Question about Hotpoint UY46 Style Line Stainless Steel Electric Double Oven
Main oven not working
I was using the oven and it trippd.  I flipped the switch and the hob worked but the main oven is not heating (top oven is working), the light and fan are working.
  • 5 more comments
  • Anonymous Nov 05, 2007
    Exactly the same problem. It tripped, the conventional oven is working on top and bottom, fan is working on main oven but no heat coming out. Is this the element?
  • Lisalou63 Nov 21, 2007
    I have exactly the same problem on my Belling oven - it tripped - top oven working, fan and light in bottom oven working but no heat???? Any ideas?
  • Stripey Feb 16, 2008
    Exactly the same problem here - again, it happend after tripping the electrics. How did you guys solve it?
  • Dorothy Galbraith Jun 21, 2008
    can I replace the element in the bottom oven myself?
  • Anonymous Oct 05, 2008
    my hotpoint oven does not heat . shows the letter A .
  • Anonymous Mar 16, 2014
    fan & light working fine
  • Anonymous Mar 25, 2014
    connecting main power supply to the oven which automatically supply hob through adapter
Element needs replacing
Posted on Mar 14, 2008
Why does my premier double gas oven not supply gas to main oven and heat, striker works and clicks but no gas, top oven and hob working ?
Nov 14, 2014 | Ovens
Fuse keeps tripping
tripping a circuit breaker indicates a dead short or insulation failure
not being able to move the main switch indicates that the contacts inside are burnt together
only option is to call an accredited electrician to test the circuits and rectify the fault
tell him to bring spare elements is case on e or both have burnt out
Mar 27, 2017 | New World Ovens
The top oven of our AEG D5701-4 is slow to heat.
Hi it could be the element on the grill it maybe burning out, what slows the grill to get hot quicker. best to turn of the mains or by the main switch. and get a toorch to check around the element or use a continental reader check if it is receving 240volts
Mar 09, 2010 | AEG D5701-4 Electric Double Oven
Faulty main oven
If the fan is working in the oven, and it is electrically heated, then it will be a faulty oven element.
This is located at the rear of the oven behind a removeable cover.
Feb 10, 2010 | Zanussi Ovens
Fan in main oven boken
Sounds as if your oven heating element has failed. You need to fit a new one.
Usually you have to get the back off, disconnect the old element, remove the fixxing screws and element, fit new one, reconnect and it should be fixed. Don't forget to switch the power off before starting work.
Dec 31, 2009 | Zanussi Ovens
I have replaced a Kelvinator hob with a ceramic hob. It works but the owen is not working. What is the problem?
There are possibly a number of options. It could be that in wiring the hob in you have disturbed the wiring for the oven. Normally the oven works off the main oven control switch on the panel and the hob could be wired into something else.
Is the oven totally dead no power at all for everything, or is the clock running but the oven will not switch on?
Dec 29, 2009 | Stoves 720EF Electric Double Oven
Diplomat Softline ADP0300 Gas-just not cooking ...anything!
Hi there..
I Just recently had the same problem, also with a diplomat gas oven..
The problem I found was down to a small resetable component under the main cover. ..
It took me ages to find the problem and I had taken the whole electical parts of the oven to bits before 'accidentaly' coming across this 'thermal switch' (located inside the main cover, at the top, behind the display module).. - to reset this there is a tiny red button between the connectors.. press this - and it should all be fine again... : One importnat note is that this may be tripping as a consequence of the fan not running or by my thinking not running on after the oven is switched off, leaving the casing to heat up and then trip this switch component.. - if this component is faulty it can be found in RS components or Farnell components.. look for Thermal swich manual reset part no: L100C 9082 470.
Nov 29, 2009 | Ovens
I have a zanussi buit under double oven the main oven all the lights come on but no heat. it worked yesterday well top oven works and so does gas hob
If it is an electric oven and fan assisted, and the fan is working o/k, then you need to fit a new oven element, located behind plate at rear of oven.
Please rate my solution.
Nov 12, 2009 | Ovens
Hotpoint ew83p oven has no heat
The oven fan element has failed, you need to fit a new one.
Remove inner rear panel of oven and you will see the round element at rear.Unscew screw(s) that secure element, disconnect leads, and fit new element.
Refit element cover.
Job done..
Make sure you have power off to oven before you start.
Plz rate my solution.
Jan 12, 2009 | Neff B1641 Single circotherm super...
Hotpoint UY46 Style Line Stainless Steel Electric Double Oven Logo
435 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
