Question about Craftsman Garden
Craftsman riding mower repair starter will spin but not engage. The gear on top of the starter spins but will not lift to meet the flywheel. If I pry it up a little it will engage and start the engine. How can I fix this without buying a new starter.
  • quinn_bob May 30, 2009
    Thanks for the solution. Every place I called said bring it in and we'll replace the starter $120. + Labor $65. Kit was $19
  • 376 Answers
You need to buy a Starter Drive Kit. If you starter has a flat piece on top held on by a retaining ring, it's part # 696541. If you have the older type starter with roll pin holding the drive on, you need part # 696540. You probably have the first one. To install the retaining ring, use a 3/8 socket to tap it into the groove. Dwain
Posted on May 29, 2009
  • Dwain Pippen May 30, 2009
    WOW! Have I been undercharging! LOL. Never ceases to amaze me how some (or most) of these shops rip customers. Glad I could help. Dwain
Starter just makes a whineing sound wont engage
Sounds like the solenoid on starter is bad. A solenoid kicks the gear out to meet flywheel, If its bad the starter will spin and not engage. God-Bless!
Apr 23, 2016 | Cub Cadet LTX 1050 KW 50" 23HP Kawasaki...
Craftsman riding mower starter will spin but not engage
The keys are not dropping in the clutch fan. Lightly tap with hammer before attempting to start. Will need to replace eventually.
Dec 16, 2014 | Craftsman YT 4500 54" Kohler 26 hp Gas...
My craftsman riding lawnmower makes a whining noise and will not start
probably the starter is spinning but not engaging the fly heel, this hapens when the mechignizem that pushes the gears up to the flywheel gose out, can be fixed with a new starter.
Jun 22, 2014 | Craftsman 20 Hp 42" Deck Lawn Tractor
917256490 Craftsman Tractor 28n707 engine. When I try to start the thing that pops up to engage the flywheel ( I think that's what it's called ) just sits and spins
What your talking about is commonly called the starter drive. If the starter itself is whirling over fast enough you can probably get away with replacing just that. Available thru Sears or any small engine facility which sells parts. If you attempt the job yourself do yourself a favor and order an extra lock ring which holds the drive on the starter shaft. You'll see why when you attempt to disassemble or assemble it. There's a lot of tricks to keep your eye on them when they go flying but it's better to have 1 just in case.
Oct 29, 2013 | Craftsman Garden
Craftsman riding mower starter spins but does not engage flywheel
remove the starter and check the gear on the shaft that engages into the flywheel could need lube could be stripped
May 20, 2012 | Craftsman Garden
Starter motor spins won't engage flywheel on lawn tractor
take it off and see if the gear is broken (you can buy the gear at napa)or did the shaft the gear rides on got a little rusty over the winter
May 11, 2012 | Craftsman Garden
New starter motor and bendix. will not engage with flyweel. starter motor just spins.
Starter motor spins, but does not engage
  1. Check the starter motor for a seized or binding pinion gear.
  2. Remove the flywheel inspection plate and check for a damaged ring gear.
Nov 08, 2010 | Ford 8n,9n,2n, Tractor Starter With Drive
Starter gear doesn't move up to engage flywheel gear when started
The solenoid does two things -- it closes an electrical contact to run the starter motor, and also pulls a lever to slide the motor gear up to engage the flywheel. Since the contact is closing, the solenoid itself must be OK, but the lever could be broken, or the sliding gear could be binding or stripped. Since you're looking at a probable replacement, try cleaning with compressed air, then squirting some WD-40 into the starter gear area - you could get lucky! Otherwise, you can replace the starter/solenoid assembly -- you can find replacements on eBay for about $80. Less expensive but more time consuming is to remove the assembly, disassemble, and replace just the defective parts if you can find them. Good luck! Please rate my answer if helpful, thanks.
Jul 15, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Gear of starter motor won't engage in flywheel to run the tractor
Look under 'My Profile' (Longhorn294 in the top right corner of this page)on page 5 at this post and solution. "craftsman riding mower starter will spin but not engage". Dwain
Jun 04, 2009 | Craftsman Garden
Replacing starter
The gear / part on the starter is commonly called a "bendix" gear, and it rotates into position only when the starter switch is engaged in the "start" position. As soon as you release the switch to the "run" position, the starter' bendix gear drops down so that the engine's flywheel can spin without causing the starter to turn as well. Just re-bolt the unit back to the engine, and reconnect your battery cable.
Apr 11, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
1,080 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
