Question about Worx 10" 18v 2 In 1 Grass Trimmer/In Line Edger
My Echo GT-200R will not start. The plug is clean and wet. The switch is "On". Fuel (50:1) is new. It was working 2 weeks ago. Thanks, Chuck My echo gt-200r will start and idle but any time you push the trigger it bogs down and eventually dies. I can keep it running by manipulating the choke-run lever up and down but cannot I use it like this. I changed the plug and air filter and it still does the same thing.
If you have not had a solution by now (I know it's been a month since your post...), I just read on another help site that by cleaning the exhaust port would solve the problem. That port gets gunked up and the motor won't work if it can't "exhale" correctly. Good luck.
Posted on Jun 26, 2009
Try cleaning the screen that is located behind the spark arrestor screen cover. This is located on the muffler. Soak it with gasoline and clean it with a wire brush.
Posted on Jun 14, 2009
  • 33 Answers
If the plug is wet it is likely fouled. Install a new plug and it should fire up. If it sits for a week or more be sure you shake it before starting to remix any fuel / oil separation that may have occurred in the tank.
If it still doesn't start you need to make sure you are getting spark. You need air fuel and spark to run. With a wet plug we know you are getting air so it sounds like you're missing spark. New plug should fix you up. If not then look for a frayed or broken wire from the kill switch and check the switch itself.
Hope this helps out.
Posted on Jul 21, 2014
Echo gt 200r
spring drive shaft broke
Apr 17, 2014 | Echo Garden
Echo gt 200r
If little peaces getting carb. YES
Mar 23, 2014 | Garden
I can't get my yamaha dt 250 to start. batt is good, fuel is on, plug gets spark. It started 2 weeks ago when I bought it.
work your way back from the spark plug, when you crank it over take the plug out, is it wet? if so the fuels getting to the cylinder but the spark may be good but not be strong enough, try a new plug.
worse aspect is holed piston or piston rings and have next to no compression, chuck an eye through the spark plug hole with a torch and see if you can see any metal filings or damage. otherwise chuck a compression tester on it to be more accurate.
Sep 27, 2012 | Motorcycles
Echo cs-370 chainsaw wont start. running fine the day before. good spark. fuel wet at muffler. plug always wet.
Check air filter- is it clean?
Some plugs are without cilinder ok but if in place dont work. cahange the spark plug.
Mar 17, 2011 | Echo Garden
What type of fuel mixture do I use for 20760 Homelite gas trimmer?
Most likely not the answer you are looking for but here is a shot:
Pick up a bottle of the Echo brand 2-cycle oil. It will say "Extended Life" on the labeling. This is meant to run in Echo products, but it is a very FINE and well engineered oil. Mix it according to label directions for 50:1 ratios. (2.6 Oz. to 1 Gal. Gasoline)
When mixed at this ratio it provides MORE than adequate engine protection for ALL 2-Cycle engines, including those that run in 40, and 30:1 ratios.
I mix one 2-cycle tank to label instructions on the Echo oil for 50:1. It handily runs in my Echo chainsaws, non-echo trimmer, Poulan Pro leaf blower, etc. They all run different ratios, but THRIVE on the Echo mix without as much oily residue and smoke to boot!
CAUTION: I do not know of ANY OTHER MAKE of 2-cycle oil that CAN DO THIS *SAFELY*.
Remember:
Always mix your 2-cycle fuel starting with *fresh* gas.
Mix only that which you can use in 30 days.
Use 89 Octane fuel to make your mix in small piston 2-cycle engines.
Clean and re-oil intake filters @ every 10 hrs. operation time. Check and re-gap your plug when you service your filter!
DRAIN unused fuel from tank back into gas mix container. Restart and let engine idle to run any remaining fuel out of engine and carb. Storing fuel in ANY 2-cycle longer than two weeks is going to gum them up and nothing short of a carb rebuild will get them sputtering back to life again!
May 08, 2010 | Homelite Mighty Lite Lawn Trimmer
Echo Weed Eater bogs down.
Echo carbs have a little black plastic plug covering the High speed adj screw..CA air pulotion control bs..So get that little black blug out and give the screw a little turn open and u should be good to go..It worked for me..on a PBL 251 blower..My Echo weed wacker has the carb also..Go to Echos site and download the parts break down for your unit and look at the carb page..You will see the plug and HS,screw..happing wacking and blowing
Jul 05, 2009 | ECHO, Inc. PB-251C Handheld Blower
you need to make sure your plug is sparking
and if it is wet then the engine is flooded with fuel
press your primer bulb 5 or 6 times and use no choke and hold throttle open when trying to start it
May 25, 2009 | Garden
Worx 10" 18v 2 In 1 Grass Trimmer/In Line Edger Logo
2,603 people viewed this question
Top Worx Garden Experts
Tim Whalen
ray gallant
Wayne McNeil
Are you a Worx Garden Expert? Answer questions, earn points and help others
