Question about Microsoft Xbox 360 Console
Scratched Xbox 360 motherboard
I'm trying to repair an Xbox 360 the only problem is it looks like someone before me whilst trying to remove the Xclamps has left a scratch. The scratch looks as though it cuts through the connection from a RAM chip to the CPU. I'm guessing its why the Xbox now wont boot up and only shows the three red lights. Is there anything I can do to repair this or is this Xbox finished. i have scratched my motherboard trying to do xclamp fix because i got 3 red lights but when i turn it on now 3 red lights appear straight away fans are working still, power supply adaptor is green can i still repair 3 red lights or is it over.
    Genius:
  • 1,019 Answers
Usually if a motherboard has been scored or damaged.
( tracks or resistors/capacitors dislodged et,c )
The board is in the Bin. ( scrap ) unless the damage can be repaired. The RROD Or red-ring of death. Is usually due to the x-clamps fitted to the console initially, by the manufacturer.
Replacing the x-clamps, with a kit ( bolts/washers thermal Compound ) And 4 x heatpads recommended. Can cure the RROD. And in my own experience the 1 red light And E74 error.
Bottom line, if the boards scratched. it,s in the Bin.
Mike @ Compurepair.
Posted on May 30, 2009
2 Suggested Answers
  • 10 Answers
SOURCE: Scratched Xbox 360 motherboard
Im sorry but this is the equivelant of a car being written off. It cant be fixed, simple as that. If it is possible to be fixed, it would work out cheaper to just buy a new one
Posted on May 20, 2009
Xbox360 seems to be scratching discs
Laser burn, looks like complete or partial circular scratches around your disc, also known as “the ring of death”. This occurs to discs when the games console has been moved whilst playing, from an upright to a horizontal position or vice versa or simply knocked against or the wires may have been just tripped upon. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but professional disc repair services is normally rerquired to restore disc laser burn damage back to "As Good As New Condition".
For further help on Xbox & Xbox 360 laser burn disc repairs or to get discs professionally repaired, visit:
www.discREPAIR.ie
You can send your discs off to this Disc Repair Service and the discs shall be sent back as good as new.
If this is happening consistently without any knocks or movement of the console, I would contact Microsoft for advice on your games console.
Jan 11, 2010 | Microsoft Xbox Console
Disk unreadable but clean disk not scratached
http://www.youtube.com/watch?v=iOmNtrStDgM
Turned on your Xbox 360 console one day and and when you try to play your game you got the message "This disc is unreadable" OR "Unplayable disc".....??
First determine whether it's a fault with the disc or not, by having a look on the disc itself & make sure it's not scratched and there are no flaws even on it, and try other game discs on your Xbox 360 console .
If your disc is scratched or have flaws try putting other discs in your Xbox 360 console just to make sure it's the disc not the actual console causing the error, If other disc are working fine, refer to the scratched discs page on our website to know what are the steps you have to follow to get it sorted out.
If the disc is not scratched and doesn't have any flaws on it, cleaning the disc and trying it once more may solve the issue, if that doesn't work try to check it by putting other discs in your Xbox 360 console, if they all work that would be definitely a fault with the disc itself and in a case like this you have the right to exchange it from the retailer you bought it from as it's not scratched.
In all cases if other game discs are giving you the same error message "This disc is unreadable" OR "Unplayable disc" you need then to contact Xbox 360 customer support to send your console to get repaired or exchanged.
Jan 03, 2010 | Microsoft Xbox Console
How to repair nba 2k9 for xbox 360
When I have problems with scratched DVD's or games, I use the scratch remover cream that goes on your disc, Leave it on for a few minutes to dry, then wipe it off with a very smooth cloth... Its about $7 or $8 I think.... Good Luck, Like I said this usually works fine for fixing scratched discs
Oct 18, 2009 | 2K Games NBA 2K9 for Xbox 360
Xbox 360 motherboard scratch.
Jeff,
Depending on where it is scratched makes the difference. But if its small scratches I think you should be fine. However any scratch on any of these platform like things can do any amount of damage.
Replacement motherboard? You could look into microsoft to see if they sell them. However even if you do obtain one you would need to find the right code to unlock it, same parts for yours. Which will get tricky. You could try here if you think you can do it by yourself: www.xbox-scene.com
Other solution: just buy a new system, they are fairly cheap.
Jun 01, 2009 | Microsoft Xbox 360 Console
May 20, 2009 | Microsoft Xbox 360 Console
Xbox 360 needs repaired
go to http://www.scratched-disc-repair.com/ this will fix any disc u need fixing and cosoles can be fixed at a very low price. i used this when i moved my xbozx whilst playing fifa 09 and they reapired the disc for just £3.95 when it had a massive scratch in it, on the website have a look around and you will find hat you need.  thsnks Alex
May 13, 2009 | Microsoft Xbox 360 Arcade
Big rings on the disc
A common problem that XBOX owners are reporting is if the console is moved during play, a whirring noise is heard and then when the disc is removed, very visible laser burn rings are found on the disc.
Laser burn, looks like complete or partial circular scratches around your disc, also known as “ring of death marks”. This occurs to discs when the games console has been moved whilst playing, from an upright to a horizontal position or vice versa or simply knocked against or the wires may have been just tripped upon. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but a professional disc repair service is usually required to repair any scratches or laser burn on discs. They can be fixed!!!
For further help on XBOX & XBOX 360 disc repairs, visit:
www.discREPAIR.ie Get Scratched Discs Repaired Back to "As Good As New Condition".
Check the “More Info” & “FAQ” Sections for further details on game disc repairs and related matters.
If this laser burn scenario is consistently happening to your game discs especially if the console has not been moved or bumped against while the discs is in play, the games console itself may require repair.
You should contact Microsoft for assessment and guidelines.
Hope this Helps!!!
Mar 27, 2009 | Microsoft Xbox 360 Elite Console
TOOTHPASTE DOSNT WORK!!! WUT WILL
Hello.
Xbox DVD-Drive's often scratch circles into your discs and some even got malfunctioning lasers that will burn rings into games.
To prevent the circular scratched from happening avoid moving your console at any time while it is running however it often also occurs just in regular use especially for older consoles with Hitachi or Samsung drives.
As far as I know Microsoft replaces discs that were clearly damaged by a console free of charge, at least here in Europe they do.
Try calling Xbox Customer Support and ask for a replacement it is worth a try for sure even if they shouldnt replace it they will at least give you a 1-month subscription for Xbox LIVE in exchange.
I hope this helps and Good luck!
Kind regards,
Wilhelm@Xboxexperts.com
Feb 21, 2009 | Microsoft Xbox 360 Console
Hello jbitwa, To determine if the scratches will have messed up you motherboard you have have to determine where the scratches are and what is scratched up. Now if you just scratched up the green motherboard (no circuits [lines cut open] and no chips [blocks]) you should be fine. But the only way to truly tell is if it will turn on when you plug everything back in. Now the processor board is small and efficient but there is still room on there for someone to scratch and still allow forgiveness.
I look forward to your post to see if it still fires up.
Nov 16, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
1,433 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
