I sent a text doc to my hp 4315 and it seems to have plugged up my queue and i cant delete it. My printer will not print anyything because this is in the way. I tryed reinstalling but it wont let me delete the printer with a doc in the queue. Any ideas???
First, I would try canceling the document either at the printer (hit cancel if it has already been sent) or at the computer.
You can do this by going to start -> settings -> printers and faxes double click on the printer to open it right click on the offending file and hit delete
It sounds like both of these have been done already. So...next option.
Second option - Restart the print spooler Go to Start -> Settings -> Control Panel -> Administrative Tools -> Services Click on the "Print Spooler" Select Restart
Third option - delete the document from the spooler Stop the Print Spooler by following the instructions above and clicking "stop" Delete all files in the c:\windows\system32\spool\printers directory Restart the print spooler.
CAUTION!!! - This will clear out both the offending job and any other jobs that have been sent to the printer after the offending job. If you have a number of other jobs, you may wish to clear out only the offending job from the printers directory.
Hope this helps - flub
Was this helpful?
Yes
No
4 people thought this was helpful
Asker's Testimonial
Thank you so much! it all worked great
" - markarama
Click on Start, then right-click on Computer (Vista) or My Computer (XP) and select Manage from the context menu. Expand Services and Applications and click on Services. In the right-hand window, right-click on Print Spooler and select Stop. Open Windows Explorer and navigate to C:\Windows\system32\spool\printers/ Open the folder for the printer in question and delete all of the files from this directory. Go back to the Service Manager and Start the Print Spooler again.
You should now be able to print.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for HP Officejet 4315 All-in-One
my scanner was working fine a few moments ago and then i tried to scan a piece of paper i ripped out...
(More)
my scanner was working fine a few moments ago and then i tried to scan a piece of paper i ripped out of a magazine. it came onto my screen with a bunch of multicolored lines through it. i figured it might be the type of picture so i tried a normal picture and now nothing will work. i tried to go inside the machine and everything seems fine.. help?
