Posted on May 29, 2009
When i rip a cd on itunes it looks ok but when i open file location a few of the tracks are marked not av
Anonymous
Level 1:
Novelist:
  • Contributor 166 Answers
  • Posted on May 29, 2009
Anonymous
Contributor
Level 1:
Novelist:
Answers
166
Questions
Helped
58058
Points
21
Do not misunderstand this problem with media players.
In your case, your media player is working fine but the OS running over your mobile system is not able to properly perform I/O(input/output) operations.
So try to restore your mobile settings to factory configuration by vendor's disk.
After that it will properly marked and played on your cellphone's media player.
Rate this solution if it was helpful to you.
Thanking you.
With Regards,
Shyny
3answers
My friend has given me an mp3 player to download cds on to but i'm not sure how to do this? I thought i might try spotify or itunes but i don't know if you can download cds off either of these sites on to...
Go to the player manufacturer's website. They should have software you can download that may make the process much easier. If not, on plugging the player into your computer, it should recognize it as an 'external' drive in which case you can treat it as you would with any external drive.
tip
How to convert M4P music to MP3
The music and audiobook files you purchased from online stores are protected by DRM. But most mobile players doesn't support DRM format. However you can burn the protected music files to CD-R/RW disc to make an audio CD, then use CD ripper softwares to rip the audio cd track back to MP3, WAV, WMA etc.
There are two ways to convert M4P music to MP3. One way is to use itunes for sophisticated computer user, another way is to use third party program for beginner, which is much easier.Following the steps , then get your job one easily.
Part one: Using itunes to converting M4p music
Step 1: Run iTunes and set burner options firstly. You can choose
Edit>Preferences>Advanced>Burning menu and then select your CD burner.
Note: If you don't have a physical burner, you may use a virtual burner program, NoteBurner. Go to http://www.noteburner.com to download the program. After you install it, you can choose NoteBurner Virtual CD-RW as what you do in the first step.
Step 2: Create a new playlist in iTunes and add all m4p files you want to convert to this new list.
Note: If you use NoteBurner, you need to select the output format in NoteBurner. After you click Settings button, you can set the output as MP3, WAV and WMA.
Step 3: Click Burn Disc button in iTunes to starting the burning. If you use NoteBurner, this is the final step since the program can rip back the burned music automatically. The output folder will be open automatically after all music finishes encoding.
Note: If you burn the m4p files on real CD, you need to rip the music back in iTunes. Open iTunes Edit>Preferences>Advanced menu and click small Importing tab inside the Advanced tab to choose "WAV encoder" or "AIFF Encoder" in the "Import Using" dropdown. In the left-hand panel under "Devices", select the CD that you burned
Step 4: In the main window opposite, deselect any CD track(s) you do not want to convert. Right-click or control-click over them, and choose the "convert to AIFF" or "convert to WAV" option.
Step 5: After the conversion, you may find the converted file at C:Documents and SettingsAdministratorMy DocumentsMy MusiciTunesiTunes Music
Part two: Using third party program to convert M4p music
Comparing to the previous method, the following is more simple and easier, you can finish the job with just several clicks.
Step 1: Free download M4P Converter, install and run it.
Step 2: Clicking "Add" or directly drag-drop protected M4P files. Batch M4P to MP3 conversion supported.
Step 3: In the "Setting" button, choose MP3 format (*.mp3), you can also custom the music.
Step 4: Click the "Start" button to start converting M4P to MP3. After successful converting M4P to MP3, the result shall be stored on the "Output path" folder. Then you can use them for playing without any limitation.
on Oct 28, 2010 • Computers & Internet
tip
How to Play iTunes Music on Windows Media Player
There's a good chance when you buy music from the iTunes Store that the files that you download will be copy protected by Apple's FairPlay DRM system. It's a great system that protects the rights of the artist and publisher by making it difficult for the consumer to distribute copyrighted material. However, DRM can also be very restrictive by stopping you playing legally purchased music on your MP3 compatible hardware. So, what happens if you want to play your DRM'ed music on a non-iPod?
This tutorial will show you a way to produce DRM-free music that doesn't require any special software that you would normally need to buy. All you'll need is the iTunes software, and a blank CD (preferably a rewritable (CD-RW)).
Before we begin, check for any updates that are available for your iTunes installation, or download the latest version from the iTunes website。
Configuring iTunes to burn and rip an audio CD
CD Burner Settings: In order to set up the iTunes software to burn an audio CD, you first need to go into the settings menu and select the correct disc format. To do this, click on the Edit tab on the main menu and select Preferences from the menu list. On the preferences screen, select the Advanced tab, followed by the Burning tab. First, make sure your CD burner is selected from the drop-down menu alongside the CD Burner option. Next, Select audio CD as the disc format that is to be written by your CD drive.
CD Import Settings: While you are still in the preferences menu, click on the Importing tab to access the CD ripping settings. Verify that the On CD Insert option is set to Ask to Import CD. Next, set the Import Using option to a format of your choice; the MP3 Encoder is your best choice if you want to import audio CDs as MP3 files that play on virtually all compatible devices. Choose an encoding bitrate from the Setting option; 128Kbps is the normal setting that is good enough for the average listener. And finally, make sure the Automatically Retrieve CD Track Names From Internet and Create File Names With Track Numbers and both checked. Click the OK button to save your settings.
Making a custom playlist
To be able to burn your DRM copy protected songs to audio CD you will need to make a custom playlist (File > New Playlist). You can add music tracks to a playlist easily by dragging and dropping them from your music library to your newly created playlist. For instructions on how to achieve this, why not follow our tutorial on How to Create a Custom Playlist Using iTunes.
While creating a playlist, make sure that the total playing time (displayed at the bottom of the screen) doesn't exceed the capacity of the CD-R or CD-RW you are using; typically, the total playing time of a 700Mb CD is 80 minutes.
Burning an Audio CD Using a Playlist
Once you have created a playlist, simply left-click it (located under the playlists section in the left pane), and then click on the File tab on the main menu, followed by Burn Playlist to Disc. The CD drive tray should now automatically eject so you can insert a blank disc; ideally use a rewriteable disc ( CD-RW) so you can reuse it multiple times. Before iTunes starts burning the DRM protected songs, it will remind you that creating an audio CD is for your own personal use only; once you have read this notice, click on the Proceed button to start burning.
Ripping an audio CD
The final step in this tutorial is to import (rip) the songs that you burned onto audio CD, back to digital music files. We have already configured iTunes (step 1) to encode any audio CD that is inserted into the CD drive as MP3 files and so this stage of the process will be mostly automatic. To start ripping your audio CD, simply insert it into your CD drive and click the Yes button to start. For a more in-depth look at this process, read the tutorial on How to Import CD Tracks Using iTunes.
Once this stage is complete, all the files that have been imported into your music library will be free from DRM; you will be able to transfer them to any device that supports MP3 playback.
Note:The only downside in using this method is that if you have a lot of files that you need to convert, then it ends up a slow and tedious process. With this in mind, use a legal drm removal tool if you have a large quantity that you need to convert.
on Aug 25, 2010 • Computers & Internet
Will iTunes cause my DVD burner to be unrecongnizable by Slideshow Expressions? How can I fix this?
Best brmoff
I found the following information on Individual Software's website. Yes, music downloaded using iTunes may indeed cause problems with SlideShow Expressions. I include a link for more reading; go to 'frequently asked questions': http://support.individualsoftware.com.
Why won't my music files work in Photo & Video Expressions?
Photo & Video Expressions is not compatible with audio files that have been protected by Digital Rights Management (DRM) functionality. Most audio files purchased online through Internet music retailers like iTunes, Urge, or Rhapsody are encrypted with some form of DRM. Similarly, audio files that have been extracted from a CD or DVD (the process known as "ripping") using certain media applications (iTunes, Windows Media Player, etc.) often have default settings that encrypt the files extracted.
There is no way to use DRM audio files purchased from online music retailers with Photo & Video Expressions. However, if you want to use music and audio files that you have extracted from your CD collection, then all you have to do is change the ripping setting in your media application before you extract the files to your computer.
To Change Your Ripping Settings:
iTunes
  1. Click Edit on the iTunes menu bar and click Preferences.
  2. Click the Advanced tab in the Preferences window.
  3. Click the Importing tab.
  4. Click the Import Using drop down arrow, and click MP3 Encoder.
  5. Click the Settings drop down arrow, and click the desired sound quality.
    (NOTE: The higher the kbps (kilobits per second), the larger the file.)
  6. The Custom... setting allows you to adjust more specific settings.
  7. Click the OK button when you are finished.
  8. Click the CD title in the left pane of the iTunes window.
  9. Click the checkbox for each track to rip, and then click the Import CD button in the lower right corner of the iTunes window.
  10. Once the extraction process has completed, you can use these audio files in your Photo & Video Expressions project.
Tried to download 50 albums to i tunes library,mp3
yes, try ripping the cd or dvd by placing in tray........open itunes and rip the track (s) you want...(itunes will convert the mp3 to mp4)....once all your track you want are done.......take the music file from the top of left hand side (make sure ipod is connected for this) and click hold and drag down to the ipod music folder (this will take a while depending on large the folder is) once you are finish never ever just unplug it you will lose your files EJECT from itunes............
tip
How to transfer windows media player muisc to iTunes
You may have some music on Windows Media Player, and you want to add them into iTunes library for your new iPod or iPhone. Or you may want to move your iTunes bought music to Windows Media Player for portable devices such as Zen, Zune, Phone, Sansa, Archos, MP3/MP4 Player, etc. It’s easy to do that. And this guide will show the steps to do the job.
Part1. Transfer Windows Media Player music to iTunes
Step1. Open iTunes and select the File -- Add Folder to Library menu.
Step2. Browse to your Windows Media Player music folder. iTunes will ask you where your songs are located, which by default will be in your My Music folder on Windows XP, or in your Music folder on Vista.
Step3. Convert Windows Media Player songs to AAC format (.m4a). If you have files in WMA format, you will be prompted to convert those WMA files to AAC. This is a necessary step if you want those tracks available to play on your iPod or iPhone. If you have a large music library in WMA format, converting WMA to AAC may take a long time. Plan to do this at a time when you can leave your computer on and walk away to do something else for awhile. You can also import your WMA files as MP3 instead, which also allows them to work with your iPod, but makes them more portable if you buy something else in the future.
iTunes doesn't modify your original music files from Windows Media Player. It leaves those songs in their original location and makes copies in your iTunes music folder.
Part2. Transfer iTunes music to Windows Media Player
Because iTunes music has DRM protection, you can't easily import the music into Windows Media Player by drag and drop. There are two ways to transfer protected music from iTunes to Windows Media Player.
Method1. You can use iTunes to burn the music to a blank CD at first, then use Windows Media Player to rip the music CD, the DRM protection will be remove during the ripping process, then you can rip the CD into WMP library. This way is good for tranferring a few music. For large mount of music, it would take a really long time to transfer music.
Method2. If you don't have blank CD disk or you have many iTunes music need to transferred to windows media player. You can use DRM Media Converter. It can legally convert the protected iTunes music to non-protected MP3 music, then you can easily drag and drop the MP3 music into Windows Media Player.
Step1. Download and install the DRM Media Converter , the file size is about 7 MB. I have scaned it with Norton Virus protector and AVG spayware protector, it's safe without any warning.
Step2. Run the DRM Media Converter, Click Add to import iTunes music, which by default will be in My Music\iTunes\iTunes Music .Or you can run iTunes, click Edit -- Advanced Tab, there you will see where your iTunes media folder location.
Step3. Set the output audio format as "MP3 - MPEG Layer-3 Audio (*.mp3)"
Step4. Click Start to run the conversion, it will take a little bit time to finish the job, then click Browse to located your converted mp3 files, drag them into Windows Media Player, done.
on Feb 05, 2010 • Computers & Internet
The drive & itunes will not read any disc. Even if a disc is put in and the drive is clicked upon it says, 'please insert a disc'
Have had the same problem for a LONG time... the workaround I use:
Open Windows Media Player, go to Tools ---> Options ---> Rip Music Tab ---> Rip Settings (format) ---> choose "mp3" (and choose bitrate, 256 kb/s is a good bit-rate-to-file-size ratio)
Rip the songs to your hard drive as .mp3, close Windows Media Player, and open iTunes....
Go to File ---> Add file to Library ---> find and highlight new .mp3 and hit ok. iTunes will import as .mp3, you can then right-click on the file and convert to .aac if you choose.
Remember, is just a workaround... hope this helps!
-- RT
PS - Please don't forget to vote!
9helpful
9answers
EZ Audio Converter does not export files to iTunes
I've had exactly the same problem, and so far no resolution from Ion. A small bit of good news: the .wav files are on the hard drive, although without any track info. At least on Vista, they are in username/AppData/Local/Temp. The files are name Temp0, Temp1, Temp 2, ...
You can use iTunes to add these files (File/add file) and then convert them to .mp3s, or whatever format you prefer. Or you could convert them first using the tool of your choice, such as Audiograbber.
This is inconvenient, but a lot better than re-ripping the vinyl after EZVinyl hangs.
Won't recognize an MP3 format CD
Usually a disc with audio files is not encoded with MP3's, but, rather, audio files. You can check this by manually opening the disc (right click on the player when the disc is in it), and looking at the files. If you only see marker (files of a few kilobits) in "MP3" format, then the disc needs to be "ripped" into MP3 format.
The ratio for audio to MP3 is 10 :1--this means a CD of 700 MB size with 10 tracks will become an MP3 collection of 10 tracks approximately 70 MB in size (this is a standard 128kbps audio quality CD) If the encoding is less (64 or 32kbps), the size of the resulting MP3 is smaller.
The hands down best ripping software to convert your audio CD to MP3's is called Goldwave. Although Nero and Winamp have functionality on a limited basis for this task, Goldwave is a far superior software package to not only rip, but also edit your creations. Once you have installed Goldwave, you use the OPEN CD button to read your files---then save them to your hard drive (in what CODEC or quality you want---MP3, Apple AIF, OggVorbis, etc.etc
Cannot make mp3 files from cds
Don't bother using Roxio for this - use Windows Media Player 11.
1. Open Windows Media Player
2. Run the mouse over the "Rip" tab - a small aroow should appear underneath the word "Rip" - click on the arrow and a drop-down should appear.
3. Select - "Format" - change to "mp3"
4. Now insert your CD and press the Rip button - by default, Windows Media Player will store the mp3 files in the My Documents --> My Music folder
Now use Roxio to make a CD out of the Mp3 files
-Tha Mp3 Doctor
 Grubhead
Grubhead
SmartAviator
SmartAviator
