Question about Haier hwr10xc6 Air Conditioner
My Window unit started spitting water out of the vent. Now it trips the reset and will not stay on. What do I need to do?
  • ldlockt May 29, 2009
    When I get home from work I will look for the drain hole.
    Thanks.
    ldlockt
  • Haier Master
  • 19,396 Answers
The air conditioner has a drain hose somewhere at the back , and when this is clogged water from condensation is coming out through the fan.
To start cut power to the unit immediately , using the unit in this conditions is an hazard and can cause more serious damage to the internal parts.
If you can find the drain hole, check for blockage in there, after disconnecting the unit from power.
If you do not find the drain line, let me know , I will look for a diagram for this specific model.
Thanks.
Posted on May 29, 2009
Brand new GE room size ac unit (1 week old) is spiiting water out of the air vent into the room. Unit 100% level.
If a brand new unit is spitting water, i waould suggest that it is short of refrigerant... Get your installer back or the Manufacturer.. You need to hold An ARC licence to do this ( In Australia)
Jul 16, 2011 | Heating & Cooling
Window air conditioner is spitting water
Hello, usually a window AC will spit water if the unit is not tilted back or if the drain is backed up, if the unit is level try tilting it back it the window somewhat. Also, if the unit does have a drain make sure it is not blocked.
Jun 19, 2011 | Haier Hwr10xc6t Air Conditioner
Water in air conditioner
A lot of the newer window units design the outside fan to pickup the condensate water and sling it onto the coil. The evaporative effect makes the unit run more efficiently. They ususally don't spit, but if the unit is running well, otherwise, I would't worry about it.
Jul 22, 2010 | Kenmore 6000 BTU Single Room Air...
Condensation buildup
Make sure the unit tilts towards the outside. If it's installed level or tilted toward front it will not drain properly.
Jun 25, 2010 | LG Electronic Window Air Conditioner
AC will not work after being cleaned
You are going to have to let it dry very well. That's about all you can do at this point, as something electrical has gotten wet, and its tripping the unit to keep from burning out a part. Its just a matter of wait. wait, and so on. It will start again.
Shastalaker7
Apr 17, 2010 | Samsung AW1203B Air Conditioner
Sears Plasmaire spits water into room
It's probably just holding water somewhere and getting thrown out. I've seen people drill holes on the bottoms to drain water quicker.
Sep 03, 2009 | Kenmore 75085 Air Conditioner
Droplets of water are coming from the vents and it's making a noise like something is rattling around inside. What could this be?
The problem with this unit is that the evaporator, or the part of the air conditioner that 'creates' the colder air is not draining correctly. Pertaining to a window unit, it needs to be installed correctly with the correct amount of tilt toward outside, to allow the evaporator condensation water to drain. You may also want to check to make sure there aren't any plugged drain holes in the air conditioner housing.
The rattling you hear is most likely the blower fan spinning against the held water inside the unit.
I hope this helps! :)
Sep 01, 2009 | Heating & Cooling
My haier a/c window unit is spitting water through the vent
Thermal transfer-the unit is creating condensation.
Jun 03, 2009 | Haier Heating & Cooling
check the filter located behind the front panel it usually snaps out also make sure the drain holes on the out side bottom of unit are not stopped up and that the unit is leaned back slightly for drainage freezing is a sign of low air flow or low on freon the coil actually gets colder when freon starts to leak out hope this helps with your problem
May 15, 2009 | Haier hwr10xc6 Air Conditioner
Troubleshooting
first I would check your air conditioner to see if it is tilted backwards it should drain to the back (outside) . also check to see if the evaporator tray is clear of debris. if it is pluged up water may back up.. let me know and if this don't help we can go deeper..Thanks
Aug 23, 2007 | LG LB8000ER Air Conditioner
Haier hwr10xc6 Air Conditioner Logo
53 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Terry Hair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
