Question about Jensen VM9410 Car DVD Player
Bypass brake wire so screen allways play I have a wm9212n Jensen system I reloaded default settings now it requires me to place the parking break to watch the dvd
Connect the red wire to the negative on your battery run it straight to it and it will always play so you don't have to pull up your e~brake
Posted on May 29, 2009
Parking break bypass axxera axv820
You can try attaching the parking brake directly to ground to bypass the issue. However, some systems require a change in voltage each time system is powered down. If this is the case, you can place a toggle switch inline with the parking brake wire, attaching one side to the wire and the other side to ground, allowing you to apply the ground and remove it when necessary.
Feb 11, 2013 | Dual Car Audio & Video
Parking brake safety bypass
If you have the old firmware then all you need to do is ground the parking brake wire
if you have the new firmware(just bought the system) a toggle switch is involved:
1 - connect e-brake wire from dvd unit to the switch
2 - connect a ground wire from switch to the unit chassis(any good metal grounding surface will do)
3 - pop in a dvd, toggle the switch back and forth 2 or 3 times depending on what wire you placed where...and voilaa!! your dvd system should work in motion!!
Jun 26, 2009 | Jensen VM9510 Car DVD Player
PARKING BRAKE DISABLE my jensen in dash doesnt want to play dvds its displays a blue screen saying something about the breaks
yes its saying in toorder to play dvd's u must engage parking brake which means the wire is suppose to be hooked up to the parking brake....BUT i know the trick to make it work where u can play dvd's and drive
May 31, 2009 | Audiovox Jensen In-Dash DVD/CD Receiver w/...
You need to run that wire directly to ground to make it think the parking brake is on.
Mar 01, 2009 | Jensen VM9410 Car DVD Player
How do i bypass the parking brake switch in order for my video to play
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On my Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Aug 25, 2008 | Dual XDVD8181 Car Video Player
Aug 23, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
DDX512 Video Playback Bypass
I grounded my Jensen to a screw inside the dash. I had to put a switch on it though - Jensen requires an on-off-on sequence with the parking brake, which applies and removes the ground. I duplicate this by throwing the switch. Check the manual or online references to see if you have to do this. If you do, you'll need a switch. If not, you can just ground the wire.
Aug 19, 2008 | Kenwood Excelon DDX-7015 Double Din Car...
Hooking up the parking brake sequence
There are no "bypass codes". Making the unit work without the handbrake is a wiring issue, and it's easy. I highly suggest doing it this way to make the player much more useable.
Aug 11, 2008 | Jensen VM9510 Car DVD Player
JENSON VM9512 CODES FOR BRAKE BYPASS
turn on the player, start the radio option, go into the setup menu, tap the language tab, ON THE REMOTE press "stop, stop, 5,4,3,2,1" This will bring up the secret menu, you do not need to connect the pink wire
Mar 10, 2008 | Audiovox VM9512 Car DVD Player
Jensen VM9410 Car DVD Player Logo
260 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
