Question about Bulldog Remote Starter & T-Harness Kit for 95-03 Chevy Blazer/Chevy S-10 Pi
I installed a remote starter and it wont start with remote
I installed a remote starter on my 1992 Blazer and need to know if it has any type of factory security on it that could be causing it to not start? ihave connected all nescesary wires ; according to the install manual and vehicle still wont start with remote
  • 344 Answers
No this does not have factory security
Posted on Sep 29, 2009
  • 436 Answers
Not in your truck and not in bulldog units
Posted on Sep 01, 2009
98 chevy blazer won't start new fuel pump, new starter, battery good. will not turn over. ignition switch changed. its not getting fire to the starter.
Have you checked the purple wire directly at the starter for power when the key is turned to start? Is the vehicle equipped with any type of remote start or alarm system?
May 20, 2015 | 1998 Chevrolet Blazer
Starter wont turn over
Most of time the reason for a chevy starter wont turn over stems from no power blown ignition fuse. Dead battery ,dirty battery cables, loose connection at the starter, bad starter solenoid or burnt starter motor.Start with easiest and cheapest things first.Check any fuses marked ignition,remove battery cables and clean with wire brush clean the battery post also. While the battery is unhooked charge and load test, check the connections at the starter. If the fuses are good and battery is ok. The cables are clean and connections are tight you will need to remove starter and solenoid and take them to be tested
Aug 11, 2012 | Haynes Chevrolet and GMC Pick-ups Repair...
1999 chevy blazer wiring harness diagram for remote start
Large purple wire is your starter engagement wire, I believe you will have to tie into more than that wire to get your remote start to work properly, maybe get me brand and model number so I may research more and point you in the right direction as far as installation goes.
Nov 30, 2011 | 1999 Chevrolet Blazer
2000 Chevy Blazer Won't Start
You can check the manual that came with the Remote starter.
If you do not have one try look it up on line.
You can try call the people that install that kind of remote starter.
Some started do a lot more than start your car and the only way to know is to look at the manual.
You are trying to find out if it is has a ignition kill command.
Mar 16, 2009 | 2000 Chevrolet Blazer
Not on Just the Remote Starter. Did you go to the Bulldog Website and get a Detailed Wiring Diagram for Your Truck? If not Get one and Retrace the Steps. You missed one Somewhere. Got it on my 95' Silverado and have had no Prob's
Dec 30, 2008 | Bulldog Remote Starter & T-Harness Kit for...
Bulldog Remote Starter On 92 Blazer-Cranks but no fuel pump
I've wired several of these and you have likely hooked up the wires wrong its not giving power to the right wires at the bottom of your steering column...........re check your connections
on your truck there are 3 wires that need power for the starter to work they are the orange,pink and brown
hope this helps!
Bulldog Remote Starter & T-Harness Kit for 95-03 Chevy Blazer/Chevy S-10 Pi Logo
453 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
Matthew Spark
Matthew Spark
John
John
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
