I have a Canon Pixma 310 and want to print several photos on one page...2 4X6 prints or several 2x3, etc. There's nothing in my manual to tell me how...it just says go to User's guide--on screen manual. I'm wasting expensive photo paper with just one 4x6 on a page. Thanks. Carol Wiebe
    Brigadier General:
  • 3,917 Answers
Hi Carol,
Would suggest the bellow mentioned weblink which actually gives a lot of option and how to acheive them in cases of several prints on one page.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=2613&modelid=15603#SupportDetailAct
Note: this is official web site from Canon so you can type any troubleshooting question in the box as well. Please do keep it handy as the manual sometimes fails to resolve certain issues.
Thank You for contacting Fixya.
Posted on May 29, 2009
NEED TO PRINT A TEST PAGE MANUALLY FOR CANON PIXMA IP3000
Click on Start - Printers and faxes - right click on your printer - Click Properties - then click on Print test Page.
Mar 19, 2013 | Canon PIXMA iP3300 InkJet Photo Printer
Not a problem,but I own the canon pixma 310 and I'm not sure how setting it up to print photos is different than regular document printing?
Hi! here is your solution. 1. Select your image. 2. Click your mouse i.e. right click. 3. Select Print. 4. There are many size for example 4x6 5x7. Chose your size you want to print. 5. Select Photo plus Glossy paper. 6. Press print. thanks
Sep 05, 2011 | Canon PIXMA MX310 All-In-One Printer
I have a Canon MX-310 Printer. Excellent. But, how can I print pages double-sided?
Hi!
Unfortunately it does not have a duplex function and you will have to manually duplex the pages meaning,Print and turn the page around and print on the other side!
Sorry!
Apr 02, 2011 | Canon PIXMA MX310 All-In-One Printer
MX-310 has fax's in memeory but keeps printing the first page of the first fax only. Screen says check paper size. When i push ok it only will print the first page over and over. How do I change it?
If your Canon MX-310 has been set up to print faxes as they are received, then what is actually in memory is a "received fax report". If you select a particular fax in this report, it will print the first page of the fax to remind you of the content.
Your Canon MX-310 will store fax documents in memory if:
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
Dec 04, 2009 | Canon PIXMA MX310 All-In-One Printer
My canon pixma ip4000 has stopped printing. It is going through the motions but the paper is coming out blank with nothing on it.
Hi
If you have lots of flashing error lights or electrical problems then it is likely to be electrical.
However, if like most... and your Canon PIXMA iP4000 InkJet Photo Printer has just been left unused for some time? You probably have an ink clog on the cyan and magenta.
Or possibly a faulty cartridge.
Provided it worked OK before a period of non-use? Then you just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
Magic Inkjet Flush usually works a treat on those!
Magic is ideal for unclogging the tiny jets on any Canon, Epson HP andremoving those horrible white lines which usually appear in prints whendried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to use the Magic Inkjet Flush kit to soak the print head and you should be printing again like new.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros (Ebay)
Nov 23, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
I am always getting horizontal lines on anything I'm printing these days - how can I fix the problem
Go to your printing preferences page and run your tools (aligning print cartridges, cleaning print heads etc.) consult your owners manual or check the Canon website under support. Also check your ink levels.Hope this helps and good luck.- jmattes
Oct 20, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Canon Pixma IP 8500
Sounds like the print head is bad or seriously clogged. If you have done repeated print head cleanings with no success, I believe Canon sells the print head if your unit is out of warranty.
Manuals available for download here.
May 19, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
Streaky print out from canon Pixma mp830 all in one
I just bought a PIXMA iP3500. The 1st 2 photos I printed had veritcal White lines. I did a Nozzle Check and Alligned the Print head after the 1st photo printed. The 2nd still had the lines. Then I changed brands of Glossy Photo Paper and tried a 3rd time. This time I noticed that it printed much slower and it turned out just fine. Information says that you should have the settings at "high" not "standard". Double check that this hasn't inadvertently changed back to Standard. Gator
Dec 07, 2007 | Canon PIXMA MP830 All-In-One InkJet...
19 people viewed this question
jasbo
jasbo
