Question about Seagate 20GB TRAVAN SCSI 5 1/4 TPE DRIVE HORNET (STT320000N) Travan Tape Drive
TR-4 data cartridge
I have a TR-4 data cartridge that i need to get the data off of for a court case I am involved in. Do you do this kind of work?
0 characters
1 Points
Move error selecting tape cartridge
remove the tape manually, looks like a faulty tape, otherwise, faulty library robot, in that case:
Raise a call with IBM Hardware:
How do I create a PMR (aka Service Request) for support?
Apr 17, 2014 | IBM Magstar 3590 Magstar Tape Drive
How do i extract files from the data cartridge
open ntbackup click on Restore,click on tape cartridge , checkmark requred files and resotore it .Always select Different Destination to restore files.
Apr 04, 2012 | Tape Drives
Its capacity, speed and price?
The new HP StorageWorks LTO-5 Ultrium Tape Drives, with up to 3TB* capacity per cartridge, include HP TapeAssure which provides comprehensive information about the status, performance, utilization, and health of the tape drive and media.
s.gif » DAT Tape Drives s.gif Affordable and reliable backup for entry-level servers and workstations
dat72usb-100x70.jpg s.gif • Capacities up to 320GB of compressed data per cartridge • Proven track record for dependable backup • Remarkably low media prices contribute to a very low cost of ownership s.gif s.gif » Ultrium Tape Drives s.gif Based on LTO technology for highest capacity, performance and reliability
ultrium960-100x70.jpg s.gif • Capacities up to 3TB of compressed data per tape • Ideal for midrange and high-end servers • Investment protection through two-generation backward read compatibility and a roadmap for future generations • Choose from high-performance full-height or affordable half-height drives s.gif s.gif
Feb 28, 2011 | HP Tape Drives
Connect you usb to the usb port. go to my computer and then click 2 times on your usb external tape drive.copy all the data and paste it anywhere on the computer.Hence the drive is backed up
Jan 24, 2011 | HP StorageWorks DAT 160 USB External Tape...
Tape does not lock in, message 6 on red screen
Set for any unrecoverable write or
positioning error where isolation is
uncertain and failure could be due to
a faulty tape cartridge or to faulty
drive hardware.
clean the drive with a clean tape, change a new data tape and try again. if you recycle the drv, the alert will disappear.
Dec 02, 2010 | Dell PowerVault 110T LTO-2 Ultrium Tape...
Anytime I try to backup or copy a 33GB data file on a 40GB or 72GB Data cartridge, it requests for more data cartridge even after formatting the data cartridge prior to starting the process. Sometimes, the...
Because the DAT72 can copy 72GB with 2:1 compressed, and it's native capability is 36GB in the most. So you can try to copy less than 30GB data to it or try to enable the drive's compress mode.
Nov 26, 2010 | HP StorageWorks DAT 72 Tape Drive
Exabyte-220 Tape Library with a 8900 Mammoth drive. Tape cartridge is stuck in the drive - had a power failure during boot of the library. Can press the eject button and hear the tape rewind but the...
These drives are a right pain in the neck!
There is no easy way for an end user to remove the tapes and they are a terrible drive (certainly unless you are using a unix/linux server with all data on this server and not on another networked machine)
My suggestion would be to buy a new drive/library!
Failing that try sending the drive to who should be able to help - but these Mammoth drives are so awful they almost sent exabyte bust so i wouldnt invest too much money in keeping it going. Better to upgrade to an HP LTO4 desktop and cut your losses - Again these guys should be able to help with an upgrade
Jan 19, 2009 | Exabyte 220 MAMMOTH (2700061150) 8mm Tape
No Compatible media found in HP Tape Drive
Try a brand new tape fresh out the wrapper.
If that doesnt work make sure you are using the right drive in your backup software!
It sounds like a message often seen in windows backup where you have selected the wrong tape drive from the list and it just tells you "No compatible media found" when actually the drive listed isnt even connected to your system still
Nov 27, 2008 | HP StorageWorks Ultrium 448 LTO 2 Tape...
Remove stuck tape
It depends on the type of TD you are using. For many TDs, there is a manual eject screw, either on the bottom or side of the drive. You can usually access this screw without removing the cover or faceplate (although side mounting rails may need to come off). The manual ejection screw is usually recessed a little bit, and may even be covered by a piece of clear plastic (in the case of DDS 4-5 drives). It will also have an arrow indicating which way to turn to load or unload. There are usually standards within each seperate TD technology - but there is no standard across all tape drives - and Tandberg as a company is notorious for not having one at all. DDS 4 and 5 for instance - the screw is on the right side of the drive, near the rear, turning the screw clockwise will unload the media.
For a Tandberg LTO2 drive, there is no way to remove the media without removing the top cover and essentially rendering the drive unusable. If your drive or server is under warranty with onsite support - that would be the best option for a Tandberg LTO2 drive
Mar 26, 2008 | Tandberg Data 220LTO LTO 1 Tape Drive
Cartridge is basically a hard disk, with several platters, contained in a hard, plastic case. The cartridge contains neither the heads nor the motor for spinning the disk; both of these items are in the drive unit.
Dec 02, 2007 | Centon Electronics Certance AL810 Ultrium...
Seagate 20GB TRAVAN SCSI 5 1/4 TPE DRIVE HORNET (STT320000N) Travan Tape Drive Logo
20 people viewed this question
Top Seagate Tape Drives Experts
Level 1 Expert
Jax Planet
Jax Planet
Are you a Seagate Tape Drive Expert? Answer questions, earn points and help others
