Question about Apple iBook G4 (Z0AZW13397068) PC Notebook
Ibook g4 - screen will not appear
The screen on my ibook will not come up. The computer turns on and the keyboard is functional, but the screen is blank.
I have restarted the computer but this has not fixed the issue.
    Novelist:
    Champion:
  • 382 Answers
Try adjusting the monitor brightness (F2). If you have an extra monitor, try connecting the mini VGA to see if it outputs a signal extenally. The videocard is onboard the logicboard....so, that is one way to process of eliminate.
Also, if you start the machine after the apple chime, hold down the OPTION key. This will prompt you as to which bootable volume to boot from. What this does though, is gives the monitor a signal before the operating system loads.....this usually eliminates the issue being software, but very seldom is no display a software issue.....
Hope this helps.
Posted on Oct 22, 2007
Turn keyboard light
your keyboard should have an icon on one of the keys that you have to hold down with either a function, or control key
Sep 01, 2013 | Apple iBook G4 1.2GHz 12" w/ Combo Drive...
My ibook g4 won't power up but the power cord works,do i need a new battery?
I found this page at apple support about your problem, it seems to have helped a lot for many people. Apple Support
Mar 28, 2012 | Apple iBook 12 iBook G4 1.33GHz,...
I have a cd stuck in my laptop computer. It's a iBook G4. The cd tray doesn't come out. there is a mechanism that helps to push the cd out. I dont know the best way to get it out. Please help!! E
Option 1:
If you restart the computer and just after it restarts if you hold down the eject key on the keyboard it should eject the disc, if not I would check to see if there is a tiny hole on the disc drive that you can stick a paper clip in - not sure if the ibook will have it but worth while checking.
Option 2:
1. Restart the computer.
2. Immediately after the startup sound, press and hold the key
combination Command-Option-O-F.
Note: The Command key has the Apple icon on it.
3. Release the keys when you see a white screen that says "Welcome to
Open Firmware."
4. At the prompt, type: eject cd
5. Press Return, then wait a few seconds. The disc drive should eject any disc that is present, and "ok" appears behind your command when the
action is complete.
6. Type: mac-boot
7. Press Return.
Dec 30, 2010 | Apple iBook G4 Mac Notebook
G4 iBook screen fades to black on start-up
It sounds like that key is sticking.
You might want to look on eBay for a replacement keyboard. I'm not sure how difficult it would be to unplug the old keyboard and plug in the new. Opening the iBooks is a challenge, but maybe the keyboard can be plugged in through the hole in the top. Not sure.
Please rate me if this helps.
Bot
Jul 06, 2010 | Apple iBook G4 Mac Notebook
Ibook g4 screen issue
That screen will most likely be compatible - I work on these for a living. The G3 laptop screens are usually not compatible with the G4 laptops, but all G4 laptop screens are compatible with eachother (provided they are the same size, of course.
Nov 10, 2009 | Computers & Internet
Ibook display problem
You can reset the pmu this might help to stable the display,this is only used as a last resort and not a possible solution.
  1. If the computer is on, turn it off.
  2. Reset the power manager by simultaneously pressing and then releasing Shift-Control-Option-Power on the keyboard. Do not press the fn (Function) key while using this combination of keystrokes.
  3. Wait 5 seconds.
  4. Press the Power button to restart the iBook computer.
Oct 07, 2009 | Apple iBook G4 Mac Notebook
I turn on my mac and only this small folder icon appears in the middle of the screen
The face is probably frowning.  The computer cannot find the operating system.  Use a utility disk to boot up the computer and then use First Aid or Disk Utility to check the disk.  You may have to re-install the operating system.  This can be done without losing your files if done correctly.  Seek help from an Apple repair facility if you are in doubt about how to do it.
May 20, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Apple iBook G4 Track Pad (Mouse) not funtioning
I think the first thing you should do is make all updates. I know that in some versions of the iBook G4, the trackpad does not work after installing OS X 10.4 (Tiger) before you do the updates. Update your OS X first. secondly, does the button work? Does the trackpad show up in the System Preferences menu? (under keyboard and mouse). It's very unlikely that the trackpad came unhooked unless someone has opened up your computer. If they have, there is a really good chance that they didn't plug it back in, because it's a hassle and easy to forget.
Apr 10, 2009 | Apple iBook Mac Notebook
Battery for iBook 14inch not recognized by iBook
you could try resetting your pram..?
Resetting PRAM and NVRAM
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Your computer's PRAM and the NVRAM are reset to the default values. The clock settings may be reset to a default date on some models.
Resetting PMU on PowerBook or iBook computers In some troubleshooting situations, if resetting PRAM does not resolve an issue, resetting the PMU may be the next appropriate step. For information on when this is appropriate and for instructions on how to reset the PMU in your PowerBook computer, see Resetting PowerBook and iBook Power Management Unit (PMU).
Mar 20, 2009 | Battery Technology for Apple iBook 14in
My iBook G4 continues to run slowly and/or freeze
Try resetting the PRAM by turning on the iBook then holding option + command + P + R and wait till u hear another chime. If it still freezes, it may indicate an application may be causing it to lock up hold shift after you hear the chime to boot OS X into safe boot.
Mar 18, 2009 | Apple iBook G4 Mac Notebook
Computers & Internet Logo
161 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
