Question about Eureka Smartvac 4870 Bagged Upright Vacuum
How to replace Handle Release Pedal
The spring is still there, just can't figure out if I should use brut force to push the pedal in or if there is a knack to it.
In my Model 4870GZ, the foot pedal came out repeatedly with great aggravation. I discovered that this is due to small, broken, inadequate, and poorly designed plastic tabs in the clear plastic housing which were intended to provide a press-fit for the mating tabs on the gray pedal component.
After removing the red cover (three screws on the underside), I was able to install a wire-strap extending from a screw on the axel mount to another screw on the front side of the pedal. Also, I drilled a through-hole in the gray pedal so that the wire would pass through the pedal and would thus connect as a "hold down" strap from the two mounting screws.
Drilling and taping holes to correct this problem is not advisable since the thickness of the brittle plastic is inadequate to support the forces delivered to the pedal.
Posted on Jan 18, 2011
I pushed it in with some force.
Posted on May 30, 2009
I need a you tube showing me how to replace the handle release. when I pick up the vacuum by the handle the vacuum head flops down
If you remove three screws you can remove the assembly with the foot pedal. Look at how it is installed closely in the assembly, including the spring, shaft and pedal. Disassemble it and install a new foot pedal exactly the same way you took it apart.
Feb 15, 2016 | Riccar 8000, 8900 Series Metal Agitator...
How do I fix the foot pedal assembly for the handle release on shark vacuums?
You should call cust service. Call may still replace it.
Aug 04, 2014 | Shark Vacuums
Install foot pedal release on riccar 8800 series
It's not hard to do but is almost impossible to explain how to do it. If you can look at one already installed on the shaft holding the pedal you can see how it's done. Visit your local Riccar dealer.
Jan 12, 2014 | Riccar Handle Release Foot Pedal - 8000...
The handle release pedal wasn't allowing the handle to lower. I took off the pedal and saw the spring load part was broken. What is this part and how to replace it? Bissell 3760-3 handle release
Order Slider Release (7.93, vacpartswarehouse) Pull off 'tank.' Remove 3 Screws for Foot Detent Lever. Pull off. Remove old slider release and spring (verify it's broke.) Replace with new. I just did this today after a year of dealing with it.
Mar 04, 2012 | Vacuums
Eureka model 4870DT plastic foot pedal for is broken
This a fairly frequent repair on the Eureka Smart Vac model 4870, so I decided to go ahead and take a few pictures of the handle release pedal repair, and walk you through this step by step. The model that I did the repair on is a slightly newer model, but other then maybe the color of the vacuum, or the color of the foot release pedal, the repair is identical. $40 is an awful lot of money to do this repair, after it's all done with you'll be very happy that you choose to post this repair on Fixya, rather then paying $40 for someone else to fix it.
What you'll need to complete this repair. The links contained in the parts are links to the parts on our website, GoVacuum if you don't already have the new pedal.
- Eureka Smart Vac Model 4870 Handle Release Pedal (colors may vary, but will fit ALL 4870 models) Eureka Part 70042-355N
- Eureka Smart Vac Model 4870 Handle Release Spring (Only needed if missing underneath of old pedal)
- Large Flat Head Screwdriver
- A small amount of elbow grease. :-)
Step 1. Remove the old handle release pedal from the base of the Eureka Smart Vac if it hasn't already fallen out of the base of the vacuum. Here's what the pedal looks like installed in the base:
The easiest way to remove the old pedal if it's still inside of the base of the machine, is to take a larger sized flat head screw driver, and put it up underneath of the pedal. With the screwdriver underneath of the pedal, pry upwards on the pedal until it pops off. This can take some pressure to get it out, don't put too much pressure on this part or it will crack the bottom housing. If the pedal won't come out from the bottom, you may also try putting the screwdriver in between the top housing (different colored plastic part in front of the pedal) and the pedal and try prying here. I find it the easiest to do when I put the screw driver underneath and pry upwards like this:
Step 2. Once you've removed the pedal from the base of the vacuum cleaner, make sure that the spring is still inside the base. The spring is a metal torsion part that pushes upwards on the pedal to keep it from always falling out of the vacuum cleaner. I have highlighted the spring in this picture in red:
Step 3. If the spring is still installed, you're now ok to put the new pedal on. You'll see on one side of the pedal that the notch that locks the machine in the upright position, as well as on the bottom part of the pedal that part of the pedal that connects into the lowest part of the base that has two little circular notches that protrude out. This part of the pedal goes on the side closest to the vacuum cleaner's upright body. There's really one way the pedal will go into the vacuum. Put the pedal over top of the metal spring, and push down on the pedal as far as it will go. I find that a few GENTLE hits with a hammer on the top of the pedal will gently slide the pedal into the correct part of the lower base:
Step 5. Test the pedal by stepping on it to make sure that the handle release when you're stepping on the pedal. Also make sure the vacuum will lay flat on the floor when you step on the pedal a second time. Now raise the handle into the upright position and make sure that the machine locks itself in the upright position. If yes, then you're all set! If it's not locking, then there may be a more serious problem of the lower base part being cracked, which will not allow the pedal to sit properly. If this is the case, please just reply to this repair, or start a new repair with that problem, and I'll be happy to show you how to fix this. If this repair was helpful to you, (it seems that it saved you $40!) please be so kind and rate my repair helpful by clicking on the 4 thumbs up icons in the top corner of the repair. I really do appreciate that. We do carry most every part for your vacuum on our website, please feel free to check out our site, Govacuum.com for all of your Eureka vacuuming needs!
Thank you,
Chris J.
GoVacuum
Apr 07, 2010 | Eureka Smart 4870DT Bagged Upright Vacuum
How do you replace Hoover Handle Release Pedal on
The handle pedal is snapped in to the base, where it pivots.
The pedal needs to be pried away fron the base, exposing the pivot pin to release it for removal. On your model, you will likelly have to remove the lower handle from the base (where it pivots) to get room to release and replace the pedal.
Mar 11, 2010 | Hoover Vacuums
Foot controlled handle release lever is broken. Where to get parts?
I had same problem - the foot release pedal would not spring into place when unit was upright (but would work if you nudged in place with your foot). I installed a replacement part, and it didn't fix the problem. I cut out a small sqare of sponge and jammed it behind the flat end of the bent plastic spring on the release pedal, and it now springs back as it shoud. Hope this helps.
Jan 11, 2010 | Hoover U6630-900 WindTunnel Bagless...
Hoover savvy handle release pedal does not retract. There does not seem to be any mechanism to force it back, is something broken or missing, like a spring?
yes the handle release pedal is broken. i have the same problem and ordering the spare as i'm writing this email
Jul 07, 2009 | Vacuums
Bissell 3595 handle release pedal spring(?) missing
I just fixed this on my Bissell PowerForce model #6594 vacuum myself. Woo Hoo for me. :-)
I called the local vacuum repair guy and he told me he'd repair it for me if I insisted but that since my machine only cost about $80 (a lot of money for me) it would not be worth the $40-$50 repair. I should just buy a new vacuum (from him I assume).
My machine works great so I sat down on the floor and after removing 5 screws and a little tinkering I got my machine apart. I had to take the brush and belt area off and then the upright part came off the base. Make sure you unplug your unit before working on it.
Next I could see where the Handle Release Pedal (HRP) on the bottom of the unit had been cracked. It's a molded piece that has a slight curve in it that allows it to spring back into position to hold the vacuum in the upright position or to keep the vacuum from going totally flat.
How it was installed I don't think they meant for it to be easily replaced but after using a screw driver on one side and a letter opener on the skinnier side I pried the molded houseing out from around the HRP just enough to let the it release. I did need a third hand for that part.
Aug 30, 2008 | Bissell 3522 PowerForce Bagged Upright...
Eureka Smartvac 4870 Bagged Upright Vacuum Logo
259 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Irene Tulloch
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
