Question about Sigma 70-210/4-5.6 UC II AF Zoom Lens for SA 760110
Leaking some thing from full zoom
I have a sigma uc zoom 70-210mm 1:4-5.6 multi-coated lens and when i push out to focus at 210 there is a piece of string that comes out which looks like the seal to me with some grease i think is there a manual for me too repair it my selve it is not in warranty and i have had it for 14 years so not paying the price in the shops.
    New Friend:
  • 117 Answers
The string is a felt dust stopper if you take off the rubber zoom grip you will see black tape peel off the tape and the base of the zoom ring will slide off just remove the rest of the felt clean the barrels and put back it will be ok without the felt you can stick back the part of the zoom ring with tape
Posted on Aug 08, 2009
Hi have a panasonic gx7been given 2 sigma lenses can i fit to my camera 1 x sigma 1:4.5 F=100 - 200mlti coated zoom lens 1 x sigma mini wide 1:2.8 f=28mm multi coated lens thank you
It depends totally on whether your camera takes interchangeable lenses, and if so, do these lenses have the same fitting ? Your camera manual should tell you if you can fit other lenses to the body - if so, follow the steps to remove the lens which is currently attached, and compare the fitments with this lens and the two others you have been given. If you are still not sure, then take it all to your local friendly camera dealer, who will be able to advise you. Do NOT try to force the new lenses onto the body - this is a sure way to render them inoperable.
Dec 22, 2016 | Sigma Cameras
Is it possible to see the user manual of the sigma uc zoom 70-210?
There's usually not a lot of information packed with standard zoom lenses besides the warranty paperwork and contact information. You may find contacting Sigma via their website linked below will get you the best results for whatever you're looking for.
Sigma Corporation of America
Sep 29, 2014 | Sigma 70-210.f4-5.6 Multicoated Uc Zoom...
Leather cord coming out of zoom barrel on sigma 28-200
That cord may have been a gasket for sealing the lens from dirt.
Dec 12, 2013 | Sigma AF 28-200 Lens
Will the Nikon Sigma 70-210 F4-5.6 55MM AutoFocus lens fit on my nikon d40?
Yes, it will fit. However, lacking a focus motor, it will not autofocus on the D40.
Jan 20, 2011 | Nikon Sigma 70-210 F4-5.6 55MM AutoFocus...
Can an old film sigma uc zoom 70-210mm lens work on canon digital cameras
In short, no. Not without an expensive adapter which includes a corrective lens (which also reduces the optical quality). Even then, the lens will be fully manual only and might only be operable at the widest aperture setting.
If your Canon uses the APS-C sized sensor (all except a few highly expensive professional full-frame models do) then the 70-210 lens will produce a cropped image as if you were using a 112-336mm lens, so it may also be less useful to you.
Aug 14, 2010 | Canon Cameras
Hi I bought a pro-spec 70-210 lens for my Sony Alpha. When you go to zoom out it doesn't twist. You can pull it straight out...Is this how it should work? The rest of my lenses all twist out
Yes. It's a push pull zoom action.
One touch zooms as used on 35mm film SLRs used to have the same mechanism, the zoom ring twisted as well to achieve focus but now that most lenses are autofocus that's unnecessary. So you have a lens which just retains the push-pull, a far more natural action in my opinion and usually faster than a rotating zoom. Once you get used to it I think that you'll prefer it.
By contrast, most modern zooms have what was considered in 35mm terms to be an old-fashioned twin touch zoom: one ring was turned to zoom the lens and another was turned to focus it. This sometimes meant that after zooming you had to refocus; your push pull zoom will likely have a more technically demanding constant focus zoom action, there will be an additional manual focus control as well, but it's very much a minor secondary control used only when your AF has broken or is switched off.
I hope that my reply has been of use to you, please return the favour by rating my answer.
Mar 03, 2010 | Sigma 70-210/4-5.6 UC II AF Zoom Lens for...
Sigma 70-210/4-5.6 UC-II AF Does not auto focus any more?
Hi
Dose the lens make any movement or is just dead
it may need a new AF motor
Nov 30, 2009 | Sigma 70-210/4-5.6 UC II AF Zoom Lens for...
Sigma auto focus 1:3.5-4.5
Hi    The switch is held on by two screws you can remove the screws    and the switch will fall off it will need cleaning
Aug 21, 2008 | Sigma Zoom Tele 135-400mm f/4.5-5.6 APO...
Trouble focusing with sigma 70-300 DL macro super lens
It will not focus on anything closer than 5 feet.
(From Sigma lens literature)
Capable of macro photography, this lens has a 1:2 maximum close-up magnification at the 300 mm focal length. It's the ideal high performance lens for portraits, sports photography, nature photography, and other types of photography that frequently use the telephoto range. It also has a switch for changeover to macro photography at focal lengths between 200mm and 300mm with a maximum close-up magnification from 1:2.9 to 1:2. The minimum focusing distance is 1.5m / 59 in. at all zoom settings.
Dec 25, 2007 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Cameras Logo
316 people viewed this question
Top Sigma Cameras Experts
M_Butkus
Steve
bhargav
Are you a Sigma Camera Expert? Answer questions, earn points and help others
