Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
Trimmer won't stay running without starter fluid
Trimmer won't stay start without using starting fluid.
  • 1,305 Answers
Drain any old gas/fuel mixture out of unit.
purchase new gas and mix with oil as recommended for your engine.
clean the air filter on the unit.
pull the spark plug and clean with carb spray and reinstall...
you also may need to remove the carb and clean any jets with carb spray... old gas can turn into a shellac'ish type goo and foul up the works...
I recommend draining all fuel after usage...
Posted on May 29, 2009
Troy bilt tb490bc trimmer cranks with start fluid but wont run
if it runs on starting fluid but dies after that runs out then you have a carburetor issue not supplying fuel to keep it running
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Sep 25, 2013 | Troy-Bilt Garden
My 93 toyota camry won't start without starter
Needs a tune up! Try some new plugs and wires, new air filter and fuel filter. Is it the 2.2 litre?
Apr 25, 2013 | Cars & Trucks
83 ford mustang sat for two years now won't start
The fuel system is most likely gummed up from bad gasoline, flush the entire system, replace the fuel pump and the filter as well. Add a can of CHEMTOOL to the gas tank to help dissolve the varnish.
Jul 19, 2012 | Ford Mustang Cars & Trucks
My 96 crown vic police interceptor, cranks won't start without spraying starter fluid.. the car won't start without spraying starter fluid into air intake hose to carb...
starting fluid is a thing of the past. dont use it. this car doesnt have a carb, its a throttle body/ electronic fuel injection system. you most likely have a fuel pump or fuel pressure regulator issue. test the fuel pressure, should be anywheres from 35-50 psi
Oct 11, 2011 | 1996 Ford Crown Victoria
Trimmer starts, but stall's out, and is sluggish
Get a can of starter fluid and an assistant. Start it up and spray some starter fluid into the air intake to make it run long enough to clear up the sluggishness. J.
Aug 02, 2010 | Homelite Mighty Lite Lawn Trimmer
Troy-Bilt TB70SS will not start
Hi. Go to any auto parts store and get a can of starter fluid. Have a helper squirt a little into the air cleaner while u start it up. Then continue to squirt the starter fluid to keep it running until the engine sounds good again. J.
Jul 07, 2010 | Troy Bilt Tb70ss Gas Trimmer
Have zrry30550 Ryobi Hedge Trimmer (reman.) I have good spark,good prime-up, but no fuel into the cylinder. Please help.
Hello. Get a can of starter fluid and a helper. Spray some into the air cleaner and start it up. Have your helper continue to spray a little starter fluid to keep it running for a minute or so. This will clear whatever blockage you have. Once it sounds like it is running well stop adding starter fluid and see. Joe
Jun 12, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
99 blazer wont start
need to check your fuel pressure...pump may be running , but not putting out enough pressure
Feb 07, 2009 | 1999 Chevrolet Blazer
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
414 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
