Question about Saeco Magic De Luxe Espresso Machine
The Coffee isn´t strong enough.
I had my machine serviced and waterelement changed. The grinderposition is on 4 and inside it is in the middle. But I cannot get stronger coffee.
pls help
Try to open the coffe group door and move to the right the quantity of coffe position (6g to 9g).
Posted on Jul 30, 2008
How do i fix my esam 3400 coffee grinder quantity?
I have change grinding from 7 to 1 ( it depends from coffee beans) and quality of coffee get much better (knob located inside the bean container).
Mar 09, 2016 | DeLonghi ESAM Coffee Makers & Espresso...
Coffee is too strong. How to dose Saeco Incanto classic? i tried to adjust SBS and beans regulator but coffee is strong and big coffee fills only quarter of cup.
press and hold the big coffee button while coffee is making,when you thing that amount is enough ,take of yuor finger ,Thats it. Next time just press the big coffee button once .
Sep 29, 2013 | Saeco Incanto Classic Espresso Machine
Ran vinegar through to decalcify. The diagnostic returns after only 3 or 4 additional cupsof coffee.
try real cooffe machine descaller not vinegar real descaller melt the scale away vinegar remove in little piece that can block our machine its not strong enough with descaller rinse the machine very good after its nasty stuff thanks
Aug 01, 2009 | Keurig B60 Coffee Maker
Won't perk properly
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Oct 21, 2008 | West Bend 13500 Coffee Maker
Water in the waste unit, coffee comes not strong enough, as use to, although the settings are for strongest possible and the coffee grinder is set to medium. My unit is 4075 but I think it is just the...
Your chute between the grinder and the brew unit is "glued" with coffee. Take out the the brew unit, clean it under water. Take a vaccum cleaner and put the pipe into the hole where the coffee falls into the brew unit. Move the bean container "hard" in and out ( knocking inside the maschin to loose the blockage). Switch in the main menue all to factory defaults. Put the grinder "level" into the middle again. start a brew unit cleaning process. After that you coffee must be ok again. Do not use oily beans or coated beans. the block the chute.
Mr. Cool
Sep 30, 2008 | Miele CVA4070 Coffee Maker
Coffee not strong enough
I had a problem like this with my first proper Gaggia. Cutting a long story short I found that the coffee I was using wasn't ground finely enough. The Illy stuff that comes in cans was ok, but pretty much everything else preground (incuding Lavazza!) was too coarse.
Sidestep the problem by getting yourslef a Rancilio Rocky grinder then you can adjust the grind in TINY increments for your perfect coffee moment...
Sep 24, 2008 | Rancilio Silvia Espresso Machine
The coffee is never strong enough
Be sure to use a very fine grind of a true Italian Roast espresso bean, and don't be afraid to tamp or pack the coffee a bit. Also, you don't want to overheat the pot...a low flame (or setting on your electric stove) will work best.
Feb 29, 2008 | Vev Vigano Kontessa Inox 6-Cup Espresso...
our waste coffee is it consistant like stay in 1 round piece or loose lock at it if it lock like it was fine grind i suspect that our machine dont grind fine enough our coffee should have that lovely brownish cream on top maybe grinder need ajustment it wasnt done properly at the compagny and you said you adjusted the dial in the grinder but what about the quatity of coffee look in our manuel fine grounded coffee good quatity of coffee our suppose to get that perfect expresso i think ajust our dial for quatity of coffee thanks for using fixya pierre
Feb 09, 2008 | Gaggia Titanium Espresso Machine
Coffee pot turns stops brewing in the middle of the cycle
Yup thats the Ticket - EASY FIX -
you have to clean the insides too people... lol.. The best way to do it is to buy citric acid crystals available from your local pharmacy. who knew huh? a couple of tablespoons in distilled water. Brew half the pot and let it sit for 30 min the brew the rest of the pot. Notice the color of your water after your done brewing. probably green from copper.. I could go into much more detail but thats the short answer... brew another pot or two of just plane ole water and bang your good go.. You should do this every month with any coffee pot for better tasting coffee..
Jan 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Weak Coffee
Yep, it's the one inherent flaw in the single serve machines - someone else decides what 'the perfect cup of coffee' tastes like.  Quite presumptuous, actually.
Solution I found to be acceptable:  Buy only the extra bold flavors (there's about 5 or 6 varieties) and brew using the small cup size button.  Yes, you only fill your mug about 3/4 of the way, but at least you get a decent cup of coffee.
The ONLY flavor I found to be strong enough when brewing with the large cup control button is DOUBLE BLACK DIAMOND...the rest is crap.
Dec 27, 2007 | Keurig B50 Coffee Maker
Saeco Magic De Luxe Espresso Machine Logo
129 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
