Cassette deck doors wont eject
I cant get the doors to eject. there is no way that i can do it manually without causing damage to the doors is it?
  • addiegrundy May 30, 2009
    I am not sure of your instructions. Are you saying to force the doors open manually? The door on the left was working until i put a tape in. the cassette that I am trying to fix is sony cassette deck tc-we6055
    Problem Solver:
  • 18 Answers
The belt that drives the mechanism is stretched and does not advance the mechanics to finish a cycle - i.e stuck in "play". Open case and manually try to rotate the capstan flywheel in the correct direction. this might free the mechanism. depending on model, you might have to leave the power on, but usually you should not apply power to unit. probably need new belt to get this unit to work again.
Posted on May 30, 2009
  • Bernard May 30, 2009
    I'm thinking that the door is stuck because the mechanism is not moving. I'll bet you can't play the tape either. As long as the tape deck is stuck trying to play the tape, the mechanism locks the eject button. You have to reach the point where the machine has accepted the "STOP" function. Then the front door can be opened.
    Inside the machine in the tape deck mechanism there is a large "thick" gray colored (aluminum) disc that has a pin in the center that goes to the front of the machine. It is called the capstan drive. Under normal operation, this pulls the tape from one side to the other by squeezing the tape between the capstan pin and the rubber wheel. This should be turned by the belt that is connected to the motor. I'm thinking you have to manually rotate this disc so that the mechanism advances the tape from the supply side to the take up side of the cassette. This should permit the mechanical parts to work and hopefully the front door lock will become unlocked. Try first without any power connected. But It may be necessary to power up the unit while you do this. Only high voltage exists near an exposed fuse or the power on switch, so be careful where you put your fingers.
There is a repetitive click when power is on...without the insertion of a cassette.. the dual deck vcr will not work
That could be caused by a damaged mechanism. When power is applied the mechanism will try to reset the deck to the eject mode if there is no tape in. But if is damaged it can't do that. What you are hearing is the mechanism trying to do something and failing.
Dec 08, 2015 | Televison & Video
Why one tape at deck A won"t come out. it stock inside unit
There are lots of causes to this. For example the mechanism has jammed. The tape has become entangled in the capstan or elsewhere. Plastic damage causing the mechanism to not move back to the eject position. Some decks have a powered eject that is faulty. Broken spring, or one that has fell off.
May 28, 2014 | Pioneer CT-W205R Single Dual Cassette Deck
Tape deck wont play only makes noise
The drive system is not functioning. Could be belts
Oct 19, 2012 | Sony Audio Players & Recorders
A cassette has jammed close the A door of my Sony TC WE675. How do I clear the jam? The tape is probably keeping the door closed.
Please click HERE so that you will be directed to the site where you can troubleshoot the issue.
I hope that this will work for you.
Aug 08, 2011 | Sony TC-WE675 Single Cassette Deck
Tapes stuck in the cassette and dooes wont eject on both sides
I hate to say this but you may have wrapped the spook around the player inside. I have not had much luck opening jammed doors that result from spooled up tapes.
Richard
May 31, 2009 | Sony Audio Players & Recorders
Tape will not turn
The more detailed the description of the problem, the better for diagnosing the root cause. Thanks.
It sounds like you have a couple of problems. I'll address them as you have them numbered above.
1. Decks typically have belts to drive the various 'reel' mechanisms. Therefore, they can slip without breaking anything inside the machine or the tape. Your first symptom leads me in that direction.
2. That it migrated is mysterious, unless Sony is using a common motor to handle both decks' reel duties.
3. This symptom may have something to do with the root cause of both sides jamming...
Do the cassette well doors come off, say, for cleaning? Could they be dislodge? If so, they may have something to do with the jamming problems in # 1 and #2 as the doors play a part in positioning the cassette and holding it in place against the reel motor cogs. How do the doors operate with NO tape inserted?
Does it take excessive force to close the door only WITH a tape? make sure the tape is fully seated before closing the door. The capstans (directly below each reel cog) have to engage through the small holes at the lower edge of the cassette. They should be straight and clean. Any dirt or oxide on them will cause problems as these are what move the tape at the precise speed necessary for good playback or recording.
My hipshot recommendation, otherwise, is to look around inside the cassette wells very carefully for any foreign matter, debris, dust bunnies.
Do you maintain the deck as recommended?
Apr 02, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
CT-W602R Dual Cassette Deck- door won't open
Dear etu7diante,
The another way to release the cassette from the deck is by moving the flywheel manualy after opening the cover of the system. The system should be disconnected from the power supply. If you are able to to do this please let me know .later I can guide you to do the job.
ramesh22
Jun 09, 2008 | Audio Players & Recorders
Denon Dual Cassette Deck DRW-660 will not eject either tape. I put a tape in right side, played a bit, stopped, will not eject. I put another tape in left side, closed, cannot eject. Cannot eject either....
Some dual decks use a common drive belt. It may have become too slack (due to age) to drive mechanism. I am sure its time to change all belts in both decks. This will solve the problem
Apr 05, 2008 | Audio Players & Recorders
433 people viewed this question
 Grubhead
Grubhead
