Surround sound won't sync with Samsung wireless plasma
Purchased a Samsung FPT5894WX/XAA. When running my surroud sound system the sound does not match up. I assume this is due to the wireless feed to the TV from its remote. Is there a fix out these? If not, can you recommend a comparable Samsung 58'' plasma? I can still return this but the picture is fantastic!
  • 1779 Answers
SOURCE: samsung plasma 42 inchs with sound no picture
Most likely your Y Sustain panel has gone bad. I would have a qualified service center evaluate it to be sure.
Posted on Nov 07, 2009
  • 6 Answers
SOURCE: Have sound but no picture on Samsung plasma
It's a pretty common problem. The no picture but sound problem is usually the y sustain board. I've replaced 2 on mine now. The 680uf 35V capacitors usually are bulging because one of the power transistors went and took them out. This has happened to both of the y boards I had. One time the failing y board took out the buffer boards too, and once it did not. The fix is super simple and anyone with even the most rudimentary knowledge of computers or electronics can do the labor yourself. You should do the simple stuff first by just doing a quick test with a multimeter. Just check the power coming to the y board. After that you can just remove the y board by removing 3 cables and like 3 screws. Plug in the new board and it's done! You can source the parts from a place like shopjimmy or discount merchant. 3 boards were like 200 bucks. 1 board is like 100 bucks. Labor took me 15min. Think about that the next time an electronics repair place charges you 1000 dollars. Of course they check everything (Yeah right) and warranty their work (I don't) but if you check the service manual it states that this is the most common repair. Look for the Canadian manual online. Hope this helps!
Posted on Feb 23, 2010
SOURCE: HPT5054 50 in. HDTV-Ready Plasma Television: Samsung HPT5054X/XAA - No picture, Sound OK, Have ...
Take a DMM put it in resistance mode to measure upto 1K Ohms and check the resistance across C5515, C5502, C5504, C5507 (LOW BOARD), Then check C5415, C5402, C5411, C5404 (UP BOARD). The defective board is the one that will have around 100 ohms or less across these capacitors.
Posted on Jun 30, 2010
toolkits
  • 1099 Answers
SOURCE: Samsung 58" plasma pop spark no picture
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Posted on Jul 02, 2010
  • 8457 Answers
SOURCE: Just purchased a Samsung LE46C650 LCD tv and it is
No,half a second that not consider a problems.There are hundred of hardwares and softwares design by dozen of compannies and corporations.Putting these diveces together 100% functionals are not gaureentee.99.99.....% out of 100% is not cosider a problems.
Posted on Nov 20, 2010
How to I get my surround sound speakers to work with the cable box?
One way would be to connect one of the the digital audio outputs to the HT as an input (HDMI or optical digital audio).
Another would be to select one of the DSP modes that uses surround speakers. They work with all input modes.
http://downloadcenter.samsung.com/content/UM/200802/20080203110035031_HT-Z510-XAA-0125.pdf
Jan 28, 2011 | Samsung HT-TZ512T Theater System with...
No sound from samsung la40b550 hdtv to external source
Connect the Red an White audio out jacks to desired audio input of surroud reciever. the reciever will decode the surround from these outputs .
Aug 31, 2009 | Samsung Televison & Video
No sound thru surround sound system in TV Mode
You need to connect your TV to the AUX connection in the back of your HT system. Then set your HT system on AUX 1 and wait about 5 seconds for the TV sound to come through. If it does not work on AUX 1, you may have to try on AUX 2 or AUX 3 settings on your HT system. Make sure the A/V cable you use is good and in working order and is a good quality cable.
Hope that helps, Gary
Jan 30, 2009 | Samsung HTZ-510 Theater System
Samsung HPT4254X/XAA plasma turns off and on by itself, clicking.
had the same problem, same tv... bad connection on a transistor....
Jan 07, 2009 | Samsung HP-R4262 42 in. Plasma Television
Sharp LC-32D44
Below picture shows Audio inputs of Sony DAV-S400 and you can hook up any one.
Go to menu of home theater system and enable surround.
Need further help, let me know please...
Oct 26, 2008 | Sony DAV-S400 System
Jumping Picture
Does the Sony surround upscale the signal from normal RCA to Component video? If so I have found that sometimes there can be signal sync issue. Meaning the signal that the component video convertor (inside the surround sound unit) sometimes struggles to give a clean component video signal. The TV then struggles to filter the signal correctly resulting in a jumping picture. Try plugging the DVD video only (yellow RCA lead) straight into the plasma and see what happens. You can also try playing with the signal frequency of the plasma, from 50 - 60hz. This will found in the menu of the plasma. Hope this helps. ST
Oct 29, 2007 | Sony DVP-NS530 DVD Player
Optical output on tv through dvd home cinema out of sync
I just had the same problem. I returned it to currys and got an exchange because I thought there was somethink wrong with the surround sound itself. I have just tried , and left for ages as it goes out of sync gradually as you said ,the red/white cables (rca , i think it's called)and it works perfectely. You can find the wire for quite cheap just type it in google.
Sep 17, 2007 | Televison & Video
Open Questions:
Televison & Video Logo
95 people viewed this question
Top Televison & Video Experts
