Question about Polaroid I533P Digital Camera
Not turning on, light blinks once that's it
My polaroid i533 only works some of the time. If I haven't used it in a while it cuts right on sometimes the color in the screen is a little off but that's it. If i try 2 use it soon after that the green light blinks once but the screen stays black. No beeps nor error message or anything.
  • mysweetempre May 29, 2009
    thx! i'll try that as soon as I can get 2 trun on. lol
  • 744 Answers
Hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...thank u!!!
rate me!!
Posted on May 29, 2009
I533 polaroid camera beeps and turns off
There are a couple of possibilities here:
i'm assuming that this camera uses a SD memory card. You have most likely bought yourself an SDHC card. The cards will look exactly the same, except for their name. SD cards only go up to 2GB, while SDHC's go much higher....sometimes the SDHC card will cause camera's to do this because it is not supported.
the other possibility is that you have a defective battery and it doesn't hold a charge. You could test this with a digital multi meter.
the last possibility is that there in internal damage/falty wiring
hope this helps,
Thomas
Feb 28, 2010 | Polaroid I533P Digital Camera
Whenever i turn my i533 digi cam on, the lens pop out and i can see the green light blinks. However, the LCD has no display and i hear 3 beeps. The camera would automatically shuts off, but sometimes it...
You've got to clean the contacts on the battery, the battery compartment and you charging station. This can easily be done using a Q-Tip "dampened" not soaked, in rubbing alcohol. Clean them all well and then if you can find a drinking straw blow dry the battery compartment and wipe down the battery with a fresh cloth or paper towel. Do the same to the station. If all this fails, replace your battery. The battery indicator on these cams is "not" always accurate.
Sep 06, 2009 | Polaroid I533P Digital Camera
Polaroid camera i533
well sure u just go to
Chandrakanth
+(91)-9346340947,9392416633
1-8-3/23/7 1st Floor, Hotel Sunanda, Chikkadpally, Hyderabad - 500020
Oct 24, 2008 | Polaroid I533P Digital Camera
My Polaroid i533 digicam won't turn on
Try checking to see if the lens is a little crocked, look at it real closley.If it is then try and pop, or bend the lens back into place, and then turn your camra on and the camra may work propelry.
I had the EXCACT smae problem, and it worked for me.
So it may hlep you too.
Aug 14, 2008 | Polaroid I533P Digital Camera
Polaroid i533
Check you camera instruction book. The card may be the wrong one or two large or???
Jul 26, 2008 | Polaroid I533P Digital Camera
Polaroid i533
Lens failure. There is no way to fix it.
Jul 24, 2008 | Canon PowerShot A520 Digital Camera
It Turns On Then It Turns Right Back Off
I put Rechargable Duracell Batteries in and now it takes pictures and turns on without a blank screen or shutting back off.
Jul 12, 2008 | Polaroid I533P Digital Camera
Polaroid I533P Digital Camera Logo
254 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
