Question about Char-Broil Advantage 463453306
Replacement of gas burners
Hello. I need instruction as to relacement of burners on charbroil gas grill Mod #463453205. Where can I obtain this?Thanks
  • 110 Answers
Hello, The model number that you gave is relatively simple to change the burners.
  1. Remove the 3 cooking grids
  2. Remove the 3 vaporizer tents
  3. Between each burner is a "pal nut" that just pushes on and will likely be destroyed when you remove it. They run a couple bucks each at Sears, part # 7000132
  4. This will release the carry over tube holding the burners down and the burners can be lifted out.
  5. Ensure that you clean out the carry over tube when you reassemble. This carries the flame from the first burner across to each of the rest of the burners when lighting them.
  6. Reassemble in the reverse order ensuring that you put the burner tubes over the burner valve tubes when reassembling.
You can find a parts listing with the parts numbers at: http://www.charbroil.com/Parts/80/Performance-Series.aspx
If this was helpful, please vote yes. Thank You!!
Posted on May 07, 2011
I had my charbroil grill for 2 yrs and I now when I turn on the propane tank and ignite, I hear hissing followed by it lighting then flames proceed to come out the front middle burners. Do I need a new...
Before buying anything, look into the burners for spider webs. The webs block gas from getting to the burner and will fire back. This is dangerous. Look carefully where the gas nozzle enters the burner tube.
Gary
Sep 04, 2011 | Char-Broil CharBroil Master Flame Gas...
#4635102 need new burner
The 4635102 model number is not a Charbroil Model Number. However, 4651330003 is accurate. And burners are available for it from Charbroil http://www.charbroil.com/Parts/529/2002--2003-Charbroil-Gas-Grills.aspx
If that doesn't work for you. You can use the same link to find one for your grill. But, you must have the correct Model Number.
Hope this helped you. Happy Grilling!!
Jul 14, 2011 | Char-Broil 465133003 Grill
How do youremove and replace a charbroil gas grill burner on model number 463268007
Here is a link to the Owners Manual for your model grill. It has the assembly instructions, so just reverse what they are and you'll be in business. As they say, "one picture is worth a thousand words."
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/463268007%20manual%20-%20english_3d4c7147-c_.pdf
Apr 03, 2011 | Char-Broil Grilling
My charbroil bbq had a metal part above the burner that has now broken and i need a new 1 do you know where i can get 1 and what the part is called
Hello, Yes, It's called a burner shield. You can go to this link and order what you need. http://www.grillparts.com/charbroil/masterflameparts.htm
You'll need to select which model series # it is and if it was made from before or after 1999, in order to bring up the correct parts list for your model. Then you can find the shield in the parts list and order it online from this parts supplier. Have a great day!
May 18, 2010 | Char-Broil CharBroil Master Flame Gas...
Where can I buy Charboil BBQ spares in the UK, in particular a burner for a Charbroil 200?
The email address sales@charbroil.co.uk does not work. I get a mail delivery failure. I have searched many times for a UK supplier and cannot find one.
Apr 11, 2010 | Char-Broil CharBroil Master Flame Gas...
How do I get the gas burner off so I can see the ignitor?
Turn off the gas at the tank. Remove the main grille wire. Looking up from the back you should see one clip on each venturi, these hold the burner on the tubes. Note the placement of the clips, to ease replacement.
The clips hook on both ends.
Remove both clips and carefully slide the burner toward the back and lift out. There's quite a jolt if you touch the ignitor while striking. Good luck. see link for charbroil replacement parts. http://www.charbroil.com/Consumer/ReplacementParts.aspx?ProductID=461
Jul 05, 2009 | Char-Broil Quickset Traditional 463761006...
Flame Shooting out the front
You clearly have a gas leak. Inspect the suspect area for loose connections like the gas delivery pipe to the burner assembly. Try to reconnect them. If there is a hole in it you can use some muffler repair adhesive but I would just get a new part. Often the company will send you free parts as a good gesture to assure encourage repeat business. Check out the links below. The second one offers free shipping.
www.charbroil.com/CharBroilWarranty
www.clagrills.com/grillparts/charbroil/charbroil-grill-parts-home.htm
Jun 20, 2009 | Char-Broil CharBroil Master Flame Gas...
Only one of four burners will light.
Hello, there is a carry over tube between the burners that looks like a burner hold down at the back of the grill. This is likely rusted closed and will need to be cleaned or replaced. The clips that hold the tube down are part # 7000132 and the tube part # is 7000280. They can be purchased directly from Char-Broil or Sears parts.
http://www.searspartsdirect.com
If you find this helpful please vote yes. Thank You!!
Apr 19, 2009 | Char-Broil Advantage 463453306
I have no even heat on my gas grill across the top
hello, lava rocks should be evenly spread apart but no real certain way i'ld check out your burners to see if there the cause of the gas supply to each burner
Mar 29, 2009 | Char-Broil CharBroil Master Flame Gas...
Char-Broil Advantage 463453306 Logo
320 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
