Turned computer on one day last week and the Dell E171 flat panel monitor showed nothing but vertical lines. The mouse showed as a strange assortment of colors in a small square and the screen adjustment menu comes up perfectly. None of the monitor adjustments change the vertical line problem. Any suggestions? Much obliged, Carl Perkins
    Novelist:
  • 152 Answers
Try another monitor, then change the graphics settings to lowest possible, then reboot the PC, and see if your screen works again, if it does, check the documentation for your monitor and make sure you do NOT exceed the maximum color depth / resolution for your monitor, also, make sure not to exceed the refresh rate.
if this does not fix your monitor issue, check the cables for missing pins, freyed wireing / broken insulation.
Again, if this doesn't fix your problem, try the monitor on another PC, and if still a no-go, you may have a damaged inverter board in your monitor, or other componant / wire based issue.
If another monitor doesn't work on your computer, try swapping the graphics card out, it could very well be a dieing graphics card.
Posted on May 29, 2009
Dell Ultrasharp 2407 monitor - Vertical lines
most likely capacitor problem as these caps only have a 25000-40000 hour life span. when you do replaace the monitor , turn it off when not at the computer. even though it goes into sleep mode there is still a current running through the unit cuz if you move the mouse or hit button on keyboard display wakes up. I know this because I have done boad level repair on panels
Feb 04, 2013 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
I have this GREEN LINE vertically on my DELL LCD MONITOR E176FP 17
c5e83efa-55e9-4b06-8023-89ff1e5850bd.pngDoes it look anything like this? I'm no computer guy at all, but I had that issue with my Dell laptop and the line disappeared completely. How? After watching that bright green line getting Ionger and longer every day I stopped using my laptop for one whole week due to the holidays. After that first week I turned it on to check some random file and to my surprise, the line was a lot smaller and disperse. I had this 2 week long trip the following week so I decided leaving my laptop at home to see if the line kept getting smaller. When I got home from my trip I turned on my laptop hoping the line were actually reduced, and it was completely gone, completely and absolutely gone. I would recommend you to stop using your lptop for 3 weeks or so. Good luck
Jan 03, 2012 | Dell E176FP 17" LCD Monitor
Vertical lines accross the screen
Vertical lines running down the screen is indicative of a data failure to the screen itself, which means either the screen is starting to fail or the data being transmitted through the data cable is being interferred with. Put a hand on either side of the monitor and give the monitor a light twist....does the line disappear? or do more lines appear...in either case, there is a problem where the data cable attaches to the lcd panel itself. You can try to change out cables, if that doesn't correct it, then the panel may have to be replaced. If you have the option of trying the computer on another monitor that would be the first step in seeing where the problem lies.
May 24, 2010 | Dell 1703FPs 17" TFT LCD Flat Panel...
Monitor won't come back from "sleep" setting.
Yes it can be, try it on other PC first to narrow down the problem.
Most problems in the Dell are failed transistors, poor solder works, see pictures here for guide: http://s807.photobucket.com/home/budm/allalbums
Post back what you find.
Apr 03, 2010 | Dell E152FP 15" Flat Panel LCD Monitor
Colored vertical lines on monitor
Have you unplugged the power cord to the LCD? Let it sit for a minute, then try it. ALWAYS buy a UPS and plug any computer devices into it. Doesn't have to be big, a $50 unit will protect it from dangerous voltage surges.
Jul 24, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
White vertical lines on both monitors
You can download the latest drivers for the video card.Your co-worker does she have the same syatem as yours?When you download the lastst drivers.Un-install the installed one from your machine.Reboot your computer and install the drivers you downloaded.
Good luck
Apr 02, 2009 | Dell E178WFP 17 in. Flat Panel LCD Monitor...
Vertical gray stripe on left edge, all pics and text gave a blur
any vertical or horizontal line (any color any size) showing stable on the screen that is the hardware damage at the LCD panel back board ( call panel driver board) . it repair complicate but easy to do change LCD panel (common parts). you need find a PC service dealer to do so.
Feb 07, 2009 | Dell E207WFP LCD Monitor
Sceptre X20G Naga III showing horizontal and vertical lines
Hi...there,
Yeah, there it... It's called a AD board. It that piece of component were you plugged your VGA or DVI cables to it. Panel scratchs repair kits, not recommended. Beside your panel could be already damaged by this problems you had. Replacing the AD board gonna cost you though...any where from $70.00 or more... My recommendation, just get a new one...saved you the headached and $$$.
Have a nice day!
May 02, 2007 | Sceptre X20g-Naga III 20.1" LCD Monitor
Strange problem
unplug the monitor from the vga , does the osd test come up ,
if not then the circuit is the issue,
if it does then you may have the refresh set too high.
Oct 24, 2006 | Dell E171FPb 17" Flat Panel LCD Monitor
Computers & Internet Logo
114 people viewed this question
David Payne
David Payne
