Question about Carrier Beverage-Air UR30GEFD Beverage Cooler
Error code E1
My AC Doesn't work only the fan and it display E1 with no reciving any order olso by the remote
Error code E1 and E4
PDF]SERVICE Manual - Quietside
https://www.quietside.com/archives/.../Service%20ACC1800C.pdf
When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
Midea air conditioner error codes
airmaster.net/midea-air-conditioner-error-codes/
Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
[PDF]Download the Fault Error Code Booklet - Samsung
Dec 05, 2015 | Heating & Cooling
Haier air conditioner won't run displaying code e1? Do not have remote.
This is the error code.
E1 = Room temperature sensor fault Indoor unit
Even if u had the remote you still have a bad sensor.
AC Repair Delray Beach
Sep 03, 2014 | Haier Heating & Cooling
My air conditioner want turn on or anthing and it shows e1, whats this mean
The E1 code is an error code that appears on the LED temperature display of some digital air conditioners. The error code could mean anything from dirty air filters to a damaged room thermistor, a safety connected to your thermostat that detects room temperature. Troubleshooting the cause of this error code may improve your air conditioner's performance
Sep 15, 2013 | Haier HWR06XC7 Air Conditioner
E1 Error on air conditioner
It's time to call a professional. Call the manufacturer and ask them who they recommend in your area. Note :Some questions can be answered if you put enough information such as brand and model number.
Mar 25, 2017 | Haier HWR08XC7 Air Conditioner
Dometic model 3313192 thermostat error code E1 what does this mean?
Hi By E1 error it means
Loss of communication between the Single Zone LCD thermostat and the module board. LCD will cycle between E1 error.
Check the link for regular maintenance Of the LCD thermostat.
If it doesn't help then you have to replace the LCD thermostat.
Ajin
http://www.google.com/url?sa=t&rct=j&q=dometic%20model%203313192%20&source=web&cd=1&ved=0CCwQFjAA&url=http%3A%2F%2Fmanuals.heartlandowners.org%2FHeating-Cooling%2FA-C_Units%2FDometic%2FDometic_Single_Zone_LCD_Thermostat_Operating_Instructions.pdf&ei=hOg0T7OUNIjkrAer4Ny6Dw&usg=AFQjCNEn2y9-ItUcF2KRJZ0dm0Ftrq8Jhw
Feb 09, 2012 | Dometic Rooftop RV Air Conditioner
I did install all correctly, but i turn it on and like 3-4 min it turns off and indicates an E1 on the display!! Whats wrong?
To help you. I will need to know what Brand your AC unit is and the Correct Model Number. The E1 error code doesn't mean the same thing on all brands and models.
Thanks for choosing FixYa.
Aug 26, 2011 | Heating & Cooling
Error mesege Showing E1
The E codes E1-E7 are displayed in the copy counter.To display both digits of the E code press the ENTER key.When the machine detect E13 condition E1 is displayed in the copy counter.Hold down the enter key and 13 is displayed.
E 11 - Exposure lamp error.In this case check the exposure lamp continuity,the thermofuse is open or power suplly board defective.
E 12 -Exposure lamp error .AC drive defective,main board defective
E 13 - Zero cross signal error.Main control or DC power board defective.
To clear the service code turn OFF/ON the machine.
Sep 09, 2009 | Ricoh Office Equipment & Supplies
E1 code
Use a universal remote (like the one for a TV) to turn on and to adjust settings. I was some what doubtful, but after trying my universal remote, my air conditioner started working.
Jun 18, 2008 | Sharp AF-S120MX Air Conditioner
Carrier Beverage-Air UR30GEFD Beverage Cooler Logo
105 people viewed this question
Top Carrier Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Carrier Refrigerator Expert? Answer questions, earn points and help others
