Question about Sony PlayStation 2 (PS2) Console
Not switching on...
The red light (Power Button ) doesn't turn green when switching on,...it usually is a Fuse or a short, but the Board looks ok. to me...
  • 47 Answers
Ok, so you get the light but no power.  Try re-seating the ribbon cable to and from the power switch and on the mother board.  If you had the box open it may have been pulled loose.  If this does not work then it may be a bad switch or ribbon.  I do not think it is a fuse or the board since you are getting the red light.  You would normlly not get this if that was the case.
Posted on Oct 27, 2007
My LG 42LH30 gets red power light but wont turn green?
Fault with main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 11, 2014 | LG 42LH30 42 in. LCD TV
Hitachi hd1080
Model? what if any lights on front of set come on? If total dead unplug and look for fuse connected where power cord enters set, as much as I can suggest without more info.
Jul 20, 2013 | Televison & Video
My LG Flatron rear projection TV won't turn on. The on/off power button is not turning the TV on. There is no click sound and the red light doesn't come on. The TV is connected to mains power and ther
tried with other ac outlet doesn't work?. if still won't turn on, at this time you will need to remove the rear cover to gain access the internal part. since your tv doesn't have any power indicator, the first place to be checked will be the power supply board this is where the power connector cord is connected. now look for a blown fuse replaced with the same rating. but take note before you replaced the bad fuse you must need to have component testing in the power supply board which the cause of blown of the fuse. like shorted bridge diode, open resistance and defective mosfet or bad regulator ic.at this time you will need a device called digital tester to check weather the parts need replacement.hope this can help good luck.
Nov 02, 2012 | Televison & Video
I HAVE A 50 INCH PLASMA TV THAT WAS GIVEN TO ME WITH NO POWER PLUG OR REMOTE . I WENT AND BOUGHT A POWER PLUG ,PLUG IT IN AND NOTHING HAPPENED . DO I NEED THE REMOTE TO OPERATE THE TV ON AND OFF/
Hi
If the set doesn't power ON, what is the use with a remote control? If it power ON properly, the power indicator light at its front panel will light up. Look for this. If it doesn't, make sure that you have got a set which has to be repaired. If it does power up, just get a remote control to operate it. OK.
Jul 11, 2011 | Hitachi P50H401 50 in. Plasma HDTV
Tv will not turn on when tried on either tv or with remote green light flashes 3or 4 times then turns into red flashing light no picture or sound at all.Have tried changing batteries in the remote and fuse...
Hi.The signal lights red means the primary power of your tv is good and the signal lights green indicate the second power.If the green lights is flashing it means that they have shorted parts in the crt board.Maybe the problem is in the power section of the crt.Need for troubleshoot or repair the crt board.
Jul 03, 2011 | Panasonic Televison & Video
The LED in my motherboard is on, but if i turn on the switch, their is no response. the power connection is correct. but it doesn't work
Try swapping the power button connection with the reset button connection. Then to turn on your computer you will need to press the reset button. If that works you have a faulty power button. Otherwise try using a different PSU. One that you know works. If that doesn't help the motherboard will have to be replaced.
Jun 18, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
Bought new power supply, no difference power button will not even go on or light up ; however small green light on mother board lights up. als accidentaly disconnected the switches wiring to the mother...
The green light just show that the motherboard is getting power.
The power button of the front of the case is connected to the mother board, not to the power supply, usually in the extreme lower left corner along with the with the HDD and Reset Button cords; Power button wire are labeled and usually red/black.
If all wired correctly, possible bad or stuck power button or reset button.
Hope this helps.
Please rate this answer by check rating "Hands"
Feb 08, 2011 | E-Machines T3958 (827103050974) PC Desktop
Won't turn on power cord good
is there red light on if yes check two boards the audio board and the power supply board for any blown components ,usually first check power filter where you connect your cord in to look for bad fuse if OK then look at the power supply if there is green light there then check audio board and power board. good luck
Apr 28, 2010 | Protron PLTV3250 32 in. LCD Television
PS2 slimeline model NoSCPH-75003
i am having same problem one day worked the next day powers down as soon as powered on.....red green in a flash
Apr 01, 2008 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
