Question about HP DeskJet 930c InkJet Printer
Printer will not print
Deskjet930c put in new hp ink cartdriges the printer fax window shows 3 icons that match my printer and are in the ready mode and when I clicck to print it shows the green bar that disappears and doesn't print anything. I have several pages pending. I have disconned the printer and restarted the computer.
  • 417 Answers
Hi Check that the cable is fully into the printer also make sure that there are not any lights on the printer that are on. Within the printer icon right hand click on it and select properties. Once in there select the ports tab at the top of the window and check that the port that is selected is the correct one i.e. LPT1 or USB or which ever the printer is connected to.
Once you have check these try clearing the print que and print a test page from the properties window. If the printer prints ok then there is nothing wrong with the printer and make sure that within the program that you are using the correct printer if not change to the correct one by Ctrl: P and then at the top of the window it should state what printer is to be used.
Hope this works for you
Thanks J
Posted on Jan 12, 2008
How do i check the ink level on my 6940 inkjet printer ?
  1. Open the Printer Toolbox . There are two ways to do this:
    • Open HP Solution Center , select Settings , and then Printer Toolbox .
    • If the HP Solution Center method does not work, open Printers and Faxes in the Windows Control Panel, then right-click the printer icon and choose Printing Preferences . Click the Features tab, and then click the Printer Services button.
  2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows otherwise. (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.
Mar 26, 2011 | HP Deskjet 6940 InkJet Printer
Bought new black ink cartridge won't print paper goes through fine white bands go across paper paper comes out with no ink on it
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Go to Printing Preferences 3. Click the Features Tab 4. At the bottom of the window you will see Printer Services or Device Services. Click on it. 5. Choose Align Printheads on the list.
Try Printing Again. I hope I was able to solve your problem. :)
Feb 03, 2011 | HP DeskJet 5650 InkJet Printer
I have a brand new HP PSC 1410 and after having to buy a black ink cartridge my printer still doesn't print in colour. The printer came with a preinstalled colour cartridge.
The product software print setting is probably designated as grayscale. Follow these steps to check this setting:
  1. In the software application you are trying to print from, click File , and then click Print . The Print dialog box opens.
  2. Make sure your printer is selected, then click Preferences . The printer Preferences dialog box opens.
  3. Select the Color tab, then make sure that the Print in grayscale option is not selected.
Step 2: Check ink levels
NOTE: If you have installed a refilled or remanufactured print cartridge, or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable.
  • Open the Printer Toolbox . There are two ways to open it:
    • Open HP Solution Center , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • If the HP Solution Center method does not work, open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and click Properties . Click Printing Preferences . Click the Services tab, then the Service This Device icon.
  • The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge might be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.
    Dec 07, 2010 | HP PSC 1410 All-In-One InkJet Printer
    Hp officejet 5610 won't show ink levels in windows 7
    fallow the steps to get inklevels in every time of printing,
    hai reader this option is not from windows Operating System its a printer manafacturer utility fallow the steps to activate it
    Start - Printers & Fax (If not available in the list go for control panel and find the printer & fax option) - select the printer proprities - select printing preferences button - their search the option and put tick to activate the show ink levels on the time of printing.
    but the softwares displayes displays the ink levels of the cartridge is approximate that is not a true.
    Aug 10, 2010 | HP Deskjet 3845 InkJet Printer
    Printer showing Offline status
    hi
  • Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer.
  • Step 2 Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open.
  • Step 3 Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
  • Jul 05, 2010 | HP DeskJet F380 All-In-One Printer
    My black ink ran out so I replaced the ink
    Hi:
    I have used the printer series that you have for years, and once in awhile, I get a new cartridge that won't immediately print. Often, there is just a bit of dried ink residue on the print head, and that won't allow the cartridge to work correctly.
    Some simple things to try are :
    1) Remove the black cartridge. and take a damp paper towel and gently swab the print head area. Next, apply some pressure to the sides of the black cartridge, until you see black ink oozing out of the print head. Repeat if needed. Once the ink starts flowing, blot off the excess, and install the cartridge.
    If you can't get ink to flow, then the cartridge might be bad. Most of them have an expiration date on the packaging.
    Mar 31, 2010 | HP DeskJet 960c InkJet Printer
    When we do a fax test, we get clear print; when we try to print documents nothing appears, altho it goes thru all the right sound motions
    Sounds like your colour cartridge is empty. Fax test will pull from black only but documents sometimes use a combination of colours in order to print out black. I suggest checking your ink levels - instructions for windows;
    Check ink levels
      • Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
      • Open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click Printing Preferences . Click the Services tab, then the Service This Device icon.
    2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low Check ink levels
    Mar 05, 2010 | HP Officejet 5610 All-In-One InkJet...
    My 8x10 photos have half a blue tint and half a yellow tint. I cleaned the heads and aligned the print cartridges and that didn't make a difference. Working with a HP2610. Thanks! Leslie
    Step 1 - Check the ink levels
    1. Open the Printer Toolbox . There are two ways to do this:Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox
      • Open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click Printing Preferences . Click the Services tab, then the Service This Device icon.The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink. Step 2 - Check the printer settings
        1. In the program being used for printing, click File , and then click Print The Print window opens.Make sure the appropriate product is selected, and then click Preferences or Properties .The Preferences/Properties window opens.Click the Printing Shortcuts tab.
        2. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .Paper size : Make sure that this option matches the paper loaded in the product.To see additional options, click the Advanced tab, and then click Advanced Features .The Advanced Features window opens. Consider changing the following option:Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
        Step 3 - Run the clean print cartridges utility
        1. Press the Setup button.Use the arrow keys to select Tools and then press the OK button.Select Clean Print Cartridge and then press OK . The device prints a test page.Examine the test page. If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for further cleaning.Open the Printer Toolbox . There are two ways to do this:
          • If the HP Director method does not work, open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click on Printing Preferences . Click the Services tab, then the Service This Device icon.
        2. The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges , then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints.
        Step 4 - Print a diagnostic page
        1. From the product control panel, press * and # simultaneously, and then release both buttons.
        2. Press 1 , 2 , and then 3 . The Service menu appears.
        3. Press the right arrow button (c01150415.jpg ) twice. The Special Reports menu opens.
        4. Press OK .
        5. Press the right arrow button (c01150415.jpg ) once. The Print Cartridge menu opens.
        6. Press OK . The diagnostic page prints.
    Jun 23, 2009 | HP Photosmart 2610 All-In-One InkJet...
    My HP 2610 defalt has changed to fax instead of print mode
    follow this trouble shooting steps your issue should resolve.
    On Computer:
    Click on Start >> Control Panel >> Printer and Faxes >>
    check which Icon is enabled if Fax is Enabled Just Disable it By right clicking on it and Disable.
    Now Right Click on Printer Icon then select " Use Printer Online"
    then set it as Default Printer.
    Now try to print your issue should resolve..
    I hope it helps ...raj 9866486995
    Raj....
    Feb 17, 2009 | HP Photosmart 2610 All-In-One InkJet...
    HP LASERJET 1100 WONT PRINT
    go to Start, Settings, Control panel, printers and faxes is your printer there? is there a checkmark? no, then right click and set as default, put your mouse over it does it say Ready? no, then change cable.
    send test page, it should print, if not the USB or Parrallel input of your printer has a problem.
    Aug 14, 2007 | HP LaserJet 1100 Printer
    HP DeskJet 930c InkJet Printer Logo
    65 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
