Question about Motorola Mobility RAZR V3
Razor phone my phone keypad will not work. the only button that will work is the number 5 and it calls my speed dial number. i have a flashing triangle at the top of the screen does that mean anything?
    Sergeant:
  • 452 Answers
Take the back up of data & get the system software reinstalled from care center
Posted on Oct 22, 2007
I need instruction manual to program speed dial
I was unable to locate a user manual for that particular device, however the basic instructions for programming speed dial functions are normally very similar between most phones.
Generally there are ONE TOUCH Speed Dial buttons labelled something like M1, M2, and M3 on the dial pad somewhere.
There should also be another button labelled PROG or STORE on the keypad as well.
Normally to program a number into a ONE TOUCH speed dial memory location you carry out the following procedure:
Lift the handset.
Then press the PROG (or STORE) button.
Now just use the number keypad to dial the full telephone number that you want to store in a Speed Dial location.
Once the full telephone number is dialed, then push the M1 button to store that phone number in the M1 One Touch Speed Dial location.
The phone may or may not show some kind of confirmation that the M1 location was just programmed, then just hang up the handset.
Now when you lift the handset and press the M1 button, the phone should automatically dial the phone number you programmed into it.
Now just repeat the same process for the M2 and M3 One Touch Speed Dial buttons with other phone numbers if necessary.
To change one of the Speed Dial numbers, just carry out the normal programming procedure for that location using the new phone number and the old number will simply be overwritten.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Dec 02, 2011 | Southwestern Bell FM-480 Corded Phone
Cordless phone GE model 2-9635 Instructions to program speed dial
After a lot of research, I have found that GE has handed the phones and their manuals down to a company called "ThomsonTM" And if you come across any of problems for this phone in the future, I'll give you their phone number so you can still get help, at: 1-800-447-1700
Otherwise for help right now for the speed dial issue, I could only find directions that were of general use of multiple GE Cordless Phones, so it's worth a shot if you've got the time, otherwise, I suggest calling the number above.
Here is goes:
1.)Raise the phones reciever, or push the "Power/On" button.
2.)Press the "Store" button.
3.)Press the number 0 through 9 or a quick dial letter A, B, C,... to assign, then press the "Store" Button again to confirm the entry.
4.)Enter the number you want to assign the speed dials memory location, and press "Store".
5.)If your GE Phone prompts you to enter a Contact Name, use the keypad to enter it. Press the "Skip" button to enter a space, and the "Store" button to confirm your entry once again.
Once again, this is just a generalized GE Cordless phone guide, and may not be exact to your phone, in which I further suggest calling the electronic product's helpline by
ThomsonTM at:
1-800-447-1700 begin_of_the_skype_highlighting
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Jun 06, 2011 | GE 27928GE5 Cordless Phone
Speed dial
1. lift the handset and listen for the dial tone. 2. press the store button 3. dial the number that you wish to store 4. press the store button a second time 5. press one of the numbers on the phone [0-9] and that will become the speed dial number. 6. make a record of the speed dial number and the name of the person it will call.
Then when you want the person on speed dial number 5, just pick up the receiver, get a dial tone and push 5. Thats it!
ps - kindly rate my answer as helpful. thanks
Feb 19, 2010 | Southwestern Bell Freedom Phone FM2552
Speed dial
go to your phone book select the person...now go to options and add to speed dial (slots 2 thru 9)...
to speed dial..go to phone and press the number on keypad then press phone...you can also speed dial 11 thru 250...by pressing the number then #....come just for the fun of it...go to phone and the keypad (act like we making a call) now press 19# (who came up)...try 15# and so on (this also depends on how many is in you contact....if you only have a fave 5...19 & 15# will not work,,,
feel free to rate the help
Jun 16, 2009 | Dual Electronics CECT P168 Cellular Phone
How to set up Speed Dial on a Uniden phone?
My Mom had this same problem.   I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
 (To enter a 2-second pause between numbers, press [redial/
pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored.
NOTE:
• Storing a number to a speed dial location will
overwrite the any previously stored number without
warning.
• When storing numbers into memory and the handset is idle (i.e., no key is
pressed) for more than 0 seconds, it will beep rapidly, and then the phone
will return to standby.
Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.)
Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
number.
Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
Jan 11, 2009 | Uniden Cordless Phone
Speed dialing
press any 1 number from you keypad and press CALL button...if you havent assigned speed dial it will automatically ask you to assign the number for that speed dial
thankyou
Nov 30, 2008 | Cell Phones
Razor v3 problem using keypad durring phone calls "press 1 for this press 2 for that etc...
go to menu/settings/intial setup/DTMF - set it to continous then try the voicemail and try deleting the msgs again.
Oct 25, 2008 | Motorola Mobility RAZR V3
Speed dialing
which model ?
generally in all cell phones v will be have speed dialing option in range costing handset also... v can set the 9 speed dialing numbers .... in which 1 speed dialing number is common that is sos(112) in samsung and motorola handsets ... common thing is may be in sony ericson also i m not sure ... in nokia handsets if we make the speed dialing option on then if we just press one number means we can call to the person ...
for ex: you may be having some person whom u will call frequently instead of selecting the number by going to phonebook if you put that number to speed dialing list means you can call them by pressing only one button...( while adding to the speed dialing list it will ask to assign the keys like 1,2,3... 9)
as every handset keypad will be having 0-9 number keys this is very useful ...
in some handsets the speed dialing option is found in phonebook & while in other it will be found in call options...
Feb 07, 2008 | Cell Phones
Uniden 900MHz phone model EX17960A
Your cordless phone can store up to ten numbers in the speed dial memory.
1) When the phone is in standby mode, press the memory key. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number; each number can be up to 20 digits.
7
3) If you need the phone to pause during the dialing sequence, press
the redial/p key to insert a two-second delay between the
numbers. You can enter multiple pauses to increase the delay.
4) Press the memory key again.
5) To store this number as one of the ten speed dial numbers, enter a
digit from 0 to 9. If there is already a number in that speed dial
setting, it will overwrite the previously stored number without
warning. You will hear a confirmation tone indicating that the
NOTE: When storing numbers into memory, if the handset is idle
(i.e., no key is pressed) for more than 30 seconds, it will beep rapidly, and the phone
will return to standby mode.
1) When the phone is in standby mode, press the talk key, and listen for a dial tone.
2) Press the memory key and enter the speed dial entry (0-9) that has the stored number you
want to dial. (If you enter a digit that does not contain a stored number, the handset will
Nov 13, 2007 | Lands Phones
Speed dial list
***Storing a Number for Speed Dialing*** 1 Press Phone Book on the control panel. 2 Press Phone Book or the scroll button (􀂥 or 􀂊) to display ?Store&Edit? on the bottom line of the display. Press Enter. 3 Press Enter when ?Speed Dials? appears on the display. The display prompts you to enter a location number, showing the first available number. 4 Enter a one or two-digit speed dial number between 0 and 79, using the number keypad or scroll button (􀂥 or 􀂊), and press Enter. If a number is already stored in the location you chose, the display shows the number to allow you to change it. To start over with another speed-dial number, press Upper Level. 5 Enter the number you want to store using the number keypad and press Enter. To insert a pause between numbers, press Redial/Pause. A ?-? appears on the display. 6 To assign a name to the number, enter the name you want. For details about entering characters, see page 1.14. If you do not want to assign a name, skip this step. 7 Press Enter when the name appears correctly or without entering a name. 8 To store more fax numbers, repeat steps 4 through 7. To return to Standby mode, press Stop/Clear. ***Sending a Fax using a Speed Number**** 1 Feed the document(s) face up into the ADF. For details about loading a document, see page 2.2. 2 Adjust the document resolution to suit your fax needs. See page 2.3. If you need to change the darkness, see page 1.20. 3 Enter the speed dial number. ? For a one-digit speed dial number, press and hold the appropriate digit button. ? For a two-digit speed dial number, press the first digit button and hold the last digit button. The corresponding entry?s name briefly displays. 4 The document scans into the memory. The fax number stored in the speed dial location is automatically dialed. The document is sent when the remote fax machine answers
Aug 17, 2007 | Samsung SF-560 Plain Paper Laser Fax
Motorola Mobility RAZR V3 Logo
74 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
