Question about Dremel 750 02 Minimite Cordless Rotary Tool
I cannot get the chuck to tighten the collet
The collet will not close around any of the drills or sanders.even when the chuck is fully closed.
  • 3 Answers
Sounds like u are using the wrong collet in the end of dremel the normally have a couple of different collets try changing it for a tighter one also make sure its in the right way
Posted on May 31, 2009
I have a masterforce 1/2" hammer drill and the chuck won't tighten-it's stuck open. Is the chuck shot?
use a pair of stillson adjustable spanner .
adjust the spanner to go around the chuck then turn to close as it will ease off then ca use your hand as nornal
Aug 10, 2017 | Hammer Drills
How do I get the mouth to close around the drill bit? It did in the past, but not now.
the 'mouth' is called the 'chuck'.
Depends if it has a chuck key or is hand tightened. I'll assume it is a drill screwdriver with no key.
Above the trigger is a slide which dictates whether the chuck goes clockwise or anticlockwise. Push this to the mid position which locks the chuck. Now you can insert the drill or screwdriver bit and lock the chuck by turning it clockwise.
Oct 28, 2015 | Drills
How do I change to the smaller chuck size?
In your kit, you will find some collets to hold the smaller bits. Unscrew the cap, insert the collet and replace the cap. Inset the smaller bit and tighten the cap. The collets have slots cut into them so they can tighten down on the bit.
May 24, 2015 | Dremel 7700-1/15 7.2v Cordless Multi Pro...
My lithium 20 volt drill is not working. the chuck is will not open and close. you cannot move the front and back sections independently so you cannot tighten a drill bit. How can I loosen the two...
Hold the chuck and run the drill either forward or in reverse until the chuck is fully closed or open then reverse it while holding chuck.
Jan 06, 2015 | Drills
Exctly what fits what
Go to Amazon and do a search for "dremel drill chucks". There are a variety of models that will close down to '0' to allow use of bits as small as #80. Make sure and look at the low end capacity and make sure it will go small enough for the size bit you want to use. I have used to #4486 to use micro drill bits but it is not rated to go that small and can cause wobble and break the bit if not very careful. They are pretty cheap so you can try a couple different models even.
Aug 10, 2014 | Dremel 3000-2/28 2 Attachments/28...
Mybrand new RZ20 keyless chuck will not close around a bit.
If a large enough drill bit is inserted too far so it bottoms in the chuck, the jaws run into the bottomed shank and will not close beyond a certain point due to the interference. If you hold the drill bit out about 1/2 inch from the bottom, the jaws should close on the bit. I assume you have tested the chuck without a bit to verify they can close.
Feb 15, 2012 | Drills
Chuck only closes half way
could be a couple things, the chuck retainingn screw in the center might have loosened up jamming the jaws when trying to close. Open the jaws all the way and tighten the screw, it is left hand thread. Or the chuck itself is damaged and depending on how little use might be covered under their warranty. I would check the screw first.
Feb 05, 2012 | Electric Milwaukee 2610-24 M18 Driver...
I've just bought my b&d cordless 14v hammer drill but the instructions were just a few pictures. one of them was of an allum key in the chuck and hammer striking it but i dont want to damage the drill....
Hi. Try the drill at slow speed without any drill bit in the chuck. Look closely to see if the chuck wobbles off centre whilst holding the drill firmly. If it does then there is a good chance that the chuck is loose from the body. If it seems ok then next close the chuck (tighten it closed) to see if all the 3 jaws are lining up ok and open it again to see if the jaws retract back down the chuck smoothly. (jaws are the small parts inside the chuck that grip the drill bit) If the chuck it seems loose then you can use a long allan key to tighten it up which is inside the chuck. If the jaws do not operate properly then i would suggest taking the drill back to b&q for them to fix, or replace the tool as it should still be under warranty. Good luck
Jan 22, 2011 | Black & Decker Drills
How do I get the opening on the drill to close around the drill bit
Turn the "chuck" (the round part that the drill bit goes into) with your hand until it is snug, then use the chuck key to tighten it the rest of the way. The chuck key should be strapped to the cord of the drill. It looks like a gear and has a "T" handle for turning it. It fits into the gear teeth on the chuck.
Dec 01, 2010 | Garden
How to tighten drill bit on makita 6343d
your must have a keyless chuck. hold the black center part of the chuck and run the drill forward or backward to open or close the chuck.
Jan 26, 2010 | Drills
Dremel 750 02 Minimite Cordless Rotary Tool Logo
352 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
