GPS Logo
Posted on May 29, 2009
FURUNO GP-161-OCF NOT WORKING
I HAVE A FURUNO GP-161 OCF, IT WAS WORKING FINE, BUY NOW THE SCREEN ON THE FISHFINDER SHOWS COLORS AND IT IS SHOWING DEPTHS WRONG. IT WILL SHOW 30 FEET WHEN I AM IN 4 FEET? IS THERE A WAT TO RESET EVERYTHING?
5 Related Answers
Anonymous
  • 113 Answers
  • Posted on Mar 17, 2008
SOURCE: Lowrance LCX-19C GPS Receiver Problem
It sounds like you may have to send it out for service, but before you you do there are a few things you can try.
Low voltage can cause erratic behavior. Since you already wired directly to the battery, check the plug for corrosion.
Try unplugging the transducer cable to see if the display still behaves erratically. You wont see depth readings but you should still see the screen going black. If no erratic behavior with transducer unplugged then problem is in the transducer cable or the plug. A common source of failure is at the plug because the added stress of plugging and unplugging cables can cause the socket to twist slightly which can cause a short.
Make sure you have the latest software update.
How to see if your LCX-19C is already using version 1.8.0 software:
  1. Press the MENU button twice on your LCX-19C.
  2. Select SYSTEM SETUP.
  3. Select SOFTWARE INFORMATION.
  4. The software version for your unit is located under the line that says "LCX-19C" (ex. "Version 1.8.0").
  5. If your version is the same version listed above, there is no need to download the software.
If it is lower than 1.8.0 you can download the update from this link: LCX-19C UPDATE
Copy it onto a blank MMC card and install it in your GPS. The GPS should prompt you on how to install the update.
If you need to send the unit in for service click this link: LOWRANCE SERVICE
A
Anonymous
  • Posted on May 07, 2008
SOURCE: eTrex Vista shows incorrect date
Thanks for the great advice. My problem is fixed!! Yay!
Anonymous
  • 4 Answers
  • Posted on Jul 03, 2008
SOURCE: wrong elevation showing garmin etrex vista
Found a fix, by resetting all user data my problem was fixed.
Garmin Edge 305 Power off device and hold 'mode + power'
eTrex Vista Power off device and then hold 'page + enter + power'
Hope this helps!
Anonymous
  • Posted on Jul 21, 2009
SOURCE: problem with navman 4150 fish finder
I installed my Navman 4150 depth finder along with the Navman GPS unit when I purchased my Bayliner Trophy 20Ft. Offshore model. Everything was ok for one year and it has been downhill since then. Losing signal, unbelievable high depth ranges, blank periods, etc.. I now can't even get a reading tieded up at the dock. I am now giving up and shoping for a quality unit.. Cape Disappointment.........
Anonymous
  • Posted on Jul 22, 2009
SOURCE: Eagle 640c Fish Finder dosen't read corectly.
I had the same problem and got the transducer changed. It now works perfectly. That could be the problem you are having... bad transducer.
Nav net 3 fish finder screen is is not showing the bottom
The NavNet 3D has a sonar module such as DFF1 or DFF3 or DFF1UHD. This is the fishfinder and may lack power. Also, your transducer could be failed with this indication.
My Furuno gp1650wf chartplotter is showing the wrong speed in knots. It shows 20 knots when we are doing 28 knots. At an estimated 42 knots it says 32 knots. I have cleaned the GPS plug and the gps...
Congratulations the device is within functionality. As a matter of fact devices without shark lense are least impactful. For example, the device may least capture images or receive data in realtime however provides accurate flight resources.
INSTALLATION MANUAL FURUNO FCV-585 BEST GROUND FOR THE UNIT SHOULD I GROUND IT TO ENGINE OR BELLHOUSING OF OUTDRIVE
Attach to engine grounding point with battery cable. Add a grounding plate for RF (green) ground.
Manual
http://www.mapsunique.com/ev/special-inst/furuno-30.htm
Here is a site that knows something about it. and to find where to buy one google it.
Furuno 4100 depth sounder shows depth twice what it really is
check your gain setting try auto gain and try manually gaining back to see if it resolves, if yes, send unit in to furuno, if no, ducer is probably at fault.
How do you activate the fishfinder for the furuno 1650 WF
pressing the "SNDR" button activates the sounder press"ALARM" tyo acces alarm menu, turn them on or off there, look "NEXT PAGE" for alarm 2 847-746-0100
Furuno GP 30-35 GPS
je viens de prendre possession d'un gps furuno 30/35 Jje n'arrive pas a afficher ma route pour allaer d un point a un autre merci de m'aider
Top Furuno GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Furuno GPS Expert? Answer questions, earn points and help others
