FRONT TOP FACIA LEAKING NEAR DETERGENT BOX
HAVE A LG INTELLOWASHER WM 1122OFD IT HAS STARTED LEAKING FROM THE TOP FRONT FACIA NEXT TO THE DETERGENT BOX
  • 15,935 Answers
Look for the bellow to be torn, damaged, or creased.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Lg tromm washer leaking from front door
We have the same problem with our LG washer. Don't think the door can be adjusted but I'm not for sure. I think the gasket is wore out but haven't checked on fixing the problem yet because it barely leaks.
Sep 29, 2012 | LG WM-2277HW Front Load Washer
My LG Intellowasher WM-1280FHD is refusing to spin, even when empty, making strange noises and displaying the code LE. I cannot find the manual to know what this means. Can anyone help?
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jul 14, 2010 | LG WM-2277HW Front Load Washer
Intello washer leaking water from detergent drawer. model no. WM10402F would like to know if a part needs to be replaced or would anew machine be better. the water only leaks when water comes into the...
Are you sure it is coming from the detergent drawer? It could be from your inlet water valves. They are very easy to see. Two screws on the rear of the machine will let you slide the top back and expose the componets.
Dec 29, 2009 | LG WM-2277HW Front Load Washer
Lg intellowasher model wm 1290fhb door will not open. tried waiting 1 hour! tried power on and off, tried child lock
  1. Press the SPIN SPEED and SOIL LEVEL buttons simultaneously.
  2. Press the Power button, while pressing the SPIN SPEED and SOIL LEVEL buttons. Then buzzer will sound twice.
  3. Press the Start/Pause button repeatedly with about 1 second interval until the lamps goes out.
  4. The washer powers off and unlock the door.
Oct 18, 2009 | LG WM-1290FHB Front Load Washer
Leaking from Detergent tray
TAKE THE DETERGENT TRAY OUT AND CLEAN IT.
IF THE PROBLEM PERSISTS TURN THE WATER DOWN TO A DRIBBLE AND SEE IF THIS FIXS THE FAULT. IF IT DOES--- THE WATER IS SPLASHING UP THE FRONT OF THE TRAY AND OVER THE TOP.
1) TAKE THE TRAY OUT 2) LOOKING AT THE TOP OF THE CAVITY ,COUNT BACK 4 ROWS OF HOLES, DRIILL THEM OUT TO 1/4 INCH . 3) BLOCK THE FIRST 3 ROWS OF HOLES WITH SILSATIC.
IF THE SLOW FILL DOES NOT FIX THE PROBLEM TAKE THE 2 SCREWS OUT OF THE BACK AND SLIDE THE TOP OFF, YOU WILL THEN BE ABLE TO SEE THE DISPENSER AND THE HOSES GOING TO IT. THEY MAY BE DAMAGED.
Jul 06, 2009 | LG WM-2277HW Front Load Washer
Intellowasher WD-12126RD
it is coputer box in the washer. if it work on all other cycles. and stop on rinse. it need a new computer box . and in not hard to change.
Feb 15, 2008 | LG WM-2277HW Front Load Washer
Suds leaking from back of washer near top
Suds are not supposed to leak from the top; means you are not using the right detergent. Use front loading powders. You can open up the top during next wash to locate where the leak is coming from (after changing powder). I understand suds appear in the window during spin....but leak? Caution when machine works with top open!
rate if helped pl........
Dec 29, 2007 | LG WM1814CW Front Load Washer
Washing Machines Logo
136 people viewed this question
Top Washing Machines Experts
