Question about Ricoh Aficio 1027 All-In-One Laser Printer
Service Code SC 542
I have a Rocoh Aficio 1027 that is giving me a service code SC 542. Nothing will work. Can you tell me what this service code is for and do you think it can be fixed without a service call as the printer no longer has a contract. Thanks.
  • paul_kellett Jul 24, 2009
    Can a fuser code be reset or would it usually required replacing a part? I know how to enter service mode but do not know how to clear it to start printing again.
  • 95 Answers
That is fuser code and needs to be reset in the service mode, it will not go away by turning the off and back on.
Posted on May 29, 2009
How to make reset for sc 542 for richo aficio 410 printer
That code requires going into the SP (Service Protocol) mode. If you have the service manual, it will tell you which buttons to press to enter it and to exit service mode. Once you enter service mode, power down the printer. If that doesn't reset, you have to go back into service mode, go the the SC/Fuser reset SP and once executed, power down then restart. Hint: you have to go to "SERVICE" then 1 will display. Press the right arrow key until you reach "5" then press the OK button. You can then right or left arrow until you find the reset SP. Good Luck.
Oct 24, 2013 | Ricoh Aficio SP C410DN Laser Printer
Sc542
Press Clear(yellow)key then press 107 press and hold Stop/Clear(red) key more than 3 second select SP modes,open a front door,turn off the power switch,wait 2 minutes,close the front door and turn ON the copier.
SC 541-542 fuser unit thermistors or thermofuses malfunctions.
Jan 22, 2013 | Ricoh Aficio 1027 All-In-One Laser Printer
My printer ricoh aficio SP 3400SF is showing service call error code SC542. kindly help to come out of this error. \r\nvr babu
FOR RICOH AFICIO SP 3400SF follow below steps.
1. To access Service Mode, On Control Panel press following buttons one
by one immediately.
Cancel Button (Red) ---> 1 (Numeric One) ---> 0 (Numeric zero) ---> 7
(Numeric Seven) ---> Copy Button (Green)
2. In Service Menu you will find Engine reset Menu. In that you can reset
SC 545 in Fuser Reset Menu. And you can also reset SC 542.
Jun 23, 2011 | Ricoh Aficio AP3800C Laser Printer
Ricoh 1045 only one copy printed then error code sc 342 will seen
Hi, there's no sc342 listed in the service manual, and I've never seen that code in years working on these machines. Are you sure it's not a different code, like sc542?
Sep 14, 2010 | Ricoh Aficio 1027 All-In-One Laser Printer
SC543 ricoh Aficio 1027
• Fusing thermistor defective or out of position
• Fusing lamp open
• Fusing thermostat open
• Poor connection of the fusing unit
Inspect all the elements before mentioned, soon presses total clear (Yellow Key) 1 0 7 and Maintain pressed clear stop key (orange key) more tan 3 sec. Enter SP 5-810 (SC code reset),
select execute, select close. Exit SP mode, turn the main power
switch off then on.
If the problem continuous the problem can be in the Power supply board, can be defective.
Aug 10, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
My Ricoh Aficio 1027 has a fuser code SC542. Is there a way to reset this in service mode (I know how to get in) to continue printing or will I need to replace or repair a part? The copier no longer has a...
to reset it just enter service mode and cycle power. But first take out the fuser ( right side of copier 2 screws ) and check that the 2 rollers hot and pressure are touching each other no gap between them. The unit you have is a nice unit, for service to fix if replacement is required would be about 300.00 or so... -Carl
Jul 24, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Service code SC 548 on a Ricoh Aficio SPC 811dn printer, what is it and how to correct?
I have sc 548 error code also. I was following your instruction, but i couldn't enter to service mode. How do i prepare it? Please write this instruction to me step by step.
Apr 23, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Jan 17, 2009 | Ricoh Office Equipment & Supplies
Sc 542
SC 542 is a fuser code that may need resetting. and this should be only done by an qualifyed service representitive as it requiers going into service mode and going into copy sp 5-810 and having it reset or if this does not work you may need a new fuser unit! Again service mode will need to be entered to reset the SC542 as this is a safty feature built in to the copier to keep it from ferther damage
Jan 13, 2009 | Ricoh Aficio AP3800C Laser Printer
Ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Oct 23, 2007 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh Aficio 1027 All-In-One Laser Printer Logo
1,108 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
