Question about Brother HL-2030 Laser Printer
Printer light is on even when paper is in machine and wont print
My paper light is on even when there is paper in the machine. I made sure all doors are closed properly and checked in the machine for paper and found none. Please advise, thanks
  • suzannemunn4 May 29, 2009
    there is no paper jam at all, what else can i check?
  • 133 Answers
Did you check the back cover for paper jam?
Still have some paper jam in your machine.
Be sure you openned all cover, paper tray and pull out the drum to check.
Posted on May 29, 2009
  • Yuk-Wa Chan Jun 01, 2009
    Now, Please hold on the start buttom for 1 min to reset the machine.
My dcp165c printer print quality prints black & yellow colour. i clean print head through maintance 76 but problem cannot be solved
How is the printer printing black and yellow color? Is it a smudge?
When I print, the pages are smudged with ink. What should I do?
Description:
- If smudged stains appear at the top center of the printed page:
  • Make sure the paper is not too thick or curled.
    Also, verify that the appropriate paper is being used and that the paper type set in the machine matches the media used.
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pages settings.
- If smudged stains appear at the right or left corner of the printed page:
- If smudged stains appear on the reverse side or at the bottom of the page:
NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
  • Make sure the printer platen is not dirty with ink.
    How to clean the machine's printer platen
    1. Unplug the machine from the AC power outlet.
    2. Lift the scanner cover until it locks securely in the open position.
    3. Clean the machine's printer platen(1) and the area around it, wiping off any scattered ink with a soft, dry, lint-free cloth.
    4. Close the scanner cover.
  • Make sure you are using Genuine Brother Innobella™ Ink.
    > Brother Genuine Supplies information
  • Make sure you are using the paper support flap.
    To use the paper support flap, pull out the paper support (1) until it clicks and unfold the paper support flap(2).
Aug 03, 2010 | Brother Computers & Internet
The documents are faded even after putting in a new cartridge
  • make sure you are using inkjet papers as inkjet printers work on inkjet papers.
  • Lift the printer access door, then remove the ink cartridges from the printhead.
  • Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  • Close the printer access door.
  • Reprint the picture or document that had the quality problem.
  • if still light prints then proceed further
  • Print Test Page
  • Review the printed test page and verify that:
    • the left color blocks are gray, cyan, and black.
    • the right color blocks are magenta, yellow, and black.
    • each block is completely filled with color.
  • If no---> Clean Printhead, the On/Off light flashes during the cleaning procedure.When the On/Off light glows steady, print test page again.
  • If Yes---->The problem could be caused by the type of paper you are using.
May 28, 2010 | Kodak Office Equipment & Supplies
I have a compaq ij650 series printer both lights are vlinking and wont print it means paper jam but there is not paper in the printer
Make sure you check up in the rollers for paper. Even a small piece of paper will cause the light to be on. If nothing found you may have to reset printer to clear error.
Sep 29, 2009 | Compaq Inkjet IJ600 Printer
Flashing yellow light not allowing me to print
just put in new cartridges in paper full,no jams
Jul 13, 2009 | HP Deskjet D4160 InkJet Photo Printer
Light is flashing and will not print
dude..u didnt mention printer's make n model nyhow give a try to dis one..
Remove all the cartridges and the paper from the printer...Power off the printer...unplugg the power cable from the back of the printer...while printer is unplugged from the power..press n hold the power button for atleast 60 seconds then release it..open the back door of the printer and look for any paper jam...remove paper from behind (if any) and roll the rollers in upward direction from behind..close the back door and connect the power cable to the printer and power on the printer..Look for the cartridge slots and clean it wid a lynt free cloth and the copper contacts of the cartridges as well...then insert only one cartridge (black or color) and close the cartridge door and check for any blinking lights on the printer...similarily repeat it with the other cartridge..by this u wud get to know if any cartridge is faulty? If u get blinking lights on the printer ...that means there is some problem,,,
Once you see the steady green light on the power..it means the printer is ready..You can also print a test page..."Press n Hold the power button down...while holding the power button down...either press "Down Arrow button" 4 Times OR "Red X button once"...then release the Power button to print the test print..
If it prints ..u r the master !!!
Best of luck
Remember if there is any blinking light,,the printer wont prin..
if the light blinks around the drops..it means there is cartridge issue and you may even replace the cartridges..make sure u remove the pink tape carefully before inserting the cartridges.
ALL THE BEST
May 08, 2009 | HP DeskJet 930cm InkJet Printer
Canon printer has no paper stuck, but yellow light will not reset
Remove any covers and open any doors and look around real carefully with a flashlight for a piece of paper that might be in there somewhere. Get a can of compressed air and blow out the machine. Make sure a paper clip hasn't come off and fallen into the machine. Don't be afraid to turn the machine upside down and shake it.
Apr 27, 2009 | Canon PIXMA iP1600 Printer
Blinking light--won't print
Best of luck
ALL THE BEST
Mar 22, 2009 | HP Deskjet 6940 InkJet Printer
I can only receive one page each time
Make sure that the paper size set on the machine matches the paper that you have in the cassette. Also make sure that the sender is not sending legal-size documents if you are using standard size paper.
Is the machine giving any type of error message or code when the error light comes on?
May 15, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Printer Won't Take Paper
I beleive that machine has two slots to put paper, try moving the tray to the other slot, for some reason it may have defaulted to that tray.
Nov 08, 2007 | HP PSC 1315 All-In-One InkJet Printer
Model : HP LaserJet 1320
Hi, If that is the only light on (blinking or not), then you probably have a paper jam or a door open somewhere on the printer. Make sure both doors are closed securely at the back of the printer. Make sure that the toner cartridge is secured inside the printer. You not only have to just insert it, but you have to insert it until you can feel it lock into place. Make sure there is no paper jammed inside the printer or inside the rear doors. If you have a blinking light AND the power light is ON, press the GO button. This is also a sign that a complex print job was sent that max'd out the installed memory. Hope this helps!
Feb 14, 2007 | HP LaserJet 1320 Printer
Brother HL-2030 Laser Printer Logo
308 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
