Question about Epson Stylus® RX640 All-In-One InkJet Printer
Printer error can find any paper jam but still wont start!
Rx640 a printer error occurred. I have read the other solutions. If I have checked as much as I can for paper is likly to be paper jam or cartridge problem. The only thing I can see is that in the cartridge bay on the side facing me is a strip of plastic clipped or stuck on that looks like it is very loose. Could that be the problem? thanks for your help
  • Epson Master
  • 511 Answers
Yes it could be. Some pin at chip of ink tank, read when printer turning on (reading presence/existence). Some pin read when start to print (reading "information" ). If there are some pin not connect, status monitor (ink level) is ok, but when start print error accured.
Posted on May 30, 2009
6b10 error, meaning?
Hi this is what i found for your problem hope it helps thanks. Paper feed cam sensor error or Error Code 6B10
Condition: An error occurred in the paper feed cam sensor during paper feeding from the cassette, or the paper absorbing a large amount of ink jammed in the PF rear guide.
Problems and Solutions:
  • Jammed paper in the PF rear guide (when a large amount of ink was absorbed in the paper);
    - remove the jammed paper and foreign material.
  • check for foreign material or paper debris in the cassette or in the PF rear guide;
    - remove foreign material.
  • If other solution fail, replace one off the following part
    - PF pick-up unit
    - Logic board
Sep 21, 2011 | Canon PIXMA iP2000 InkJet Printer
Paper jam error with my canon mp180 printer and it wont let me do anything i have checked the printer numerous times to see if theres anything in there and theres not.
This problem can occur, may be there is no paper jam inside but improperly inserted paper in the paper tray.
Check and verify that there is no paper or a piece of paper stuck in the roller or the belt. Remove all the paper from the paper tray and insert them again, do not fill the paper tray fully,
Aug 24, 2011 | Canon PIXMA MP180 All-In-One InkJet...
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
HP 3005dn Printer Tray 1 paper jam error
If message in display panel reads [13.XX PAPER JAM [LOCATION]]Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken.
Soln.
For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation.
For message 3.0 PAPER JAM [LOCATION]
means
A non-specific paper jam occurred.
Soln
1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation.
For more help check yhis site
http://www.printertechs.com/tech/error-codes/error-codes-0-19.php
Nov 26, 2010 | HP LaserJet P3005n Printer
Canon imageclass mf6530 paper jam error wont go away
check where that u removed the paper and see if one of the sensors is stuck or out of place. also look for a piece of paper. you may have to get a flash light to see better
Aug 05, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Paper jam 11
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Nov 07, 2008 | Copystar CS-1815 Printer
Samsung ml 2010 r laser printer
Check your manual, there is a solution there or download the user guide from
this site below or read the information below.
http://downloadcenter.samsung.com/content/UM/200602/20060216163720484_ML-2010_English.pdf
LED pattern Possible Problems and Solutions
Your system has some problems. If this problem occurs,
contact your service representative.
On Line/Error LED
lights red
• Paper jam occurs. To solve the problem, see “Clearing
Paper Jams” on page 5.6.
• The front cover is open. Close the front cover.
• Paper tray is empty. Load the paper in the Tray.
• The toner cartridge is out of toner. Remove the old toner
cartridge and install a new one. See “Installing the Toner
Cartridge” on page 2.4.
• You pressed the Cancel button while the printer is
receiving data.
• In Manual Feed mode, there is no paper in the manual
tray. Load paper into the manual tray.
• If the printer is receiving data, the On Line/Error LED
slowly blinks green.
• If the printer is printing the received data, the On Line/
Error LED blinks green fast.
Jul 17, 2008 | Samsung ML 2010 Laser Printer
Error paper jam
Step1
Step
Step
Step
Step
5
Step
6
Step
7
Step
8
Step
9
Mar 22, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Epson Stylus® RX640 All-In-One InkJet Printer Logo
188 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
