Box 3606 Grand Rapids. MI 49501
    Thanks, Don the Vac Man
    Go Ahead. Use Us.
    Jun 30, 2008 | Kenmore Progressive Bagless Upright with...
    How to install a new water pump on a big Green machine?
    I have replaced this pump before, and had the pump "seize" again. I hooked the output of the bissel to a siphon pump to pull a vacuum while i had the input hose (with the little filter) submerged in a bucket of water. After i got the pump started, I submerged both the inlet and outlet hoses (after the trigger handle) into a bucket of warm water and turned the spray switch on to circulate clear water through the whole deal
    Jun 27, 2008 | Bissell Vacuums
    Big Green
    We found that ours had a simpler problem. Upon opening the motor compartment, we saw that the pump had "nudged" up from it's mounting slots. It is held down by a clip on each end and one had pushed up, allowing the pump to ride up and thereby disconnecting the short hose which kept the "suction train" intact. Once we re-seated the pump correctly and pushed the clip back down, the hose reached nicely and our suction was re-established.
    Getting into the motor and pump area was the hardest part. Inside the power hose "cubbie" is a small hex head screw. Find your shortest stubbiest 1/4 inch open ended wrench to loosen this screw (lefty-loosey). Once the screw is out, gently pry along the edge with fingers and thumbs. The top (ours is green) part should separate itself from the bottom (ours is beige) part. The pump in our unit is red and has a 4-5 inch hose leading from the end of the pump to the outlet (on the outside of the green or top part). Re-assemble and go for it!
    Mar 20, 2008 | Vacuums
    Bissell 1720-1 Little Green
    If it isn't spraying, the pump is most likely bad, leaking from tank, depending where it is leaking, may need a new tank. But Bissell has obsoleted this unit and its parts. So unless you can find the parts somewhere, it may be time for a new one.
    Feb 29, 2008 | Bissell 1720-1 Little Green Wet/Dry Vacuum
    Bissell 1400 Little Green Pro Canister Steam Vacuum Logo
    2,264 people viewed this question
    Top Bissell Vacuums Experts
    Jim Parker
    Jim Parker
    Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
