Question about Brother MFC-3240C All-In-One InkJet Printer
BROTHER MFC-3240C Please could you tell me what MACHINE ERROR51 means in Maintenance mode, and what I can do to clear it?. When not in maintenance mode, it shows either UNABLE TO PRINT, OR PAPER JAM.
  • 1 more comment
  • Anonymous Nov 16, 2007
    unable to clean
  • Anonymous Jan 10, 2008
    on start up shows unable to initiate go maintenece mode and shows error51
  • Anonymous Sep 09, 2008
    unable to clean
  • 832 Answers
The printhead cant travel without prob in its rail. Try to pick up the paper which might stuck somewhere.
Posted on Oct 22, 2007
SOURCE:
I have a brother MFC-3240C 5 in 1 Multi Function and cannot find where I plug the printer in to the computer. Can someone please tell me where the printer port is on this machine. Thank you
On the back of the printer there should be a place to plug in at USB B cable. This is a square whole (check an image search for what USB B looks like). That cable then converts to a standard USB to plug into your computer.
Thumbs Up!
May 04, 2011 | Brother MFC-3240C All-In-One InkJet...
I have a Brother 5 in 1 Multifunction MFC-3240C and wondering where you plug the printer cable in to the machine? Could you please tell me where the printer port on the printer is located. Thank you very...
This printer connects via USB cable and not thru a parallel printer cable. The USB connector is actually inside the machine. Here is a small image of where the connector is and a link to the quick start guide.
here is a link to the entire document
http://www.brother-usa.com/ModelDocuments/Consumer/Quick%20Setup%20Guide/QSG_MFC_3240C_3340CN_EN_376.PDF
My MFC-3240C Brother Printer reads: Unable to Clean. What can I do
Hi you can try
This works with most Brother printers
Procedure how to reset the error 46 error (unable to clean). This can be done on every Brother inkjet machine with a numeric keypad.
- Machine off
- Switch on the machine while holding down the “menu” button until all the leds are flashing on/off. Now you are in “maintenance” mode.
- press 80
- press the “mono start” button several times until you see “purge: xxxx”
- press “2783” in order to reset the purge counter. You will see: “purge:0000”
- press “99” to exit the maintenance mode
Now you are able to print again, but actually your ink absorber box is now full with ink. Ink flooding can happen if you don’t replace this ink box
Also can try.
Reset code.
Press menu then*2864 within 2 seconds (maint should be on the display and all the lights should be flashing, if not try again) press 80
then keep pressing black/mono start button until screen displays ‘purge count’
press 2783 to reset purge count
press stop/exit key
press 99
machine should return to normal
May 10, 2010 | Brother MFC-3240C All-In-One InkJet...
My Mfc 3240 Brother Printer will not Print and the readout says to get the trouble shooting and maintenance guide
When ever you get an error message like the one you are describing, there should be a numerical code with it.
Most of the time when you get an error code like this, it is a mechanical problem with the machine.
Try unplugging the power for about 5 minutes to see if that clears it out, otherwise you might as well replace it. A machine like this has been discontinued and is not worth paying for repairs.
Mar 25, 2010 | Brother MFC-3240C All-In-One InkJet...
MFC 3240C seems to dead
unable to clean means the ink absorber is full and you need to have the absorber box replaced and the counter reset at a shop. The job usually costs less than a hundred dollars, but the new mfc 490 is selling for about $129.00 with a one year warranty.
Oct 02, 2009 | Brother MFC-3240C All-In-One InkJet...
How to clear memory from fax? MFC-665CW
Hi Jodi,
I have a Brother MFC 8860 DN Laser.
Just contacted Brother and they told me the following:
1. Switch off machine from Mains
2. Press and hold the Red "Stop/Exit" button
3. Switch on machine from mains.
It worked fine with me and the memory is back to 000 now.
Hope this helps.
Sep 18, 2008 | Office Equipment & Supplies
Unable to print
Brother Error Codes
RAM clear (most models)
Quickly press function * 2 8 6 4
Display should read maintenance
Press 0 1 for a full ram clear, or 9 1 to retain user data
Display should read reinit for a few moments then redisplay maintenance
Press 9 9 to exit the maintenance mode
Other maintenance mode switches:
01 ram clear (see 91 below)
02 scanner initialize (feed a white sheet, then a black sheet)
05 white level
09 print test
10 modify soft switches
11 print configuration list
16 panel test
19 CML test
20 signal test
21 tonal test
23 filter RX
54 scan edge
55 scanner area
66 test print memo
75 display drum life (if enabled on laser models)
76 reset drum life counter (laser models)
91 parameter initialize (user programming remains intact)
95 protection
B2 error = scanner or power supply error
Brother 950/980: On copy or transmit they may produce black pages. Prone to bad scanner (CCD). Brother may provide a replacement CCD at no charge to the original owner. Sometimes leaving the unit unplugged for a few hours will solve the problem temporarily.
Brother HL600 series laser printer toner will work in the laser fax & multifunction machines (part number TN100HL = TN100PPF). Drum units may be interchangeable as well (?).
Brother 1350/1550/1950: Problem: Record paper jams. Solution: Replace upper shoot. P/N UF6058001. Although there seems to be nothing causing the jam, the upper shoot gets stress marks on the ends. Replace even though it is not broken. (Thank you David Price, dyprice@earthlink.net)
Thermal Transfer Machines: Only one side of the page is printing. Caused by the printhead latch being cracked. The latch is blue in color there is one on each side of the printhead, replace both latches
Nov 04, 2007 | Brother MFC-3240C All-In-One InkJet...
Brother MFC-210C stuck in "please wait maintenance"
Press menu then start mono (b/w) then 4x arrow-up-button. Machine will be in maintenance-mode: What error code does the display show off?
Sep 24, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-3240C All-In-One InkJet Printer Logo
265 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
