Question about Epson Stylus Color 640 InkJet Printer
All panel lights flashing. Printer seems to initialize, then reverts to all lights flashing.
With new cartridges installed, all panel lights are flashing. Printer seems to go through startup sequence, but reverts to all panel lights flashing.
    Novelist:
  • 152 Answers
Depending on the particulars of printer cartridge technologies, you may have a faulty cartridge, or there is a paper jam, also try powering the printer off, then unplugging it for 1 minute, then re-power the device and see waht happens. If all else fails, it's cheaper to buy a new printer / all in one solution than having a controller chip repaired. Current inkjet printers are in the range of $65 - $150 depending on format, and functions. labor, and parts will more than likely cost you more that a new inkjet printer if you have it repaired.
Check this PDF for more detailed information about your printer, espectially check out the " Checking the control panel lights " under " troubleshooting"
http://files.support.epson.com/pdf/sc640_/sc640_u1.pdf
Posted on May 29, 2009
  • 744 Answers
Hi....take it to a tech to check about the system control chip... the control chip would have gone bad... and they will replace u with a new chip..or else Try manually moving the head carriage back and forth a few times!
Also check, if there isn't some piece of paper lodged inside, if yes try to remove it carefully!..
these are the possible solutions u can try out...
thank u
rate me
I am refilling the black ink of my canon printer using continuous ink container but the black color doesn't flow into the end of the hose and it didn't print at all, please help
  • Check the printer's power/alarm light. If it is flashing orange, count the number of flashes. Look up the flash code in your printer's user manual to diagnose the problem.
  • 2 Remove and reinstall the ink cartridges if the power/alarm light flashes 5, 7 or 15 times consecutively. This indicates that the issue is a cartridge error, an incorrectly installed cartridge, or an unrecognized cartridge. These errors can be fixed by reinstalling the ink cartridges. Make sure that you are using the correct ink cartridges for your Canon printer.
  • Turn on the printer and open the front cover. The ink cartridge holder should move to the replacement position.
  • 4 Verify that the colored ink cartridge is inserted in the slot on the right and the black ink cartridge is inserted in the slot on the left. Swap the cartridges and reinstall them in the correct slots if necessary.
  • 5 Check to see that both ink cartridges are level with one other and parallel to the top of the ink cartridge holder. If either cartridge is wedged at an angle, gently apply pressure to the cartridge until it clicks into the correct position.
  • 6 Close the front cover of your Canon printer and wait while the printer initializes the newly installed cartridges. This can take a minute or two.
  • Jun 12, 2011 | Office Equipment & Supplies
    How do I change the ink on the Epson Stylus TX300? Thanks.
    Just follow the following steps:
    #1
    The printer should be turned on and not printing. Refer to control panel to see which cartridge is empty.
    #2
    Hit the printer "Menu" button until you get to "Change Cartridge." At this point, hit "Color Copy" to move the cartridges into proper replacement alignment.
    #3
    Open the top of the printer and pull open the tab for the ink cartridge you are replacing. The black cartridge can be found to the left, while the color cartridge is on the right.
    #4
    Pull the cartridge out.
    #5
    Get the new cartridge ready to install. Before putting it in, pull off the yellow tape on the bottom.
    #6
    Push the cartridge into the appropriate slot, and click the tab securely shut.
    #7
    Close the top of the printer until it clicks securely.
    #8
    Wait 30 seconds or so for the ink to initiate. The on button will flash during the process and then stop flashing and stay lit when it's done.
    Thanks
    Oct 03, 2010 | Office Equipment & Supplies
    I've just installed both a new black cartridge and a colour one but after having to clean the heads a number of times to try and get the print quality back up to scratch the printer is now refusing to do...
    .. is the light flashing alternate? if yes, then the printer porous pad need to be replaced and reset ink counter.. install your printer driver and status monitor and you should be able to find out whether it's the ink empty or maintenance needed. For this model.. I am sure your waste ink counter is full...
    May 20, 2010 | Epson Stylus 680 InkJet Color Printer
    I have installed a new black ink cartridge. "Ink is out" comes up when I try to print. It is properly installed and is the second new black ink cartridge this has happened with. The "On" and 'Ink" lights...
    I have installed all new cartridges. "Ink is out" comes up when I try to print. It is properly installed and is the second set of ink cartridge this has happened with. The "On" and 'Ink" lights do not stop flashing. The printer does not see the new cartridges.
    Jan 04, 2010 | Epson Stylus CX4800 All-In-One InkJet...
    Can u use the scanner on a hp pcs 1610 all in one inkjet printer without the color ink cartridge?
    Hi, the answer is no you cannot, the printer will only work if both cartridges (black and color) are installed, if you install just one the check print cartridge light will flash.
    Hope this helps
    Muzzi_123
    Nov 14, 2009 | HP PSC 1610 All-In-One InkJet Printer
    Light keeps fashing for cartridge
    Here is something to try:
    1. Make sure the new kit is installed and the printer is turned ON.
    2. Open the front panel.
    3. Hold the Cancel button in until the front panel LEDs flash.
    4. Close the front panel
    Sep 29, 2009 | Lexmark E250d Laser Printer
    Installed new cartridge in canon pixma mp210 & now can't print
    The printer needed to be reset.
    Unhook the printer then take out the new cartridges.
    try to very gently clean the contacts also make sure the contact on the new cartridges is clean.
    Let it dry for a few minutes assembly.
    Plug it. My printer is reset by pressing the start button and hold it down until it beeps 6 times.
    You can check your manual how to reset yours.
    I hope it work for you.
    Mar 16, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
    Hpdeskjet 940c printer
    make sure thats the right one and to test page and cean the heads if there still not ok change the cartridge again
    Jan 03, 2008 | HP DeskJet 940c InkJet Printer
    Hp 1350 all-in-one
    When power is applied to the all-in-one for the first time, the power light is solid and the check paper, check print cartridge, black copy, and color copy lights flash, the display will be blank, and the all-in-one will not respond. One or more of the following symptoms will also be observed: The all-in-one keeps turning off Cannot print, scan, or copy The print carriage will not move Windows plug and play (device detection) does not occur The all-in-one does not respond when buttons are pressed, including the power button. SOLUTION: This problem occurs for two reasons: the front panel cover was not installed or the ink cartridge access door was not closed before plugging in the all-in-one. The front panel overlay must be correctly installed before the power cord is plugged in. Follow the steps below to correct the problem: Disconnect the power cord. Lift the scanner lid and carefully line up and install the front panel overlay. Plug the power cord in. The print cartridge access door must be closed before the all-in-one is plugged in for the first time. The all-in-one cannot complete its first initialization until the door is closed. Follow the steps below to correct the problem: Disconnect the power cord. Locate and close the print cartridge access door. CAUSE: The all-in-one initializes when it is plugged in for the first time. While initializing, the all-in-one scans a bar code on the under side of the front panel cover requiring that the front panel cover be in place and that the scanner be operable. The scanner cannot operate when the cartridge access door is open On light (green) - On Check Paper light (amber) - Blink Simultaneously Check Print Cartridge light (amber) - Blink Simultaneously Black copy area backlight (green)- Blink Simultaneously Color copy area backlight (green) - Blink Simultaneously Issue Front panel overlay is not attached at all or not attached properly Solution Turn Off the all-in-one. Attach front panel overlay as instructed on Setup Poster. Turn On the all-in-one.
    Sep 06, 2007 | HP PSC 1350 All-In-One Thermal Printer
    Epson Stylus Color 640 InkJet Printer Logo
    199 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
