Question about Sentry Fireproof Safe
I HAVE A SENTRY SAFE A3860 I NEED TO OVERRIDE THE ELECTRONIC CO
I HAVE THE KEY,IS THERE A WAY I CAN BUT IN MY OWN COMBINTION? THANKS The safe is open and wont close. We have the key and can't get the tumblers to close. How do you reset the code? Help.
  • 80 Answers
Http://www.sentrysafe.com
the instructions are located link above.
mj
Posted on Sep 07, 2009
2 Suggested Answers
SOURCE: I HAVE A SENTRY SAFE A3860 I NEED TO OVERRIDE THE ELECTRONIC CO
Sure you just enter the master code then enter the new user code then hit program. Sentry Safe programing instructions.
Posted on Aug 06, 2010
Have key and code...safe will not open
Sentry Safe not unlocking - YouTube
? 0:36
https://www.youtube.com/watch?v=4mbtSUAoS6w
May 8, 2013 - Uploaded by 1diazsantana1
When i put the pass-code on my Sentry Safe the handle will remain locked and I ... mine dont want to open either! i get 5 beeps ... How To: Open A Locked Sentry Safe If You ForgotCombination Code Or Lossed Key Model Is ...
Opening a Sentry Safe with a Rubber Mallet, some WD-40 ...
idoneitmyself.com/.../opening-a-sentry-safe-with-a-rubber-mallet-some-...
May 7, 2010 - Since this safe can only be opened with an electronic code, this is a .....i have sentry V260 electronic with key, no handle. cant find key and ...
Jan 05, 2016 | Sentry Safe Fire-Safe .8 Cubic Ft....
No override key to open the safe and need to change battery
is there a reset button in the sentry safe X055 that i could use to reset the password
Nov 15, 2012 | Safe International Sentrysafe X055...
What do you do if the batteries are dead in my Sentry fire safe and can't put code in ?
a1 locksmith advised me to To install batteries, remove cover between knob and keypad.Unlock door with the override key provided in the plastic bag attached to the owner's manual, and open the door using the knob. Remove battery cover located on the inside back of the door by sliding to the right. Insert the four batteries as indicated. Replace the battery cover.
Jul 23, 2012 | Sentry Security Safe with Electronic Lock...
Lost factory code
hi.
the factory code for sentry safes would normally be 00000.
if this does not work you may have to contact Sentry with the safe model and serial number .
these are normally found on a label on the back of the safe, or a label on the front edge of the safe.
contact details for sentry can be found on www.sentrysafe.co.uk
hope this helps
Mar 26, 2011 | Sentry Security Safe with Electronic Lock...
I lost my sentry safe code! what can i do to program the safe! can i do it without the code? please help! thanks
Depending on model, some safes have a key override that can be used to open the safe. Most models do not. Without a key override, probably the only thing you can do is to contact a lock smith, otherwise, start checking each possible code combination until you find the correct code.
If there are valuables in the safe, then take it to a locksmith. Otherwise, it might be cheaper to get another safe.
Jul 14, 2010 | Sentry Fireproof Safe
I have a Sentry safe A3860.. I have the combo and
1. Insert a paper clip or pen point into
the small hole of the battery cover located
directly below the keypad. Push in while
sliding cover to the right (Fig. B).
2. Disconnect and remove battery holder.
• Insert 4 new AA batteries (not included)
to power this lock.
• Reconnect the battery holder and put back into proper
position. Slide battery cover back in place.
NOTE: The yellow LED will light when the batteries need
to be replaced.
You can also get the manual here on link below. page 1 tells you how to replace battery.
http://www.sentrysafe.com/pdfs/OwnersManuals/506218.pdf
Dec 22, 2009 | Sentry Fireproof Safe
look instructions are located link above.
mj
Mar 15, 2009 | Sentry Fireproof Safe
The number 1 button will not press
Key override
If your electronic lock fails or you do not have any codes
available, you may use a key override to access this unit.
1. Remove the battery cover, disconnect and remove the
battery holder.
2. Insert the skeleton key (second set of keys provided)
into the key hole inside the opening for the battery.
3. Turn the key to the right.
4. Turn the four-bitted key to the right.
5. Open the door.
You can download the user manual here:
http://www.sentrysafe.com/pdfs/OwnersManuals/172967.pdf
Dec 24, 2008 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
2,948 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
 Brian Main
Brian Main
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
