Question about Kyocera Office Equipment & Supplies
Copier not coping due to teo messages on the display, 020 and C-6
I have a Kyocera Mita 1500 and i am not able to use the copier due to messages appearing on the display. Those messages are 020, C-6 which are preventing me from coping. Can someone tell me how to solve this problem?
  • dspencer912 Jun 02, 2009
    how do you enter "U163?" I do not see any place to enter this number, can you say how???
    President:
  • Kyocera Master
  • 990 Answers
Hello sir; your machine temperatur too high need to reset the procedur as follow;
1, press "stop/clear" key, "start" key", and left copy density key.
2, press "stop/clear" key again.
3, enter U163 press "start".
4, when screen display "CLE" then press "start" again to reset.
Posted on May 29, 2009
What happened when my Kyocera Mita KM5035 Copier is unable to copy after refilling the toner?
there are many reasons for this .first make sure you installed the toner container very well. second type 1087 twice to service menue then type 30 to chick motors then exit and type 130 to adjust toner mode when the machine stop turne it off-on
Nov 19, 2015 | Kyocera Mita KM-5035 Printer
What does the error message OP mean on my Kyocera mita KM-1500 copier?
From what I remember on this copier...... The software in the copier may be from another country.... OP or AP most likely the copier needs a new toner installed or could be a paper jam in the doc feeder. The codes were a bit messed up between different countries, I did not biuld them.... Good Luck
Dec 19, 2012 | Kyocera Mita Toner For Kyoceramita...
FS 3900 "Unknow toner istall" shows in display?
The message is indicating that you do not havea real Kyocera toner installed in the machine.
Apr 04, 2011 | Kyocera Mita KYOCERA/MITA - FS-3900DN Mono...
Kyocera Mita KM-1500 shows flashing c-6 and 020 Pls help
check the fixing unit thermoswitch,thermistor & heaterlamp one of them is the cause of error
Nov 22, 2010 | Kyocera Mita Office Equipment & Supplies
Kyocera Mita 1500 Error code 6000
This C6000 error code is triggered by a few things all having to do with the fixing heater wire. Ask your technician to check the thermistor, the thermal cutout and the connection between the thermistor and the power supply board. My guess would be that the power surge overloaded the power supply board. This is not something that can be reset and may require new parts.
The manuals that describe the error codes are only available to Kyocera technicians, sorry.
Henry
May 26, 2009 | Kyocera KM-1505 Copier
Kyocera mita error codes of KM 1500
Hello sir; The error code you display A3200 is not available in our menual, we do have C3200 , if that's correct, it means exposure lamp burn out ( not on), replace it, or thermos fuse out.
May 13, 2009 | Kyocera KM-1505 Copier
SYSTEM ERROR
error 610 machine kyocera km-3035 ????
Nov 05, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera Mita km-1820
Unplug the power cord for 10 seconds.
Oct 20, 2008 | Kyocera Mita KM-1815 All-In-One Laser...
Kyocera/mita KM1510 copier
Unfortunately it is the laser unit that has failed. And these unit's aren't a servicable item.
Dec 17, 2006 | Kyocera Mita KM 1510 Laser Printer
207 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
