Question about Pentair Minimax Ch 400,000 Btu Propane Pool Heater Millivolt Ignition
Pool heater cycles off and on
Raypac versa, electronic .  cleaned filter and tryed by pass on pressure switch but problem persists.  Heater was neglected and full of leaves and rat droppings but that has been cleaned . Paul Minimax 400 pool heater cycles on and off about every 30 seconds? Is it the pressure switch or possibly the flow valve? Somethig else I have a similar problem on a minimax 400. I replaced the control board but that wasn't it. I bypased all limit switches and it still cycles. Manifold get's very hot, so I'm pretty sure ti has to do with the flow control valve. I removed the flow control valve last night and am lookign at it now. It there any way to tell from sight if it is bad? Otherwise, $120 to buy a new one. If I replace it and that's not it, what else can it be?
    Champion:
  • 246 Answers
Insert on hot water and see if open or close than on cold water and must reverse from hot. if nothing happen replace
Posted on Sep 19, 2009
Where is the pressure switch on a 130000 btu raypac heater
It should be just inside the door, maybe up behind the thermostat. It is connected to a 1/8" copper tube on one side and has two wires coming out the other side.
Sep 15, 2013 | Raypak Versa 130,000 Btu Above Ground...
Raypac 407 ASME swimming pool heater Do you have a troubleshoot manual for this heater that I can download ?
if pump ok and filters ac going to unit check transformer if ok check safety circuit if ok on cycling check ignitor if ok check gas
Jun 20, 2011 | Raypak COMMERCIAL R407A 399K BTU ASME...
My pool heater flashes LO and BO.
"LO" is simply informing you that the Heater is not sensing proper water flow through it! A Flow Problem.
A special sensor, called a pressure switch is this source. But... That does not mean it is bad - No, it is in most cases just doing its job!
Most common reason - Dirty Filter.
A good cleaning of the cartridges, or maybe a breakdown and recharge of a DE Filter, or a good cleansing backwash of your sand filter, will remedy this situation.
Or... Check for any OTHER reason or situations water flow may be reduced through the heater:
  • enough water in pool or spa?
  • If you have a weir gate in skimmer, is it stuck in the UP position?
  • Are any valves closed?
  • Do you have a bypass valve at the heater?
    • If open, this will reduce the amount of water going thru heater, close it to the point, LO goes away.
  • Could be debris in front of Pressure Switch, in the copper tubing
    • Unscrew and remove pressure switch, turn pump on. But first, align end of tube so that when water squirts out it will shoot out from heater and not onto electronic heater components!
  • If all above is good, you may have failed pressure switch?
  • Etc
BO Message...
This means "By-Passed Operation"
This mode is for systems with 'Automation' controls. If you don't have an automation system, then your heater has a control dip switch or logic jumper that needs to be undone. But if you have automation, do Nothing, your automated system has control of your heater. Good Luck - hope this helped.
May 29, 2011 | Hayward H-series Electronic Gas Pool...
Heater cycles on / off
This could be a water flo problem. you need to chech to be sure your by-pass valve is closed down enough to force water threw heater, There is a internal by-pass that could be a problem also, or a bad pressure switch. If the by-pass isn't the problem then you should check these also.
Jul 25, 2010 | Pentair 460736 Master Temp Pool Heater...
Pool heater will not fire up
Check for proper flow at your pump and at the return jets. You have to sustain proper water flow in order of rthe heater to function properly. If the flow is adequate, then use a jumper lead across the pressure switch terminals on the heater and see if it will fire and remain on. If so then the pressure switch is either faulty or you have a flow problem which is not generating enough water pressure to trip the switch. DO NOT adjust the pressure switch, as it is factory set. Check your pump for a clogged inlet or other possible blockage before the heater.
Apr 14, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Pentair matertemp 400,000 BTU heater cycles on & off
My pentair matertemp 400,000 BTU natural gas heater cycles on and off before reaching desired temperature. I completely cleaned the DE filter and flow should not be an issue. When running the spa the pressure is 25. When running the cleaning system (polaris pop ups) the pressure is 30. Burner fires for 80 seconds then shuts off, reignites after 53 ceconds.Any tips on what might be the issue with the heater
Apr 04, 2010 | Pentair Mastertemp Pool & Spa Heater Dual...
I have a Raypac 2100 digital pool heater and it's reading PRS. Is there someone out there that can tell me where this pressure switch is? According to the guide, PRS means "pressure switch open". If I...
On the side of the heater where the pipes are connected; under the top cover. It is a round disk threaded into the header. It is likely that your filter needs a good cleaning if your heater has always worked reliably in the past. If you have a cartridge filter, it may be time for a new element if you can no longer get it clean enough to get the heater to work.
Sep 26, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Sounds like a limit switch, although it might mot be bad. If the filter is cleaned, and you have a good return from the pool jets, then you may have a problem with the flow valve in the heater. I would try to bypass the limit switches and see if that stops it, but it is dangerous. If you feel capable enough to try, only do so if there is a pressure relief valve on the header (does not come with heater, but if it was installed correctly then the installer would have to have put one on).
Apr 20, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
check pressure switch if ok check for loose wires if ok check copper tube to pressure switch
Mar 16, 2009 | Raypak Pool Heater Covers for Teledyne &...
Pentair Minimax Ch 400,000 Btu Propane Pool Heater Millivolt Ignition Logo
374 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
