Question about GE 30" Built-In Electric Cooktop - Black
Cannot calibrate pan sensors after changing right front element
My pan sensors do not work. I get a fault code of f160. The sensors were working fine before I changed my right front burner. The right front burner kept shutting off with a code f153. I am trying to calibrate thr sensors but I must be doing something wrong.
  • larryljc May 29, 2009
    Fixed. The solution is in the manual..
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
Light "Burner On" stays on all the time on my electric stove GE model JBS27WH2WW
I have a GE Range Model JBS27W H2WW and the serial# XXXXX that I was cooking on and the back burner starting throwing out sparks and blew a hole in the coil and the drip pan. Now the light Burner on is staying on and I switched the 8 inch burner in the front with this 8 inch burner and still cannot get it to work.
Dec 19, 2013 | Cooktops
Fault Codes
This code is shorted temp sensor, element 2, which is the left rear.
Action:
1) Check all heater, sensor and wire harness connectors. Make sure they are tight and secure. Check heater ribbon for possible damage.
2) Remove sensor connector (for left rear in this case) from logic board and measure RTD resistance. Should be 1030-1150ohms. If not, replace heater element assembly (~$130 for part)
3) if fault persists, replace logic board.
See my other entry as how to open the unit and do the replacement of the heater element.
Note: this error code 1X4 (where X in the number of the burner) is similar to 1X3 which is "open temp sensor"; they are dealt with in the same way. Both can be due to damage but I would suspect that, unlike 1X3 codes, 1X4 codes are less likely to be due to simple wear.
Nov 19, 2013 | GE 30 in. Profile JP939 Electric Cooktop
GE profile JP969 fault code F113
I took the cooktop apart I removed the terminal from the main electronic board . The left front burner has 2 white wires and 2 yellow (my case). The 2 white wires lead to the RTD sensor.With an electric meter set on OHMS check continuity between the two wires leading to the RTD sensor .If the reading is more than 1030 ohms is good if not than you need to replace the whole burner that comes as a complete unit with sensor and ribbon heating element.I found it on line for $114.00 +shipping.I wish they sold only the sensor but it would've been too cheap and not worth it for the makers . All connections to that burner are very easy put back together . Some suppliers may ask for as much as $175-$195 for the complete unit .
Apr 11, 2012 | GE 36 in. Profile JP969 Electric Cooktop
The front right burner isnt working
Most common fault is the hotplate element is faulty and requires replacement followed by a burnt off terminal at the hotplate terminal followed by a faulty control switch.
Feb 09, 2011 | Frigidaire 31 in. FEC30S7E Electric...
I have a Wolf gourmet 30" stove. it's about 10
Interesting, I'm looking for a solution to a similar issue. Our new (7 month old) 30'' Wolf Range has this issue. When both front burners are light, the back burner's electronic starter begins to click, but only when you put a pan on the front left burner. I believe the iron/steel in the pan is causing a magnetic field thats starting the rear burner to go off.. just don't know.. will report back after the repair person comes.
Jan 22, 2011 | Wolf Range 18 in. SPR-100 Gas Cooktop
Right Front Burner shuts off after 30 seconds. Fault code f153 flashes. I have reset the circuit. Same issue occurs. Any advice?
x9009 Hello and sorry to hear about your problem.
You have a open heat sensor, one 1 of your heating elements.
I suggest you contact a service company for repairs.
I tried to help you, Please help me by vote/rate my response.
Thanks and good luck.
If you live in the Denver Co area, I can help you out
Dec 22, 2010 | GE 30 in. Profile JP939 Electric Cooktop
Jenn Air Gas cooktop burner ignition
Hi JHMcdona
Most likely the electrode for the right burner is defective. As well as the switch may also be defective (is shorted because of pressing hard on it trying to make it work!!). Change the electrode and igniter switch of the right front burner.
Regards
Aug 26, 2009 | Miele 35 in. KM326G Gas Cooktop
Jenn-Air JED8345 one burner does not come on
The switch for the burner is bad and needs to be replaced.
Jun 25, 2017 | Jenn-Air JED8345 Electric Cooktop
One unit show fault code F153 before, now fault 160
May 29, 2009 | GE 30 in. Profile JP938 Electric Cooktop
GE 30" Built-In Electric Cooktop - Black Logo
343 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
