Question about JVC GR-DVL300 Mini DV Digital Camcorder
Cannot import video from jvc to pc
Am unable to connect my JVC DVL300 to my Vista, I just spent 50 on a S video cable and also on a Belkin firewire, my computer said to just plug it in and the import video should run instantly, but it didn't, I have tried turning the camera on and off, plugging the cables in in different orders, nothing,
SOURCE: Problem connecting JVC GR D370U
I have JVC GR-D270 cam how I can copy my video from tap to my Laptop
Posted on Dec 22, 2007
  • 11 Answers
My camera is a JVC GRD370.
JVC seems to only work with firewire (iee1394) that uses the Texas Instrument chips.
I ended up having to buy a PCI card for my PC that specificaly had the Texas Instruments IEE1394 chip.
Worked fine after that. No special drivers, Windows XP automaticly installed the Firewire drivers for the card, and auto-detected the camera.
Posted on Apr 18, 2008
Bubbabear64
  • 2794 Answers
SOURCE: JVC GR-DVP7 - Video to PC / Firewire Cable ... where can I get one?
Best Buy has a 6 pin to 4 pin firewire cable. You will need some software as well to copy to the hard drive such as Pinnacle Studio if you don't have on already.
Once the cable is plugged in and turned on Studio will detect the camera and run the program.
Posted on Jul 04, 2008
SOURCE: driver for JVC GR-D290U
i need drivers jvc gr-d290u
Posted on Sep 24, 2008
Ciza24
  • 59 Answers
SOURCE: JVC CAMCORDER GZ-HD7U
You CAN NOT use the Firewire to capture your footage like DV or HDV camcorders. I too Have a macbook pro and use FCPS2 to edit my footage. If you want to get the footage off of the HD7u, you'll have to connect via USB2.0 and download the .TOD files and use a program to convert them. I use MPEGStreamclip. It will work with the .TOD files and convert them to a format that iMovie or FInal Cut will understand. If this is not for professional work you'll probably be fine converting the footage to the HDV standard or DV standard and not have to render in FCP to edit the footage.
Caution... MPEG2 codec may be needed. If you have FCP or have Quicktime pro, you probably already have it other wise you can purchase it from apple for $29.99 or if you try real hard (not to hard) you can probably find it on a torrent for free.
I hope this helps your situation
Ciza
Posted on Oct 29, 2008
I have got my uncle`s Mini Dv JVC GR-DVL300 EA without driver to connect to my laptop running with Vista please also advise me where/how can get a cable to connect that camera to my laptop thank you
The cable is a firwire 4-6 or 4-4 pin cable. Check your computer for the type of firewire socket it has. Most newer laptops have 4 pin.
These are available at most places that sell computer gear.
Feb 08, 2011 | JVC GR-DVL300 Mini DV Digital Camcorder
Connect JVC GR-D240ek to vista laptop
Hi and welcome to FixYa,
A firewire to USB will not work. It has to be firewire to firewire. A JVC GR-D240ek uses 4-pin, IEEE 1394 compliant Digital Video Connector [DV OUT] to connect a 1394 cable (also known as a FireWire or i.Link cable) to a laptop equipped with an equivalent IEEE 1394 port. Please note that some laptops firewire port could either be 4 pins or 6 pins.
Soon as that connection as shown above is established, you can use Windows Import Video to capture / download the videos.
Other notes (from the same Windows Help link above) :
  • You can also open Windows Import Video by using Windows Movie Maker. After you connect ... your DV camera, and your computer, start Windows Movie Maker, turn on your DV camera, put it into playback mode, and Windows Import Video should open automatically.
  • You can also open Windows Import Video by using Windows Photo Gallery. After you connect ...your DV camera, and your computer, start Windows Photo Gallery, turn on your DV camera, and put it into playback mode. In Windows Photo Gallery, click File, click Import from Camera or Scanner, click your DV camera in the list of devices, click Import, and then follow the instructions.
  • You can also open Windows Import Video by using Windows Live Photo Gallery. (This options requires you to install Windows Live on your computer.) After you connect your...your DV camera, and your computer, start Windows Live Photo Gallery, turn on your DV camera, and put it into playback mode. In Windows Live Photo Gallery, click File, click Import from a camera or scanner, click your DV camera in the list of devices, click Import, and then follow the instructions.
Verify that the laptop's firewire port is 100% up to specs and totally compliant to IEEE 1394.
God luck and thank you for using FixYa.
Jun 18, 2009 | JVC GR-D240 Mini DV Digital Camcorder
Both my sony and jvc dv cameras show no connection on movie maker windows vista....please help. Fire wire, load dif. program, help, ect.
I had this same problem, It is the cable itself, check under system properties/hardware in control panel of windows and make sure the firewire ieee is working properly also. pretty sure you need a new cable though...goodluck
Jun 15, 2009 | JVC GR-DVL300 Mini DV Digital Camcorder
Unable to export video from camcorder to PC
Get a 4-pin Firewire cable. Plugs in just below power plug slot. What plug you need on the other end depends on your computer. You can get Firewires in 4 to 4 pin; 4 to 6 pin, and 4 pin to USB. My laptop is configured to take a 4 or 6 pin Firewire but my desktop only has USB. I transfered using 4 to 4 pin and it worked great. No drivers, no discs needed...at least with Vista. As soon as I plugged in the camera, I was asked to whether I wanted to transfer from biginning of tape or at currenty location. I chose from the beginning and the camera automatically rewound and strated to transfer to the PC. I don't know if it would work same way with 4-wire Firewire to USB but assume it would. Cables around $35 but I purchased at Circuit City for the going out of business discount. I also bought some SD cards so I can take snapshots and transfer them too for print.
Get a firewire and you should be fine.
C
Jan 13, 2009 | JVC GR-D270 Mini DV Digital Camcorder
How to connect JVC GR-D820E camcorder to PC
Hi, connect the cam and PC using 4 pin firewire cable. Switch on the cam. Open Windows Movie Maker and import the video from device.
Dec 28, 2008 | JVC GR-D370 Mini DV Digital Camcorder
Record directly from jvc model GR-- D370U Digital Video Camera to my pc
Sorry, but it's not possible to record directly to a PC. Windows movie maker will only record from a tape. Please use a quality cable like Belkin, I have had issues with the cheaper firewire cords.
Good luck
Oct 07, 2008 | JVC GR D370US camcorder Mini DV
JVC Digital Still Function 32X
I'd try using a different cable to connect to the PC. The one you are using could be faulty. It does happen sometimes.
Mar 14, 2008 | JVC Digital Video Camera
JVC camera software GR-D70 for windows vista
Like most I have searched the web for drivers, preferably free ones. I emailed JVC Australia who responded with tis solution.
The camera has a connection called DV. The DV connection is used with a cable called Firewire.
Firewire is a driver less cable and will allow you to stream you video footage across from the camera to your PC.
USB is used for data transfer and need drivers, you would use this mainly to transfer still images or data files off a HDD camera.
If you use firewire and the DV connection you will stream the footage across to the PC and the PC will capture the footage as it is playing.
The firewire is about $15 and can be purchase from stores such as **** Smith, Bing Lee, Harvey Normans and Tandy. I would suggest that you take a photo of the connections on your PC as there are two types of DV connections. (4pin - 6pin)
Feb 12, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
Cannot download video to movie maker
Has anyone got a solution for this problem yet? I'm having the same issue.
Jan 14, 2008 | JVC GR-D32 Mini DV Digital Camcorder
JVC GR-DVL300 Mini DV Digital Camcorder Logo
78 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
