Paper Jam 2 message on SCX-4200 not resetting despite clearance of all visible paper, resetting all doors/drawers, and powering off/on the unit.
  • kathryn_mich May 29, 2009
    Tried manual feed, jammed in the back. Pulled it out through the back of the machine, closed all doors, powered down and back up. Same message. Any other thoughts?
  • 489 Answers
There is a little plastic lever/flag which detects the paper at the rear, just after the heat section. I think on this model it can just about be seen by opening the rear door, it should be in the middle of the black lower paper guide section. The "flag" should be protruding slightly to be activated when the paper passes. However if it is stuck down (hence giving you false paper jam message) it will be more difficult to see! Use a decent torch to help see.
pls do it carefully and if it works rate this solution.
good night.
Posted on May 29, 2009
    Brigadier General:
  • 3,917 Answers
Finally put a sheet in halfway through the manual feed slot
- had door open doing it so I could make sure sheet went far enough so that the little two-pronged black flag right at front of the paper feed opening was kept pushed down by the sheet.
Then used Copy to copy the sheet - this got rid of the false alarm.
or
As the paper passes through the printer, it pushes against little black sticks that wobble back and forth to trip the different sensors. These little 'flags' usually kind of stick up in the middle of the plastic along the paper path. Look over the whole paper path and find all the little flags and make sure they're all moving freely. Sometime you can knock them out of place while removing a jam...then you can't get rid of the jam error.
Thank You for contacting Fixya and would appreciate if rated Fixya !
'paper jam' message - Printer not working!!
Clear all paper jams from the front and the back areas inside the printer. Then, turn off and restart. It should reset itself.
Aug 10, 2017 | Samsung SCX 4200 All-In-One Laser Printer
Samsung SCX-4521 "Paper Jam 2" won't clear
Hi there have you tried the door at the back of the machine as there maybe a piece stuck in the fuser unit. If not open the back door and check that there is a small black lever in the middle of the two rollers sticking up as this is the sensor arm that determines that there is a paper jam or not. If this is still there then the paper will be stuck just after the paper cassette within the paper path.
Hope this helps you.
Goodluck,
please don't forget to rate me as fixya..
Feb 01, 2008 | Samsung SCX 4521F All-In-One Laser Printer
My Samsung scx 4x20 printer shows paper jam in the dsisplay but there is NO paper jam. Can not get the error away and the printer refuses to print. What to do?
I suppose that the exit paper sensor in fusing section is broken (ussually when you pull out paper jam you can brake this little black or blue pawl). You can order and buy only this paper sensor pawl (very cheep).
pifonski
Feb 23, 2011 | Samsung SCX 4200 All-In-One Laser Printer
I have a samsung scx 4200 am getting the papaer jam error even when theres no paper jamed up there
Good Day Sir,
when paper jam occurs, Paper jam appears on the display.
Message Location of Jam
[Paper Jam 0] - In the paper input tray
[Paper Jam 1] - In the fuser area or around the toner cartridge
In the manual feeder
[Paper Jam 2] - In the paper exit area
hope this will help you. god bless
Nov 06, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Paper Jam
Yes ... or try a different **** of paper.
Jun 13, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Paper Jam
Good day, Check the table below about the problem of paper jams.
Display and Meaning
[Paper Jam 0] - Paper has Jammed in the feeding area of the paper input tray.
[Paper Jam 1] - Paper has jammed in the fuser area or in the manual feeder.
[Paper Jam 2] - Paper has jammed in the paper exit area.
hope it will help you.
Jun 04, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Paper Jam 2
We had the same proplem - did you check there was no paper jammed when you opened the back cover?
Sep 09, 2008 | Samsung SCX 4200 All-In-One Laser Printer
SCX-4200 jam
remove the toner box then clean the black colour roller with a wet smooth cloth.
May 05, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Paper Jam Error 2
Don't try a dozen things suggested by people online who's credentials are unknown. Go straight to the source.
I had the same issue and just went to www.samsung.com - looked up my model #, downloaded the PDF manual 86 pages and did a search for that error. It had step by step picture diagram of how to clear out the jam.
I just saved the company a few hundred on a service call to our printer sales/service vender.
Oct 28, 2007 | Samsung SCX-4100 All-In-One Laser Printer
[no paper] in SCX-4200
there 9is a paer sensor which senses when there r papers ,prob might b that either it is not functioning or on of the sensor is depressed
Jul 29, 2007 | Samsung SCX 4200 All-In-One Laser Printer
48 people viewed this question
k24674
