Question about Nokia 9300 Handheld
Keyboard characters My Nokia 9300 does not type the characters that is indicated on the keys.  For example, ? is supposed to be shift / but it is actually shift 0.  I would have at least 10 keys that are not right.  Is there a fix for this?thanks
  • 490 Answers
If u want to type special signs(which are in blue colour )  then u need to Press CHR+Sign it  will work if u want to type other symbol  ($%^) then press SHIFT+ that key which u want to type($%$%$.)
Gizmo1
Posted on Oct 23, 2007
SOURCE:
Dell manuals
I have Dell N 017F9Y keyboard, which has several keys with up to 4 special characters (e.g., ;, : apostrophy and degree symbols on one key) on them. The problem is - what keys (shift/alt/Ctrl or specific combinations of these) should be used to get appropriate character. There are 6 keys with 4 characters, 6 with 3 characters. Another example is when I try to put question mark using Shift lock it gives me ( ^ ) this character. The help is urgently needed.
Thanks..Kumar
Jan 10, 2014 | Computers & Internet
Blackberry curve 9300 unlock
Hi, You can unlock your Blackberry 9300 safer and easier using unlock code. You can get the unlock code for a Blackberry 9300 either from your network provider or from any trusted vendor online. For example, You can get the unlock code for a Blackberry 9300 from www.simpleunlocking.com/blackberry-9300/rs16wp9/ at affordable cost.
UNLOCKING STEPS FOR A BLACKBERRY 9300
1 - Switch ON your Blackberry 9300 with your current network/service provider's SIM card.
2 - Using the menu go to Settings Menu -> SIM card and press select.
3 - While holding the SHIFT key, type mepd.(NOTE: You may not see any text appear on the screen while typing mepd)
4 - You should now see the five locking categories listed.
5 - While holding the SHIFT KEY, type mep2.(NOTE: You may not see any text appear on the screen while typing mep2).
6 - Release the shift key.
7 - You will now be prompted to enter the Network MEP code. (it will also state how many attempts left)
8 - Enter the Unlock Code.
9 - Enter Return/Enter.
10 - The Blackberry 9300 should then be unlocked.
Oct 28, 2012 | Motorola Mobility Defy Cell Phone
My laptop is entering more than one character at a time when typing in my password for example its adding additional letters how can i turn this off
seems like something is ring with the keyboard, try an external keyboard, if the issue is still the same this will be a windows issue, once in windows tap on the shift key 5 times this will either deactivate sticky keys or ask you to activate sticky keys.
If it is not a sticky key setting issue then the problem most likely will be Hardware, did any liquid spill on your keyboard previously causing the key to malfunction causing the key to type extra characters?
If none then possible this is a faulty keyboard on the machine.
Sep 10, 2011 | Computers & Internet
I have a Logitech keyboard+mouse wireless combo MK250. Since Day 1 I can't type few special character. For example the inverted coma" and at the rate symbol@ are interchanged i.e I have to press shift+2 to...
Look for a KeyMapper program on your system. It sounds as if some keys have been remapped on your system. If that's the case, any keyboard will exhibit the same symptoms and, of course, they work fine on other systems with no remapped keys.
May 27, 2017 | Computers & Internet
The keyboard characters does not correspond to what appears on sc
Does it type " by any chance when you press the @ key? if so this is usually because keyboard input is set to the wrong language in the regional & language settings are wrong in the control panel. try pressing the left alt key & shift at same time first this is a quick key to change between input languages.
Feb 27, 2009 | Dell Inspiron 500m Notebook
Keyboard problem
i suppose you are pressing SHIFT while you want to type@..?
Aug 19, 2008 | Compaq Armada E500 Notebook
Keyboard problem
Information about computer keyboards Now with new technology, stuck keys are no longer an issue; ... Given all the above problems
Information about the AT and PS/2 port 1, Keyboard Clock. 2, Keyboard Data. 3, Not Connected or Keyboard Reset
Device Manager information and help Users who have a keyboard with a windows key may also quickly get to the system .... CODE 2 (Second Error)
This should get ya back in to typing again/Good Luck.. Please dont for get to Vote, Thank You.
Dec 19, 2007 | Acer Aspire 3680 Laptop
Nokia 9300
U r shift key might have gone bad, u just go to nokia care and repaire it.
Sep 05, 2007 | Nokia 9300 Smartphone
Datalogic Heron D130 (Barcode Reader) Header setup
Whether or not you can set this feature depends on which interface type you are using if you are using wedge interface then the procedure is described below: The extended Header/Terminator keys for Wedge Interface users can be customized by defining them through a simple keyboard setting procedure. For example, the Numeric Keypad keys can be set for use as Headers or Terminators by substituting the default extended keys using this procedure. The type of computer or terminal must be selected before activating the keyboard setting command. Press and release a key to set it. Some characters may require more than one key pressed simultaneously during normal use (refer to the manual of your PC or terminal for keyboard use). The exact sequence must be indicated to the reader in this case pressing and releasing the different keys. Example: If one has to press the "Shift" and "4" keys simultaneously on the keyboard to transmit the character "$" to the video, to set the "$", press and release "Shift" then press and release "4". Each pressed and released key must generate an acoustic signal on the reader, otherwise repress the key. Never press more than one key at the same time, even if this corresponds to the normal use of your keyboard. Press "Backspace" to correct a wrong key entry. In this case the reader emits 2 beeps. Note: "CAPS LOCK" and "NUM LOCK" must be off before starting the keyboard setting procedure. "SHIFT" must be repressed for each character and cannot be substituted by "CAPS LOCK". Check page 31-33 of the "heron reference manual", downloadable near the bottom of this link page; http://www.datalogic.com/_vti_g2_dwnlDett.aspx?idCF=1&idC=44&rpstry=13_ Hope this helps :)
Mar 19, 2007 | Datalogic Heron D130 Handheld Barcode...
Nokia 9300 Handheld Logo
Top Nokia Computers & Internet Experts
k24674
Marvin
Marvin
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
