Question about Dell 1600n All-In-One Laser Printer
Overheat message comes on.
My Dell 1600n printer shows the message "overheat". What steps should I take in order to print?
  • 10 Answers
First, you need to make sure that you are using the best settings for your printer. Here are a few things to consider:
1) Environment - If this printer is stored in a cabinet, under a desk, on the floor, etc., it is likely that any heat created by the fuser doesn't have room to escape properly. Be sure to give at least an 1.5" clearance on all sides.
2) Power - The parts inside of a printer are all rated to operate using certain voltages. That being the case, you need to use unregulated power (i.e. - wall outlet) to make sure the parts are given as much (and only as much) power as necessary to operate. Using powerstrips rated at different voltages can create either not enough or too much power which could mean the fuser operates at too low or too high of temperatures.
3) Media - Make sure the paper you're using is rated properly for the printer. Most printers accept a certain paper weight (found in the owners manual). Contact Dell if you've misplaced this.
4) This particular printer isn't rated for too high a speed, which means the fuser shouldn't have to run as hot. If you still get overheat messages, you could try updating the firmware on the printer at support.dell.com or even contact their technical support.
Posted on May 29, 2009
Dell 1600n. I have to reset the printer constantly.
Do a hard reset of printer to erase all memories. Then also uninstall and reinstall the driver and see what happens. Also make sure that you are using the correct driver for your OS
Sep 12, 2017 | Dell 1600n All-In-One Laser Printer
Document failed to print" message
Hi go into settings on you're printer & clear the pending queue it will not print till u delete them ..cheers
Jan 18, 2018 | Dell 1600n All-In-One Laser Printer
Mac user can't scan on Dell MFP 1600n
That's because you can't scan over wireless. In order to scan, you need to be connected via USB, so I hope you've got a MacBook...
Jul 24, 2009 | Dell 1600n All-In-One Laser Printer
Prints faint copies
If the print rubs off the page, this means the toner is not being fused to the page. Fused......this is done by the fuser. This would have nothing to do with light print.
The dell (1600n and 1815n /1815dn) printer drivers has a toner saver mode, which can contribute to light print.
To turn Toner Save Mode off, (Windows XP) perform the following steps:
  1. Click the Start button, click Settings, and then click Printer and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser MFP 1600n, 1815dn, and left-click Printing Preferences.
    The Dell Laser MFP 1600n, 1815dn Printing Preferences window appears.
  3. Click the Advanced button.
    The Dell Laser MFP 1600n, 1815dn Advanced Options window appears.
  4. Click to highlight Toner Save.
  5. Click the drop-down list and change it to Off and click OK.
  6. Click OK.
One thing that you mentioned in your post "it takes the printer forever to warm up". The fuser does have to reach operational temperature in order for it to fuse the toner to the page. So it is possible that you are having fuser problems, because of the time it is taking for it to warm up. Another thing that can contribute to the warm up time is not plugging the laser printer directly into a wall outlet. This would be true for any laser printer, not just a Dell laser printer. The low voltage power supply is what works the fuser, along with sensors and other motors in the printer.
Replacing the fuser and or the low voltage power supply in this model of printer is not an easy task. If using a Dell branded toner cartridge and checking the toner saver mode does not fix the issue. Then you would be looking at more expense then the machine would possibly be worth.
May 04, 2009 | Dell 1600n All-In-One Laser Printer
Dell 1600N fuser replacement
1. Power Printer off and disconnect power cord.
2. Remove back cover.
3. Remove rightside cover
3. Disconnect the thermistor cable from the controller card. (rightside)
4. Disconnect the power cable from the power board. (bottom back of the printer)
5. Remove the 4 screws securing the Fuser assembly to the chassis.
6. Pull fuser out towards you.
7. Reverse the previous steps to replace the fuser.
Apr 23, 2009 | Dell 1600n All-In-One Laser Printer
1600n Printing an Extra Page everytime...
I had a computer experiencing the same problem.
I found under the printer properties that there was 2 drivers listed; both say "Dell Laser MFP 1600n PCL 6"
I swtiched the settings from one to the other.
The Printing Preferences also show more options.
  • Open the Printer(Control Panel->Printers>Dell MFP 1600n)
  • On the menu at the top click Printer->Properties
  • Click the tab at the top Labeled Advanced
  • Change the driver and Click Apply
This should fix your problem.
Nov 08, 2008 | Dell 1600n All-In-One Laser Printer
"Toner Low" message = no faxes :(
Need to do a hard reset. Contact Dell for instructions, but it will involve turning printer off, opening front cover, pushing buttons on front panel in certain sequence, etc. Each model differs, which is why you should call Dell.
Mar 20, 2008 | Dell 1600n All-In-One Laser Printer
Printer Problem
Clean the small glass strip on the left side of the scanner. There is probably some dirt there and will only show up when using the ADF.
Nov 15, 2007 | Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Laser Printer Logo
97 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
