Question about HP Pavilion Slimline S7410N Notebook
Sud I turn my p/c every night - HP Pavilion Slimline S7410N Notebook
  • aarthur69 May 30, 2009
    yes it helped me thank you
  • Gyanendra Kumar May 11, 2010
    hi,
    u are talking about turn on or off?
  • 39 Answers
I assume you ask "should i turn my pc off every night?"
its a rather tought question and it is debated.
my computers are on 24hours a day, 365 days a year.
most servers areound the world is always on.
the worst thing for computer parts is to get cold -> warm -> cold -> warm ->-> all the time. this is what wears absolutely the most on components in the computer
so lets say you are using the computer in the evening and you are gonna start using it again in the morning, i would say you could just as well leave the computer on.
if you are going away for the weeken i would suggest to turn it off.
There is another concern about this tho. and that is about saving the environment. consuming less electricity.
so to conclude: Yes, if there is no special reason to leave the computer on (downloading files, playing music, whatever), you should shut it down every night.
please rate if you found this helpful
Posted on May 30, 2009
I have a Frigidaire dishwasher that's just over 1 year old and I use it a couple times a week. I turned it on last night and went in another room. appox 30 minutes later my daughter came in and noticed the...
Someone squirted dish soap in there instead of regular dishwasher detergent...
You will need to manually rinse out the soap and use the right soap...
heatman101
Sep 18, 2010 | Dishwashers
Last night I tempted to clean the large duet washer with the chlorine program. After starting, I realized I only had clorax bleach for colors and reluctantly used this. Large suds formed. I paused/cancel...
Drop your drain hose to floor level with bucket under it this will drain with no power applied , pour in as much water as you can to flush it out / clear pump .After all suds clear refit / restart ..Should now fill, wash/ empty and spin...I hope ...
Apr 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Bottom thing is not turning... suds is running
YOU ARE USING WRONG DETERGENT IF YOU HAVE SUDS TO THAT EXTREME, OR DETERGENT LEFT ON ONE OF THE DISHES. CAN'T SAY THAT I HAVE EVER SEEN ANY SUDS IN A DISHWASHER THAT USED DETERGENT MADE FOR A DISH WASHER. THE SPRAY ARM WILL NOT TURN AS THE IMPELLER CANNOT PUMP AIR (SOAP BUBBLES).
Mar 09, 2010 | GE Dishwashers
Message sud and f35 causing washer to stop washing
don't panic/ suds is just what is you have / look in the window. do you see suds/ ok if door is unlocked poor into tub two lids of fabric softner . mixed with a quart of water . wait over night . and everything will be ok . f35 ?? it will probably go away also . if it does not get back with me. . no to stop this from happing again cut down the amount of dergt. or change to the proper type like H E .. hope this helps / ps remove the front panel 3 screws and on the left side remove the drain clean out .. this will help a great deal ..mm feed back please ..mm
Dec 17, 2009 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
What does the code suds mean on my maytag neptune washer
sud's ( like to much soap ) this causes the machine to shut down . mix some downey of fabric softner in a quart of water . pour it in tank . let set over night . and try again . fabric softner will get rid of suds or at least reduce them . it will probably work .. mm
Dec 08, 2009 | Maytag MAH6700AWW Neptune Front-Load...
"suds" code, won't pump out, barrel won't spin properly, "clinking" sound behind lower panel.
hi. you will need to stop using the unauthorized brand of soap. a non HE soap will be trip the suds sensor and it will shutdown the unit. the best way to restore normal actions is to let the washer sit over night. remove the clothes, if any, and allow the suds to settle. the next morning, simply start the draining process. this will drain the water.
May 21, 2009 | Kenmore Washing Machines
Kirby not shampooing, no suds coming out.
Make sure the tray is all the way down. Step on the toe petal to adjust. Turn on power assist.Turn sud control valve right to increase suds.
Apr 27, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Shampoo does not sud
The suds screen is not there or is somewhere in hose elbow. Click HERE and read the tip about installing the suds screen.
If you want to see where the screen is supposed to be installed - see out Kirby shampooer manual HERE.
Good Luck
Rocky
Apr 03, 2009 | Kirby G6 Bagged Upright Vacuum
Whirlpool duet front load will not drain and gives an error code of "sud"
be sure you are using he(high efficency low suds) detergent ..the tide he tend to suds a lot and all brands may over suds some in soft water try cutting back some if problem ..not truly suds issue? ck pump for clog..remove bottom cover turn pump clean out counterclockwise and pull clean out and reinstall try running washer short cycle cold water to removce excess suds
Jul 16, 2008 | Whirlpool Washing Machines
FO2 AND SUD
hAVE YOU TRIED UNPLUGGING FOR A LONGER PERIOD SO COMPUTER LOSES ITS MEMORY.
Dec 23, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Open Questions:
HP Pavilion Slimline S7410N Notebook Logo
76 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
