OK if nothing has Struck the door (Like a foot...etc) then that is OK. If water is not draining, Then it is the Drain Pump. About $30 on Amazon. It needs to be replaced cause it is bad and is causing these other issues. Unplug the machine and disassemble it, replace pump and reassemble. If this is above/below your pay grade. Then call Sears and have them do it for around $130.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
SOURCE: Need code/s for LG WM1832CW to have washer do a spin/drain only
1. press POWER button to turn om.
2. press SPIN SPEED button only.
3. press START/PAUSE button/
SOURCE: LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
SOURCE: lg-wm1832cw front loader washer won't spin and drain
did anyone solve this problem? Mine is doing the same thing... uggh!
SOURCE: Got an LG front load washer WM2277HS with an error
Replace the Drain Pump. Its very cheap to replace, so do not worry. The impeller magnet was most likely damaged by a small object or normal wear & tear,
If you want to be sure, first remove it and attach power to its 2 pins.
Good Luck :-) - J.Q
* If you found this solution helpful, please vote positively.
Testimonial: "You saved me!!!!! I would have never figured this out without your help."
Thanks, Jeremy. I tried this; the "dE" code comes on at start now, won't even start first cycle.
