Question about Frigidaire Refrigerators
Frigidaire refrigerator - not cooling
Less then 3yr old fridge, power went out twice yesterday and fridge is not cooling -- can hear running. unplugged and plugged back in but temp gage still shows 70 on the fridge side and 60 on freezer side. I lowered the temp but still displayed the 70/60 Model is FRS6L7EESN
Is there a reset button - I can't find my owner manual
HVACRH20
  • 237 Answers
SOURCE: Fridge problems - frigidaire
Sort of sounds like the adaptive defrost board is bad and you are not going into a defrost cycle. Do you have ice build up on the lower interior freezer section? Are the vent slots full of frost/ice? Ideally, pull the freezer shelfs out and take the little aluminum panel off the interior back to look at the coils. Are they basically a block of ice and frost? The problem happens when the unit doesn't go into defrost cycle and the coils freeze up. That blocks the air flow in the freezer so you get frozen food at the bottom but soft stuff at the top. And the frige just can't get enough cool/cold air from the freezer section to cool anymore. Power surges or blackouts, etc. can just destroy the defrost circuit board. Without good air flow the unit is not going to cool properly.
Posted on Dec 20, 2006
VANMAN69
  • 23 Answers
SOURCE: freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Posted on Jun 29, 2007
Cerfer39
  • 709 Answers
SOURCE: Freezer and Fridge side not cooling
Sounds like your Defrost heater is burned up. It is located in the back of the freezer compartment behind the lower cover. Look at the base of the condensor. Two screws hold the heater and two wire connectors. The heater is in a glass tube. Measure continuity from one end to the other, you should see a few ohms. if it is open, your heater is definitely burned. I got a good deal on a replacement heater on Ebay. I think it was $17 including shipping. The heater being bad will cause major frost buildup in the back of the freezer and stop the Ice maker from working and damage food. Be sure to thorougly dry the freezer compartment prior to putting it back in operation. If too much moisture is present, the new heater will evaporate the moisture into the Ice dispensoer motor and solenoid that swtiches from crushed to solid ice. Hope this helps. it has nothing to do with your problem, but please Check out my website www.playstationclinic.com
Posted on Sep 25, 2007
SOURCE: Samsung RS2533SW freezer not cooling problem
I was having the same problem but with the refrigerator side. I know your problem was with the freezer side but I hope this works in your situation too. I was also told to unplug the fridge for 20 minutes and that did not do a thing to reset the circuit board in my situation. Unplug the refrigerator first. In the back of the refrigerator at the bottom is a metal panel. Remove that panel and off to the right side of it should be a white looking plastic box. Unscrew that box from the fridge and open it up to get to the circuit board. Remove ALL harnesses from the circuit board and capacitor. After doing so plug them all back in and reassemble everything back together and plug in the fridge. This should reset the board and allow it to function correctly. This is advice I got from someone else and everything as of today is cooling down like it should. I hope this helps everyone else out. Best of luck.
Also since the evaporator was frozen solid at the bottom on the refrigerator side I had to leave the power off until it thawed and then had to soak up all the water that collected at the bottom of it.
Posted on Apr 20, 2009
  • 102 Answers
SOURCE: Samsung RS2556 - Refrigerator side is not cooling - Freezer is fine
check the defrost circuit here is a helpful link to a service manual..in it t tells you how to initiate Forced Operation of defrost cycle.
http://www.servicematters.com/maytag_library/docs/SAM0059.pdf
Press Power Freeze and Fridge Temp. buttons for 8 seconds simultameously to get in the ready mode for a forced
operation.
The display panel will return to normal after 20 seconds in the ready mode.
At the ready mode, press any button(except Ice Type and Child Lock) once to start a pull-down operation, twice for a
defrost cycle for the refrigerator, three times for a defrost cycle for the freezer and the refrigerator, and finally four times
for cancellation of this function.
Another way to cancel this function is to simply plug out and in the power cord.
Posted on Sep 16, 2009
I have a Frigidaire FRC150FF fridge, the fridge light comes on but the fridge is warm. The frezzer compartment is working fine
How old is the fridge? Can you hear it running?
It could me many things. Could be anything from a dead compressor to a coolant leak.
Did someone change thermostat setting, maybe during a cleaning? There's a knob in the refrigerator section somewhere; see if it's turned to "Off" or to a less-than-cold setting.
If you hear the motor running, but it doesn't get cold, it probably doesn't have any refrigerant to compress. That could be recharged, but modern refrigerators are pretty tight, so that would also indicate a leak. With a leak, it will need recharging again sometime later.
Jul 22, 2011 | Refrigerators
I have a Maytag fridge MTF2193arw, the freezer is nice and cold with the fan working, but the fridge is not cold with no air movement.The unit is 3yr
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 15, 2010 | Maytag Refrigerators
5 year old refrigerator stopped cooling
Sounds like your refridgerant compressor or the motor driving it has bit the dust.  I am assuming it does not kick on or you can't hear it running.  Call a local appliance repair to get a quote, but 9 times out of 10, it is cheaper to replace the fridge.  A motor and compressor can cost upwards of 300-600 bucks.  That is just from my knowledge and your model may be higher or lower.  Best to get an appliance guy to take a look.
Mar 11, 2009 | Frigidaire FRT17G4B Top Freezer...
Frigidaire refrigerator making beeping sound
Unplug your refrigerator from the ac outlet, and 0open theref door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door. wallah it's fixed.
Dec 21, 2008 | Frigidaire FRS3R5EMB Side by Side...
My fridge stop cooling including the freezer section, motor is running okay. This is a icemaker fridgedair. Help , please.
Hello kenbarn
Welcome to Fixya
You said,
your fridge stop cooling including the freezer section, motor is running okay. This is a ice maker Frigidaire. Help , please.
What is the model number?
And how old is the fridge?
First try to unplug the fridge for 5 minutes and then turn it on again and see if we reset the system.
If not then you have a bad thermostat or leaking freon, and the pressure is too low to cool anything.
Or,if the compressor went then you may find this article I just read interesting!!!!!!
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Please remember to enter a rating before you sign off!
Thank You, HUUUM
Oct 05, 2008 | Frigidaire Refrigerators
Freezer fine /After power went out twice fridge not cold enough
In back of the refrigerator is a removable panel behind which is the compressor. Listen for a hum and a click. If you hear those sounds the compressor may have failed. Behind that same panel is a condenser where heat is removed from the refrigerating system. Make sure it is clean and check that the fan operates when the compressor runs.
Jun 07, 2008 | GE Â 17.9 Cu. Ft. Top-Freezer...
Not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Jun 03, 2008 | Frigidaire FRT18G4A Top Freezer...
Inglis Refridgerator
No the fan must stay or your Fridge will not cool, I hear this same problem from a lot of people that have new Fridges. all new fridges are louder that the older ones, check to see what setting you have your control set at. Try turning it down to 3 or B this will make it run less. other than that, if it is cooling ok. then that is just the way it is. I hope this helps
Dec 22, 2007 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Frigidaire 7.5 cu.ft. Top Freezer the fridge part doesn't cool; freezer is fine.
It should be under warranty, retry he is probably right, run for 24hrs and it should work ok, if you ever defrost you should turn off for 24hrs and leave the door open. Regards Advisor
Aug 08, 2007 | Frigidaire GLRT83TES Top Freezer...
Refrigerators Logo
132 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
