Question about Maytag Dryers
My Maytag dryer, about 10 years old, has no heat.
My dryer has no heat on any settings.
  • marcia_brown Jun 01, 2009
    I don't know if it solved my problem...I will have an appliance man come in and fix it . thank you for you helpful advise.
  • 6,784 Answers
For gas dryers, check the following below.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
For Electric dryers, check the following below.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Posted on May 31, 2009
40 year old maytag dryer
You need to replace the temperature control rheostat, which I doubt is available.
Sep 22, 2016 | Maytag Dryers
Dryer was working fine. It's between 5 and 10 years old. Suddenly stopped heating. Model #HYG3658AWW Rev 14
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 06, 2011 | Maytag HYG3658AW Gas Dryer
I have Maytag Neptune dryer. It is not heating when drying the clothes. It is about 10 years old
the most common problem if its electric is the heating element the secound most common problem is the fusable link if the fuse link to the relay has not blown then replace the heating coil
Sep 21, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer won't heat up! It tumbles fine, but no heat! My Maytag dryer is only two or three years old!
This problem is normally caused by a faulty thermostat and or heating element. Test and replace if needed
Sep 23, 2009 | Maytag Dryers
Maytag dryer does not heat.
If the dryer comes on but doesn't heat, it is probably the heating element. If the dryer doesn't come on at all, it most likely is the dryer's motor.
Sep 18, 2009 | Maytag Dryers
Maytag SD-8 about 10 years old. Making clunking
The reason to this problem is due to the bearing.
Sep 02, 2009 | Maytag PYE2300AY Electric Dryer
Maytag dryer not starting
You must replace the hi limit thermostat and the thermal fuse.
They come as a set and must both be replaced.
They are located on the heating element.
Feb 21, 2009 | Maytag PYE2300AY Electric Dryer
Maytag PYE3300AYW Elec Dryer Runs, But No Heat
hello kellygubser,
If you are sure the thermal switch is ok.. have you checked the high temp ( bi metal snap switch) too? Here is a link to the wiring diagram of your dryer. You can see that there are a few other temp switches in circuit of the heating element that would disble it.. Hope this helps
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Jan 06, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
134 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
