Question about Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television
HDMI slection not working
I have had an intermittant problem with the HDMI selection on my Toshiba 52HM84. I turn the TV on with HDMI selected and all I get is a black screen with some color flashes (the other video selections seem to be fine). Seems like if I turn the TV off, then back on again, it is OK. Any clue what may be the problem??
I contacted Toshiba and they said to turn the TV on first, then turn on the HDMI device.
Posted on May 30, 2009
Toshiba rear projection will not play one antenna channel
How To: TV Auto Program / Channel Scan - TOSHIBA FORUMS
forums.toshiba.com/t5/Televisions...Base/...Channel-Scan/ta.../345660
Aug 7, 2013 - The following article will take you through the procedure to perform achannel ... TOSHIBA television to store channels from a cable TV or TV antennasignal. ... The TV must not be connected to a cable box through the coax ... The Option 1 procedure is for TVs with menus similar to the one shown below. Understanding / Changing Inputs on your TV
Mar 9, 2012
46G300U Intermittent Flickering / Flashing / Pulsa...
Sep 22, 2011
new tv.... dolby digital not working through optic...
Sep 19, 2011
More results from forums.toshiba.com
Missing: rear
[PDF]User's Manual - Newegg.com
images10.newegg.com/User-Manual/User_Manual_24-207-007.pdf
High Definition TV broadcast, a High Definition digital cable program, or a High Definition digital satellite program). For details, please contact your TV antenna installer or your .... 14a) Item 14 does not apply to "Lamp unit replacement and ...... Thank you for purchasing this Toshiba TV, one of the most innovative DLP™ ...
Toshiba 52HM84 DLP Rear Projection Product Review and ...
? 10:43
https://www.youtube.com/watch?v=B4VRJPUmpho
Nov 3, 2012 - Uploaded by Channel 2012
In one of my very last videos before my old account was spontaneously shut down, I covered a decent 52" DLP ...
Jan 24, 2016 | Toshiba 62HM196 62" SD Television
Using the HDMI ports how do I connect a sony Blu-ray player to a Toshiba 30HFX85 tv?
Usually with the TV on and DVD off just turning on the DVD will select the HDMI output.......if that does not work then on the remote select AV and keep pressing for the HDMI output!
Feb 15, 2015 | Sony Televison & Video
How to connect sony ps3 to toshiba 32av500a
Use any HDMI cable to to this.
Connect cable to the "HDMI" port on the back of the PS3. Connect the other side of the HDMI cable to the "HDMI" port on the Toshiba TV. If the Toshiba TV has multiple HDMI ports, make note of which port you plugged the HDMI cable into.
Change the Toshiba TV to its "HDMI" video display mode. Press the "Power" button on the PS3 to turn the console on. The PS3 will automatically detect the HDMI cable. Select "Yes" to use the audio and video from the HDMI cable. Select "Yes" to have the PS3 automatically use the optimal settings for the Toshiba TV. Select "Yes" to accept the recommended resolution. Press the "X" button to save the settings
Dec 22, 2012 | Toshiba Televison & Video
My 52" Toshiba DLP just dropped an HDMI connection... There are two connectors on the back, both have worked fine until just now when one disappeared from the inputs menu on the screen.
I'm not sure about your tv model as question post shows it is Toshiba 52HM84 that has one HDMI input at rear and you said 3 HDMI inputs in your tv.
Please unplug tv from wall socket for minute or so to get it reset, replug back in, turn it On and check its HDMI inputs appear or not.
Also check for Reset option in Menu for factory default settings that can also help you to get back disappeared HDMI inputs.
If all that does not solve the issue then it seems hardware problem with HDMI circuit board and tv repairman is needed for visual check to get it fix.
Hope these info will help you.
Thanks.
Jun 04, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
Problem with Toshiba DLP Projection TV Model #52HM84
It is possible the lamps may be defective or that they may be the wrong replacement for this model, as it may have a different wattage setup with the ballast. If you want to try to order the TB25 lamp from a different vendor, you can order the original Toshiba replacement lamp for this model (52HM84) from a major Toshiba parts distributor at the link below:
Toshiba 52HM84 Replacement Part TB25 Lamp / Bulb
Apr 10, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba 52hm84 DLP-HDMI Component has been compromised?
This is a wild guess, but I believe that you are being **** by the movie industry. The HDMI protocol includes a form of DRM (Digital Rights Management) for high resolution content called: High Bandwidth Digital Content Protection Basically this means that the media (disk or broadcast) instructs the player (in your case the cable box) to insist that any downstream devices (your TV) is industry and DRM compliant. Specifically this evil protection scheme is designed to plug the analog hole and make it impossible for you to record or copy the movie by using an analog output from your TV. This even restricts the size of the TV you can play the movie on, thus preventing pubs and bars from displaying the content on big screen TVs without paying royalties. The message means that the manufacturer of your TV has refused to toe the industry line. 1984 Anyone ? Martin
Apr 24, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Black box in center of the screen?
could it possible be a problem with closed caption setting....is this a square or rectangular box how big?
Feb 15, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television Logo
271 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
