Question about Nikon Speedlight SB-800 TTL Flash
Shows STBY
For some reason the flash indicator keeps showing STBY
  • 77 Answers
STBY means 'Standby'. This is to conserve the batteries. It will come out of standby mode as soon as you press the shutter release button halfway down.
Posted on Jun 14, 2009
How to fix problem with power supply sony klv 32EX400 ,showing only 3.3v stby
Please specified problem,Check BackLight Inverter Board look for any burnout component,then look power supply,generally Power supply shows only 3.3 or 5v in standby condition,after initialize by control engine you may able to check several power rails.
May 13, 2014 | Sony Bravia KDL-32V4000 32 in. LCD TV
Lights keep flashing
After you connect the AC adapter the display shows Set Clock for 60 seconds and all of the extension indicators flash until you assign the extension number of your unit.
Even if you do not use the intercom, assign the number otherwise all of the extension indicators will continue flashing.
Manual here
Nov 06, 2013 | Panasonic KX-TS3282 Two-line Corded Phone
The screen keeps flashing on and off.it shows the wallpaper picture for about 7 or 8 seconds then goes off for about the same time.it repeats this constantly when in a low reception area and randomly at...
This is apparently an indication that an application is running. I found that Messenger was running for some reason (I never use it) & once I turned it off, the flashing stopped. Check for running applications.
Dec 19, 2010 | Sony Ericsson Zylo Cell Phone
My SB600 is on, shows "ready" but won't fire... the STBY shows on even when not connected to the camera. Will not fire. Any ideas?
Aug 17, 2010 | Nikon Speedlight SB-600 TTL Flash
My walkie talkies will not charge wheni place them on my charger, whywont it work
If neither of them work, then that would suggest something common to both... the Charger? Are you sure it is OK? Is it making good connection, give them a clean/scrape. Otherwise it could be dicky batteries, they go faulty all the time & for no apparent good reason.
Feb 09, 2010 | Cobra Electronics CXT85 Two Way Radio
The battery indicator on my laptop keeps flashing unusually
Try to upgrade the bios you can download it on the support site of dell which is www.support.dell.com
ERNZ
Feb 05, 2010 | Dell Latitude D510 Notebook
I try to turn it on but it just blinks on stand by
Probable Lamp. If lamp hasn't bown the red Lamp Lite won't flash but other lamp issues cause stby timer light to continue flashing. If stby red lite is flashing, count the no. of times flashing - could open thermal fuse (6X flashing)
Nov 27, 2009 | Sony KDF-E42A10 42 in. LCD Television
Yeah, I have the HL-5250DN printer. The light
Hi there -
The reason the drum light keeps flashing is that you have to "reset" the machine after you've installed a new drum. To do this, I believe all you have to do is make sure the printer is on and then push and hold down the "GO" button a few seconds and then the flashing will stop. This will "reset" the printer to recognize you've installed a new drum. I'm going from memory on that, but I believe that's correct. It's a really simple solution. Good luck!
May 15, 2009 | Brother HL 5250DN Laser Printer
Panasonic lumixDMC-FX7 camera
Could be either. If on switch on again the indicator is full and you get more work done then its a camera fault. If when you switch on again the battery remains flat then this could be the camera fault too the flash capacitor showing signs of distress. On the other hansd the battery could be nearing the end it useful life. How much is a new battery?
Aug 29, 2007 | Panasonic Lumix DMC-FX7 Digital Camera
Nikon Speedlight SB-800 TTL Flash Logo
136 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
